[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.4-6-g7e88a075f
Tue Feb 1 23:06:58 PST 2022
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  7e88a075f3ec17b1cb6b0ce9e6561d469ce4a268 (commit)
      from  6287b09999f5f033ea8d3257b402fa69e47a3730 (commit)
revisions in full, below.
commit 7e88a075f3ec17b1cb6b0ce9e6561d469ce4a268
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Feb 2 02:06:50 2022 -0500
    Search path vulnerability during install/upgrade. References #5069 for PostGIS 3.0.5
diff --git a/NEWS b/NEWS
index 0cd4cd777..5bd0189b5 100644
--- a/NEWS
+++ b/NEWS
@@ -1,9 +1,11 @@
 PostGIS 3.0.5
-2021/XX/XX
+2022/02/XX
 * Bug Fixes and Enhancements *
   - #5026, fix DropTopology in presence of UPDATE triggers on
            topology layers (Sandro Santilli)
   - #5046, Fix upgrades in absence of old library (Sandro Santilli)
+  - #5069, search_path vulnerabilty during install/upgrade
+           (Regina Obe)
 PostGIS 3.0.4
 2021/09/04
diff --git a/extensions/postgis/unpackage_raster_if_needed.sql b/extensions/postgis/unpackage_raster_if_needed.sql
index 8b111bc6c..c344ea561 100644
--- a/extensions/postgis/unpackage_raster_if_needed.sql
+++ b/extensions/postgis/unpackage_raster_if_needed.sql
@@ -1,10 +1,10 @@
 DO $unpackage_if_needed$
 BEGIN
 	IF EXISTS (
-		select t.typname from pg_depend d, pg_extension e, pg_type t where
+		select t.typname from pg_catalog.pg_depend d, pg_catalog.pg_extension e, pg_catalog.pg_type t where
 		e.extname = 'postgis' and d.refclassid =
 		'pg_catalog.pg_extension'::pg_catalog.regclass and d.refobjid = e.oid
-		and d.classid = 'pg_type'::regclass and d.objid = t.oid
+		and d.classid = 'pg_catalog.pg_type'::pg_catalog.regclass and d.objid = t.oid
 		and t.typname = 'raster'
 	) THEN
diff --git a/extensions/postgis_extension_helper.sql b/extensions/postgis_extension_helper.sql
index bc1e9f92d..60af72748 100644
--- a/extensions/postgis_extension_helper.sql
+++ b/extensions/postgis_extension_helper.sql
@@ -30,38 +30,38 @@ DECLARE
 	var_sql_list text := '';
 	var_pgsql_version integer := current_setting('server_version_num');
 BEGIN
-		var_class := CASE WHEN lower(param_type) = 'function' OR lower(param_type) = 'aggregate' THEN 'pg_proc' ELSE '' END;
-		var_is_aggregate := CASE WHEN lower(param_type) = 'aggregate' THEN true ELSE false END;
+		var_class := CASE WHEN pg_catalog.lower(param_type) = 'function' OR pg_catalog.lower(param_type) = 'aggregate' THEN 'pg_proc' ELSE '' END;
+		var_is_aggregate := CASE WHEN pg_catalog.lower(param_type) = 'aggregate' THEN true ELSE false END;
 		IF var_pgsql_version < 110000 THEN
 			var_sql_list := $sql$SELECT 'ALTER EXTENSION ' || e.extname || ' DROP ' || $3 || ' ' || COALESCE(proc.proname || '(' || oidvectortypes(proc.proargtypes) || ')' ,typ.typname, cd.relname, op.oprname,
 					cs.typname || ' AS ' || ct.typname || ') ', opcname, opfname) || ';' AS remove_command
-			FROM pg_depend As d INNER JOIN pg_extension As e
-				ON d.refobjid = e.oid INNER JOIN pg_class As c ON
+			FROM pg_catalog.pg_depend As d INNER JOIN pg_catalog.pg_extension As e
+				ON d.refobjid = e.oid INNER JOIN pg_catalog.pg_class As c ON
 					c.oid = d.classid
-					LEFT JOIN pg_proc AS proc ON proc.oid = d.objid
-					LEFT JOIN pg_type AS typ ON typ.oid = d.objid
-					LEFT JOIN pg_class As cd ON cd.oid = d.objid
+					LEFT JOIN pg_catalog.pg_proc AS proc ON proc.oid = d.objid
