[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-476-g4d970198b
Thu Feb 3 14:00:16 PST 2022
the project "PostGIS".
       via  4d970198baef0c027843dc6be9e3e85e0c8e4367 (commit)
      from  289bc3830c2af633f92ea86c3d3c65f969379083 (commit)
revisions in full, below.
commit 4d970198baef0c027843dc6be9e3e85e0c8e4367
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Feb 3 14:00:12 2022 -0800
    Improve doc for ST_LineCrossingDirection
diff --git a/doc/html/image_src/st_linecrossingdirection01.wkt b/doc/html/image_src/st_linecrossingdirection01.wkt
index d4963c680..64b080b24 100644
--- a/doc/html/image_src/st_linecrossingdirection01.wkt
+++ b/doc/html/image_src/st_linecrossingdirection01.wkt
@@ -1,2 +1,2 @@
-ArgB;GEOMETRYCOLLECTION(LINESTRING(25 169,89 114,40 70,86 43), POINT(25 169),POLYGON((78.26 40.98,83.98 50.74,86 43,78.26 40.98)) )
-ArgA;GEOMETRYCOLLECTION(LINESTRING(171 154,20 140,71 74,161 53),POINT(171 154),POLYGON((153.15 48.12,156.12 60.85,161 53,153.15 48.12)) )
+ArgA;GEOMETRYCOLLECTION(LINESTRING(25 169,89 114,40 70,86 43), POINT(25 169),POLYGON((78.26 40.98,83.98 50.74,86 43,78.26 40.98)) )
+ArgB;GEOMETRYCOLLECTION(LINESTRING(171 154,20 140,71 74,161 53),POINT(171 154),POLYGON((153.15 48.12,156.12 60.85,161 53,153.15 48.12)) )
diff --git a/doc/html/image_src/st_linecrossingdirection02.wkt b/doc/html/image_src/st_linecrossingdirection02.wkt
index 28dcd17e3..f26dcf2f5 100644
--- a/doc/html/image_src/st_linecrossingdirection02.wkt
+++ b/doc/html/image_src/st_linecrossingdirection02.wkt
@@ -1,2 +1,2 @@
-ArgB;GEOMETRYCOLLECTION(LINESTRING(25 169,89 114,40 70,86 43), POINT(25 169), POLYGON((80.84 41.66,84.66 48.16,86 43,80.84 41.66)) )
-ArgA;GEOMETRYCOLLECTION(LINESTRING(171 154, 20 140, 71 74, 2.99 90.16),POINT(171 154),POLYGON((6.66 84.21,2.99 90.16,8.94 93.83,6.66 84.21)) )
+ArgA;GEOMETRYCOLLECTION(LINESTRING(25 169,89 114,40 70,86 43), POINT(25 169), POLYGON((80.84 41.66,84.66 48.16,86 43,80.84 41.66)) )
+ArgB;GEOMETRYCOLLECTION(LINESTRING(171 154, 20 140, 71 74, 2.99 90.16),POINT(171 154),POLYGON((6.66 84.21,2.99 90.16,8.94 93.83,6.66 84.21)) )
diff --git a/doc/html/image_src/st_linecrossingdirection03.wkt b/doc/html/image_src/st_linecrossingdirection03.wkt
index 2d84451bd..072ce4dc3 100644
--- a/doc/html/image_src/st_linecrossingdirection03.wkt
+++ b/doc/html/image_src/st_linecrossingdirection03.wkt
@@ -1,2 +1,2 @@
-ArgA;GEOMETRYCOLLECTION(LINESTRING (20 140, 71 74, 161 53), POLYGON ((153.15 48.12, 156.12 60.85, 161 53, 153.15 48.12)))
+ArgA;GEOMETRYCOLLECTION(LINESTRING(25 169,89 114,40 70,86 43), POINT(25 169), POLYGON((78.26 40.98,83.98 50.74,86 43,78.26 40.98)) )
+ArgB;GEOMETRYCOLLECTION(LINESTRING (20 140, 71 74, 161 53), POINT(20 140), POLYGON ((153.15 48.12, 156.12 60.85, 161 53, 153.15 48.12)))
diff --git a/doc/html/image_src/st_linecrossingdirection04.wkt b/doc/html/image_src/st_linecrossingdirection04.wkt
index df543396f..b46305346 100644
--- a/doc/html/image_src/st_linecrossingdirection04.wkt
+++ b/doc/html/image_src/st_linecrossingdirection04.wkt
@@ -1,2 +1,2 @@
-ArgA;GEOMETRYCOLLECTION(LINESTRING(2.99 90.16,71 74,20 140,171 154),POINT(2.99 90.16),POLYGON((159.33 163.69,171 154,161.31 142.33,159.33 163.69)) )
