[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-475-g289bc3830
Thu Feb 3 13:27:42 PST 2022
the project "PostGIS".
       via  289bc3830c2af633f92ea86c3d3c65f969379083 (commit)
      from  9416eb1705253f8365461f8050a7536b0a0ce060 (commit)
revisions in full, below.
commit 289bc3830c2af633f92ea86c3d3c65f969379083
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Feb 3 13:27:39 2022 -0800
    Add doc simple SQLMM and UnaryUnion refs
diff --git a/doc/reference_overlay.xml b/doc/reference_overlay.xml
index e3c944c28..1c5d0a9f4 100644
--- a/doc/reference_overlay.xml
+++ b/doc/reference_overlay.xml
@@ -890,29 +890,35 @@ MULTILINESTRING((1 3 2.75,1 4 2),(1 1 3,1 2 2.25))
         <para>
         A single-input variant of <xref linkend="ST_Union" />.
         The input may be a single geometry, a MultiGeometry, or a GeometryCollection.
-        The union is applied to the individual components of the input.
-        This allow using this function to fix MultiPolygons which  are
+        The union is applied to the individual elements of the input.
+        </para>
+        <para>
+        This function can be used to fix MultiPolygons which  are
         invalid due to overlapping components.
-        (However, the input components must each be valid.
-        An invalid input component such as a bow-tie polygon may cause an error.)
+        However, the input components must each be valid.
+        An invalid input component such as a bow-tie polygon may cause an error.
+        For this reason it may be better to use <xref linkend="ST_MakeValid" />.
         </para>
         <para>
-        Another use of this function is to node and dissolve a collection of linestrings.
-        (This can also be done with <xref linkend="ST_Node" />.)
+        Another use of this function is to node and dissolve a collection of
+        linestrings which cross or overlap
+        to make them <link linkend="Simple_Geometry">simple</link>.
+        (To add nodes but not dissolve duplicate linework
+        use <xref linkend="ST_Node" />.)
         </para>
         <para>
-        It is possible to mix ST_UnaryUnion with <xref linkend="ST_Collect" /> to fine-tune
+        It is possible to combine ST_UnaryUnion with <xref linkend="ST_Collect" /> to fine-tune
         how many geometries are be unioned at once.
         This allows trading off between memory usage and compute time,
         striking a balance between ST_Union and <xref linkend="ST_MemUnion" />.
         </para>
         <para>
-If the optional <code>gridSize</code> argument is provided, the inputs are
-snapped to a grid of the given size, and the result vertices are computed
-on that same grid. (Requires GEOS-3.9.0 or higher)
+        If the optional <code>gridSize</code> argument is provided, the inputs are
+        snapped to a grid of the given size, and the result vertices are computed
+        on that same grid. (Requires GEOS-3.9.0 or higher)
         </para>
         <para>&Z_support; However, the result is computed using XY only.
@@ -930,6 +936,7 @@ on that same grid. (Requires GEOS-3.9.0 or higher)
         <para>
             <xref linkend="ST_Union" />,
             <xref linkend="ST_MemUnion" />,
+            <xref linkend="ST_MakeValid" />,
             <xref linkend="ST_Collect" />,
         </para>
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index 1629f4527..4c6c8ab77 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -879,12 +879,13 @@ SELECT ST_Distance('LINESTRING(-122.33 47.606, 0.0 51.5)'::geometry, 'POINT(-21.
 	  <title>Geometry Validation</title>
 	  <para>PostGIS is compliant with the Open Geospatial Consortium’s (OGC)
-	  Simple Features Specification.
-      It defines the concepts of geometry being
+	  Simple Features specification.
+      That standard defines the concepts of geometry being
       <emphasis>simple</emphasis> and <emphasis>valid</emphasis>.
       These definitions allow the Simple Features geometry model
       to represent spatial objects in a consistent and unambiguous way
       that supports efficient computation.
+      (Note: the OGC SF and SQL/MM have the same definitions for simple and valid.)
         </para>
 	<sect2 id="Simple_Geometry">
@@ -1025,8 +1026,8 @@ SELECT ST_Distance('LINESTRING(-122.33 47.606, 0.0 51.5)'::geometry, 'POINT(-21.
 		</tgroup>
 	  </informaltable>
-    <para>As described in the next section, the linear rings forming a
-    <varname>POLYGON</varname> must be simple for it to be valid.</para>
+    <para><varname>POLYGON</varname>s are formed from linear rings, so
+    valid polygonal geometry is always <emphasis>simple</emphasis>.</para>
     <para>To test if a geometry is simple
 	use the <xref linkend="ST_IsSimple" /> function:</para>
@@ -1045,6 +1046,7 @@ SELECT
 	Simplicity is primarily used as a basis for defining geometric validity.
     It is also a requirement for some kinds of spatial data models
     (for example, linear networks often disallow lines that cross).
+    Multipoint and linear geometry can be made simple using <xref linkend="ST_UnaryUnion" />.
     </para>
     </sect2>
Summary of changes:
 doc/reference_overlay.xml     | 27 +++++++++++++++++----------
 doc/using_postgis_dataman.xml | 10 ++++++----
 2 files changed, 23 insertions(+), 14 deletions(-)
hooks/post-receive