+					LEFT JOIN pg_catalog.pg_type AS typ ON typ.oid = d.objid
+					LEFT JOIN pg_catalog.pg_class As cd ON cd.oid = d.objid
 					LEFT JOIN pg_operator As op ON op.oid = d.objid
-					LEFT JOIN pg_cast AS ca ON ca.oid = d.objid
-					LEFT JOIN pg_type AS cs ON ca.castsource = cs.oid
-					LEFT JOIN pg_type AS ct ON ca.casttarget = ct.oid
+					LEFT JOIN pg_catalog.pg_cast AS ca ON ca.oid = d.objid
+					LEFT JOIN pg_catalog.pg_type AS cs ON ca.castsource = cs.oid
+					LEFT JOIN pg_catalog.pg_type AS ct ON ca.casttarget = ct.oid
 					LEFT JOIN pg_opclass As oc ON oc.oid = d.objid
 					LEFT JOIN pg_opfamily As ofa ON ofa.oid = d.objid
 			WHERE d.deptype = 'e' and e.extname = $1 and c.relname = $2 AND COALESCE(proc.proisagg, false) = $4;$sql$;
 		ELSE -- for PostgreSQL 11 and above, they removed proc.proisagg among others and replaced with some func type thing
 					c.oid = d.classid
 			WHERE d.deptype = 'e' and e.extname = $1 and c.relname = $2 AND (proc.prokind = 'a')  = $4;$sql$;
@@ -85,7 +85,7 @@ CREATE OR REPLACE FUNCTION postgis_extension_drop_if_exists(param_extension text
   RETURNS boolean AS
 DECLARE
-	var_sql_ext text := 'ALTER EXTENSION ' || quote_ident(param_extension) || ' ' || replace(param_statement, 'IF EXISTS', '');
+	var_sql_ext text := 'ALTER EXTENSION ' || pg_catalog.quote_ident(param_extension) || ' ' || pg_catalog.replace(param_statement, 'IF EXISTS', '');
 	var_result boolean := false;
 BEGIN
 	BEGIN
@@ -109,13 +109,13 @@ DECLARE
 	var_result text;
 	var_cur_search_path text;
 BEGIN
-	SELECT reset_val INTO var_cur_search_path FROM pg_settings WHERE name = 'search_path';
-	IF var_cur_search_path LIKE '%' || quote_ident(a_schema_name) || '%' THEN
+	SELECT reset_val INTO var_cur_search_path FROM pg_catalog.pg_settings WHERE name = 'search_path';
+	IF var_cur_search_path LIKE '%' || pg_catalog.quote_ident(a_schema_name) || '%' THEN
 		var_result := a_schema_name || ' already in database search_path';
 	ELSE
 		var_cur_search_path := var_cur_search_path || ', '
-                        || quote_ident(a_schema_name);
-		EXECUTE 'ALTER DATABASE ' || quote_ident(current_database())
+                        || pg_catalog.quote_ident(a_schema_name);
+		EXECUTE 'ALTER DATABASE ' || pg_catalog.quote_ident(pg_catalog.current_database())
                               || ' SET search_path = ' || var_cur_search_path;
 		var_result := a_schema_name || ' has been added to end of database search_path ';
 	END IF;
diff --git a/extras/tiger_geocoder/utility/set_search_path.sql b/extras/tiger_geocoder/utility/set_search_path.sql
index c8e8595bb..19d2f9523 100644
--- a/extras/tiger_geocoder/utility/set_search_path.sql
+++ b/extras/tiger_geocoder/utility/set_search_path.sql
@@ -13,9 +13,9 @@ DECLARE
 	var_result text;
 BEGIN
-	EXECUTE 'SET search_path = ' || quote_ident(a_schema_name) || ', ' || var_cur_search_path;
+	EXECUTE 'SET search_path = ' || pg_catalog.quote_ident(a_schema_name) || ', ' || var_cur_search_path;
 	var_result := a_schema_name || ' has been made primary for install ';
   RETURN var_result;
 END
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 7bf0bfcd5..26bd3da64 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -29,15 +29,15 @@ DO $$
 DECLARE
 	pgver text;
 BEGIN
-	SELECT substring(version(), 'PostgreSQL ([0-9\.]+)') INTO pgver;
+	SELECT pg_catalog.substring(pg_catalog.version(), 'PostgreSQL ([0-9\.]+)') INTO pgver;
 	IF POSTGIS_PGSQL_VERSION::text != ( SELECT CASE