+ArgB;GEOMETRYCOLLECTION(LINESTRING(5 90,71 74,20 140,171 154),POINT(5 90),POLYGON((159.33 163.69,171 154,161.31 142.33,159.33 163.69)) )
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index 85c55041b..8bc310f08 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -709,191 +709,6 @@ WHERE ST_Crosses(roads.geom, highways.geom);</programlisting>
     </refsection>
   </refentry>
-  <refentry id="ST_LineCrossingDirection">
-  <refnamediv>
-    <refname>ST_LineCrossingDirection</refname>
-    <refpurpose>Returns a number indicating the crossing behavior of two LineStrings.</refpurpose>
-  </refnamediv>
-  <refsynopsisdiv>
-    <funcsynopsis>
-    <funcprototype>
-      <funcdef>integer <function>ST_LineCrossingDirection</function></funcdef>
-      <paramdef><type>geometry </type> <parameter>linestringA</parameter></paramdef>
-      <paramdef><type>geometry </type> <parameter>linestringB</parameter></paramdef>
-    </funcprototype>
-    </funcsynopsis>
-  </refsynopsisdiv>
-  <refsection>
-    <title>Description</title>
-    <para>Given 2 linestrings, returns an integer between -3 and 3
-      indicating what kind of crossing behavior exists between them.
-      0 indicates no crossing.
-      This is only supported for <varname>LINESTRING</varname>s.
-      </para>
-    <para>The crossing number has the following meaning:
-       <itemizedlist>
-        <listitem>
-          <para> 0: LINE NO CROSS</para>
-        </listitem>
-        <listitem>
-          <para>-1: LINE CROSS LEFT</para>
-        </listitem>
-        <listitem>
-          <para> 1: LINE CROSS RIGHT</para>
-        </listitem>
-        <listitem>
-          <para>-2: LINE MULTICROSS END LEFT</para>
-        </listitem>
-        <listitem>
-          <para> 2: LINE MULTICROSS END RIGHT</para>
-        </listitem>
-        <listitem>
-          <para>-3: LINE MULTICROSS END SAME FIRST LEFT</para>
-        </listitem>
-        <listitem>
-          <para> 3: LINE MULTICROSS END SAME FIRST RIGHT</para>
-        </listitem>
-      </itemizedlist>
-    </para>
-    <para>Availability: 1.4</para>
-    <!-- optionally mention that this function uses indexes if appropriate -->
-  </refsection>
-  <refsection>
-    <title>Examples</title>
-  <!-- TODO: We really badly need diagrams here and more examples -->
-    <informaltable>
-      <tgroup cols="2">
-      <tbody>
-        <row>
-        <entry><para><informalfigure>
-          <mediaobject>
-            <imageobject>
-            <imagedata fileref="images/st_linecrossingdirection01.png" />
-            </imageobject>
-            <caption><para>Line 1 (green), Line 2 ball is start point,
-          triangle are end points. Query below. </para></caption>
-          </mediaobject>
-          </informalfigure>
-          <programlisting>
-SELECT ST_LineCrossingDirection(foo.line1, foo.line2) As l1_cross_l2 ,
-    ST_LineCrossingDirection(foo.line2, foo.line1) As l2_cross_l1
-FROM (
-SELECT
- ST_GeomFromText('LINESTRING(25 169,89 114,40 70,86 43)') As line1,
- ST_GeomFromText('LINESTRING(171 154,20 140,71 74,161 53)') As line2
-  ) As foo;