-		WHEN split_part(s,'.',1)::integer > 9
-			THEN split_part(s,'.',1) || '0'
+		WHEN pg_catalog.split_part(s,'.',1)::integer > 9
+			THEN pg_catalog.split_part(s,'.',1) || '0'
 		ELSE
-			split_part(s,'.', 1) || split_part(s,'.', 2)
+			pg_catalog.split_part(s,'.', 1) || pg_catalog.split_part(s,'.', 2)
 		END
-		FROM substring(version(), 'PostgreSQL ([0-9\.]+)') AS s )
+		FROM pg_catalog.substring(pg_catalog.version(), 'PostgreSQL ([0-9\.]+)') AS s )
 	THEN
 		RAISE EXCEPTION 'PostGIS built for PostgreSQL % cannot be loaded in PostgreSQL %',
 			POSTGIS_PGSQL_HR_VERSION, pgver;
@@ -52,7 +52,7 @@ DECLARE
   rec RECORD;
 BEGIN
   FOR rec IN
-    SELECT n.nspname, p.proname FROM pg_proc p, pg_namespace n
+    SELECT n.nspname, p.proname FROM pg_catalog.pg_proc p, pg_catalog.pg_namespace n
     WHERE p.proname = 'postgis_version'
     AND p.pronamespace = n.oid
   LOOP
@@ -2591,7 +2591,7 @@ BEGIN
         -- We are using postgis_type_name to lookup the new name
         -- (in case Paul changes his mind and flips geometry_columns to return old upper case name)
         EXECUTE 'ALTER TABLE ' || quote_ident(real_schema) || '.' || quote_ident(table_name) ||
-        ' ALTER COLUMN ' || quote_ident(column_name) || ' TYPE  geometry(' || @extschema at .postgis_type_name(myrec.type, myrec.coord_dimension, true) || ', ' || new_srid::text || ') USING @extschema at .ST_SetSRID(' || quote_ident(column_name) || ',' || new_srid::text || ');' ;
+        ' ALTER COLUMN ' || pg_catalog.quote_ident(column_name) || ' TYPE  geometry(' || @extschema at .postgis_type_name(myrec.type, myrec.coord_dimension, true) || ', ' || new_srid::text || ') USING @extschema at .ST_SetSRID(' || pg_catalog.quote_ident(column_name) || ',' || new_srid::text || ');' ;
     END IF;
 	RETURN real_schema || '.' || table_name || '.' || column_name ||' SRID changed to ' || new_srid::text;
@@ -2788,8 +2788,8 @@ CREATE OR REPLACE FUNCTION _postgis_scripts_pgsql_version() RETURNS text
 CREATE OR REPLACE FUNCTION _postgis_pgsql_version() RETURNS text
 AS $$
-	SELECT CASE WHEN split_part(s,'.',1)::integer > 9 THEN split_part(s,'.',1) || '0' ELSE split_part(s,'.', 1) || split_part(s,'.', 2) END AS v
-	FROM substring(version(), 'PostgreSQL ([0-9\.]+)') AS s;
+	SELECT CASE WHEN pg_catalog.split_part(s,'.',1)::integer > 9 THEN pg_catalog.split_part(s,'.',1) || '0' ELSE pg_catalog.split_part(s,'.', 1) || pg_catalog.split_part(s,'.', 2) END AS v
+	FROM pg_catalog.substring(pg_catalog.version(), 'PostgreSQL ([0-9\.]+)') AS s;
 $$ LANGUAGE 'sql' STABLE;
 -- Availability: 2.5.0
@@ -2846,7 +2846,7 @@ BEGIN
 				--force install in same schema as postgis only if postgis extension is installed
 				IF rec.name NOT IN('postgis', 'postgis_topology', 'postgis_tiger_geocoder') AND EXISTS (SELECT 1 FROM pg_catalog.pg_extension WHERE extname = 'postgis') THEN
 					sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged SCHEMA '
-					|| quote_ident( (SELECT ns.nspname FROM pg_catalog.pg_extension AS e INNER JOIN pg_catalog.pg_namespace AS ns ON e.extnamespace = ns.oid WHERE extname = 'postgis')) || ';';
+					|| pg_catalog.quote_ident( (SELECT ns.nspname FROM pg_catalog.pg_extension AS e INNER JOIN pg_catalog.pg_namespace AS ns ON e.extnamespace = ns.oid WHERE extname = 'postgis')) || ';';
 				ELSE
 					sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged;';
 				END IF;
@@ -2859,7 +2859,7 @@ BEGIN
 		ELSIF rec.default_version != rec.installed_version
 		THEN
 			sql = 'ALTER EXTENSION ' || rec.name || ' UPDATE TO ' ||
-						quote_ident(rec.default_version)   || ';';
+						pg_catalog.quote_ident(rec.default_version)   || ';';
 			RAISE NOTICE 'Updating extension % from % to %',
 				rec.name, rec.installed_version, rec.default_version;
 			RAISE DEBUG '%', sql;
@@ -2871,11 +2871,11 @@ BEGIN
 			RAISE NOTICE 'Updating extension % %',
 				rec.name, rec.installed_version;
-						quote_ident(rec.default_version || 'next')   || ';';
+						pg_catalog.quote_ident(rec.default_version || 'next')   || ';';
 			EXECUTE sql;
 			EXECUTE sql;
 		END IF;
@@ -2959,7 +2959,7 @@ BEGIN
 	END;
 	BEGIN
-		SELECT postgis_raster_scripts_installed() INTO rast_scr_ver;
+		SELECT @extschema at .postgis_raster_scripts_installed() INTO rast_scr_ver;
 	EXCEPTION
 		WHEN undefined_function THEN
 			RAISE DEBUG 'Function postgis_raster_scripts_installed() not found. Is raster support enabled and rtpostgis.sql installed?';
diff --git a/postgis/postgis_after_upgrade.sql b/postgis/postgis_after_upgrade.sql
index 02f86920b..20c08204f 100644
--- a/postgis/postgis_after_upgrade.sql
+++ b/postgis/postgis_after_upgrade.sql
@@ -241,7 +241,7 @@ BEGIN
 IF _postgis_scripts_pgsql_version()::integer >= 96 THEN
 -- mark ST_Union agg as parallel safe if it is not already
         BEGIN
-            UPDATE pg_proc SET proparallel = 's'
+            UPDATE pg_catalog.pg_proc SET proparallel = 's'
             WHERE oid = 'st_union(geometry)'::regprocedure AND proparallel = 'u';
         EXCEPTION WHEN OTHERS THEN
             RAISE DEBUG 'Could not update st_union(geometry): %', SQLERRM;
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index 5fdadad54..611e6108c 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -30,8 +30,8 @@
 --         FROM pg_catalog.pg_proc p
 --         LEFT JOIN pg_catalog.pg_namespace n ON n.oid = p.pronamespace
 --         WHERE
---                 LOWER(n.nspname) = LOWER('public') AND
---                 LOWER(p.proname) = LOWER('ST_AsGeoJson')
+--                 pg_catalog.LOWER(n.nspname) = pg_catalog.LOWER('public') AND
+--                 pg_catalog.LOWER(p.proname) = pg_catalog.LOWER('ST_AsGeoJson')
 --         ORDER BY 1, 2, 3, 4;
 CREATE OR REPLACE FUNCTION _postgis_drop_function_if_needed(
 	function_name text,
@@ -53,9 +53,9 @@ BEGIN
 	SELECT oid
 	WHERE pronamespace = postgis_namespace
-	AND LOWER(p.proname) = LOWER(function_name)
+	AND pg_catalog.LOWER(p.proname) = pg_catalog.LOWER(function_name)
 	AND pg_catalog.pg_function_is_visible(p.oid)
-	AND LOWER(pg_catalog.pg_get_function_identity_arguments(p.oid)) ~ LOWER(function_arguments)
+	AND pg_catalog.LOWER(pg_catalog.pg_get_function_identity_arguments(p.oid)) ~ pg_catalog.LOWER(function_arguments)
 	INTO matching_function;
 	IF matching_function IS NOT NULL THEN
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index b5e7a093a..15414c346 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -47,7 +47,7 @@ DECLARE
   rec RECORD;
 BEGIN
   FOR rec IN
     WHERE p.proname = 'postgis_raster_lib_version'
   LOOP
@@ -63,11 +63,11 @@ DECLARE
   nsp TEXT;
 BEGIN
   SELECT n.nspname
-	INTO nsp FROM pg_proc p, pg_namespace n
+	INTO nsp FROM pg_catalog.pg_proc p, pg_catalog.pg_namespace n
   WHERE p.proname = 'postgis_lib_version'
   AND p.pronamespace = n.oid;
-	IF nsp != current_schema() THEN
+	IF nsp != pg_catalog.current_schema() THEN
     RAISE EXCEPTION
 			'PostGIS Raster must be in the same schema as PostGIS (%)',
 			nsp;
@@ -7216,7 +7216,7 @@ CREATE OR REPLACE FUNCTION _raster_constraint_info_srid(rastschema name, rasttab
 			split_part(s.consrc, ' = ', 2),
 			'[\(\)]', '', 'g'
 		)::integer
-	FROM pg_class c, pg_namespace n, pg_attribute a
+	FROM pg_catalog.pg_class c, pg_catalog.pg_namespace n, pg_catalog.pg_attribute a
 		, (SELECT connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
 		    FROM pg_constraint) AS s
 	WHERE n.nspname = $1
diff --git a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
index 0d6f3ba00..e31d74f76 100644
--- a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
+++ b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
@@ -94,11 +94,11 @@ BEGIN
 	IF NOT EXISTS (
 			SELECT
 				proname
-			FROM pg_proc f
-			JOIN pg_type r
+			FROM pg_catalog.pg_proc f
+			JOIN pg_catalog.pg_type r
 				ON r.typname = 'raster'
 					AND (f.proargtypes::oid[])[0] = r.oid
-			JOIN pg_type g
+			JOIN pg_catalog.pg_type g
 				ON g.typname = 'geometry'
 					AND (f.proargtypes::oid[])[1] = g.oid
 			WHERE proname = 'raster_contained_by_geometry'
@@ -117,11 +117,11 @@ BEGIN
 	IF NOT EXISTS (
 			SELECT
 				proname
-			FROM pg_proc f
-			JOIN pg_type r
 					AND (f.proargtypes::oid[])[1] = r.oid
-			JOIN pg_type g
 					AND (f.proargtypes::oid[])[0] = g.oid
 			WHERE proname = 'geometry_contained_by_raster'
@@ -362,8 +362,8 @@ CREATE OR REPLACE FUNCTION _rename_raster_tables()
 		cnt int;
 	BEGIN
 		SELECT count(*) INTO cnt
-		FROM pg_class c
-		JOIN pg_namespace n
+		JOIN pg_catalog.pg_namespace n
 			ON c.relnamespace = n.oid
 		WHERE c.relname = 'raster_columns'
 			AND c.relkind = 'r'::char
@@ -374,8 +374,8 @@ CREATE OR REPLACE FUNCTION _rename_raster_tables()
 		END IF;
-		FROM pg_class c
 		WHERE c.relname = 'raster_overviews'
@@ -417,8 +417,8 @@ CREATE OR REPLACE FUNCTION _drop_st_samealignment()
 		cnt int;
 	BEGIN
-		FROM pg_proc
-		WHERE lower(proname) = 'st_samealignment'
+		WHERE pg_catalog.lower(proname) = 'st_samealignment'
 			AND pronargs = 2
 			AND (
 				proargnames = '{rasta,rastb}'::text[] OR
@@ -586,10 +586,10 @@ BEGIN
 	SELECT
 		count(*)
 	INTO cnt
-	FROM pg_proc f
-	JOIN pg_type t
+	JOIN pg_catalog.pg_type t
 		ON f.prorettype = t.oid
-	WHERE lower(f.proname) = '_raster_constraint_nodata_values'
+	WHERE pg_catalog.lower(f.proname) = '_raster_constraint_nodata_values'
 		AND f.pronargs = 1
 		AND t.typname = '_float8'; -- array form
diff --git a/topology/sql/manage/ManageHelper.sql.in b/topology/sql/manage/ManageHelper.sql.in
index 31b70756b..2acfd9c41 100644
--- a/topology/sql/manage/ManageHelper.sql.in
+++ b/topology/sql/manage/ManageHelper.sql.in
@@ -25,13 +25,13 @@ DECLARE
 	var_result text;
 BEGIN
 	ELSE
 	END IF;
diff --git a/utils/create_undef.pl b/utils/create_undef.pl
index 077c649b5..c59521192 100755
--- a/utils/create_undef.pl
+++ b/utils/create_undef.pl
@@ -261,10 +261,10 @@ DECLARE
 BEGIN
 	FOR rec IN
 		SELECT n.nspname, c.relname, a.attname, t.typname
-		FROM pg_attribute a
-		JOIN pg_class c ON a.attrelid = c.oid
-		JOIN pg_namespace n ON c.relnamespace = n.oid
-		JOIN pg_type t ON a.atttypid = t.oid
+		FROM pg_catalog.pg_attribute a
+		JOIN pg_catalog.pg_class c ON a.attrelid = c.oid
+		JOIN pg_catalog.pg_namespace n ON c.relnamespace = n.oid
+		JOIN pg_catalog.pg_type t ON a.atttypid = t.oid
 		WHERE t.typname = '$type'
 		  AND NOT (
 				-- we exclude complexes defined as types
@@ -363,14 +363,14 @@ DECLARE
 	var_search_path text;
 BEGIN
 	SELECT reset_val INTO var_search_path FROM pg_settings WHERE name = 'search_path';
-	IF var_search_path NOT LIKE '%' || quote_ident(a_schema_name) || '%' THEN
+	IF var_search_path NOT LIKE '%' || pg_catalog.quote_ident(a_schema_name) || '%' THEN
 		var_result := a_schema_name || ' not in database search_path';
 	ELSE
-    var_search_path := btrim( regexp_replace(
-        replace(var_search_path, a_schema_name, ''), ', *,', ','),
+    var_search_path := pg_catalog.btrim( pg_catalog.regexp_replace(
+        pg_catalog.replace(var_search_path, a_schema_name, ''), ', *,', ','),
     RAISE NOTICE 'New search_path: %', var_search_path;
-		EXECUTE 'ALTER DATABASE ' || quote_ident(current_database()) || ' SET search_path = ' || var_search_path;
+		EXECUTE 'ALTER DATABASE ' || pg_catalog.quote_ident(pg_catalog.current_database()) || ' SET search_path = ' || var_search_path;
 		var_result := a_schema_name || ' has been stripped off database search_path ';
 	END IF;
diff --git a/utils/postgis_proc_upgrade.pl b/utils/postgis_proc_upgrade.pl
index d50436bc4..8c2761ac9 100755
--- a/utils/postgis_proc_upgrade.pl
+++ b/utils/postgis_proc_upgrade.pl
@@ -545,8 +545,8 @@ BEGIN
         SELECT into old_scripts MODULE_scripts_installed();
     END;
     SELECT into new_scripts 'NEWVERSION';
-    SELECT into old_maj substring(old_scripts from 1 for 1);
-    SELECT into new_maj substring(new_scripts from 1 for 1);
+    SELECT into old_maj pg_catalog.substring(old_scripts, 1, 1);
+    SELECT into new_maj pg_catalog.substring(new_scripts, 1,1);
     -- 2.x to 3.x was upgrade-compatible, see
     -- https://trac.osgeo.org/postgis/ticket/4170#comment:1
@@ -567,11 +567,11 @@ CREATE TEMPORARY TABLE _postgis_upgrade_info AS WITH versions AS (
 ) SELECT
   upgraded as scripts_upgraded,
   installed as scripts_installed,
-  substring(upgraded from '([0-9]*)\.')::int * 100 +
-  substring(upgraded from '[0-9]*\.([0-9]*)\.')::int
+  pg_catalog.substring(upgraded, '([0-9]*)\.')::int * 100 +
+  pg_catalog.substring(upgraded, '[0-9]*\.([0-9]*)\.')::int
     as version_to_num,
-  substring(installed from '([0-9]*)\.')::int * 100 +
-  substring(installed from '[0-9]*\.([0-9]*)\.')::int
+  pg_catalog.substring(installed, '([0-9]*)\.')::int * 100 +
+  pg_catalog.substring(installed, '[0-9]*\.([0-9]*)\.')::int
     as version_from_num,
   installed ~ 'dev|alpha|beta'
     as version_from_isdev
Summary of changes:
 NEWS                                              |  4 +-
 extensions/postgis/unpackage_raster_if_needed.sql |  4 +-
 extensions/postgis_extension_helper.sql           | 46 +++++++++++------------
 extras/tiger_geocoder/utility/set_search_path.sql |  4 +-
 postgis/postgis.sql.in                            | 28 +++++++-------
 postgis/postgis_after_upgrade.sql                 |  2 +-
 postgis/postgis_before_upgrade.sql                |  8 ++--
 raster/rt_pg/rtpostgis.sql.in                     |  8 ++--
 raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in     | 30 +++++++--------
 topology/sql/manage/ManageHelper.sql.in           |  8 ++--
 utils/create_undef.pl                             | 16 ++++----
 utils/postgis_proc_upgrade.pl                     | 12 +++---
 12 files changed, 86 insertions(+), 84 deletions(-)
hooks/post-receive