- l1_cross_l2 | l2_cross_l1
-           3 |          -3
-        </programlisting>
-      </para>
-    </entry>
-    <entry>
-      <para><informalfigure>
-        <mediaobject>
-          <imageobject>
-          <imagedata fileref="images/st_linecrossingdirection02.png" />
-          </imageobject>
-          <caption><para>Line 1 (green), Line 2 (blue) ball is start point,
-            triangle are end points. Query below.</para></caption>
-        </mediaobject>
-        </informalfigure>
-        <programlisting>
-FROM (
- SELECT
-  ST_GeomFromText('LINESTRING (171 154, 20 140, 71 74, 2.99 90.16)') As line2
-) As foo;
-           2 |          -2
-        </programlisting>
-      </para>
-    </entry>
-    </row>
-    <row>
-          <mediaobject>
-            <imageobject>
-            <imagedata fileref="images/st_linecrossingdirection03.png" />
-            </imageobject>
-          </mediaobject>
-          </informalfigure>
-          <programlisting>
-SELECT
-  ST_LineCrossingDirection(foo.line1, foo.line2) As l1_cross_l2 ,
-FROM (
- SELECT
-  ST_GeomFromText('LINESTRING (20 140, 71 74, 161 53)') As line2
-  ) As foo;
-          -1 |          1
-        </programlisting>
-      </para>
-    </entry>
-    <entry>
-        <mediaobject>
-          <imageobject>
-          <imagedata fileref="images/st_linecrossingdirection04.png" />
-          </imageobject>
-        </mediaobject>
-        </informalfigure>
-        <programlisting>
-FROM (SELECT
-  ST_GeomFromText('LINESTRING(2.99 90.16,71 74,20 140,171 154)') As line2
-  ) As foo;
-          -2 |          2
-        </programlisting>
-      </para>
-    </entry>
-    </row>
-    </tbody>
-  </tgroup>
-</informaltable>
-<programlisting>
-SELECT s1.gid, s2.gid, ST_LineCrossingDirection(s1.geom, s2.geom)
-  FROM streets s1 CROSS JOIN streets s2 ON (s1.gid != s2.gid AND s1.geom && s2.geom )
-WHERE ST_CrossingDirection(s1.geom, s2.geom) > 0;
-</programlisting>
-  </refsection>
-  <!-- Optionally add a "See Also" section -->
-  <refsection>
-    <title>See Also</title>
-    <para><xref linkend="ST_Crosses" /></para>
-  </refsection>
-  </refentry>
   <refentry id="ST_Disjoint">
     <refnamediv>
       <refname>ST_Disjoint</refname>
@@ -1132,6 +947,175 @@ t
     </refsection>
   </refentry>
+  <refentry id="ST_LineCrossingDirection">
+  <refnamediv>
+    <refname>ST_LineCrossingDirection</refname>
+    <refpurpose>Returns a number indicating the crossing behavior of two LineStrings.</refpurpose>
+  </refnamediv>
+  <refsynopsisdiv>
+    <funcsynopsis>
+    <funcprototype>
+      <funcdef>integer <function>ST_LineCrossingDirection</function></funcdef>
+      <paramdef><type>geometry </type> <parameter>linestringA</parameter></paramdef>
+      <paramdef><type>geometry </type> <parameter>linestringB</parameter></paramdef>
+    </funcprototype>
+    </funcsynopsis>
+  </refsynopsisdiv>
+  <refsection>
+    <title>Description</title>
+    <para>Given 2 linestrings, returns an integer between -3 and 3
+      indicating what kind of crossing behavior exists between them.
+      0 indicates no crossing.
+      This is only supported for <varname>LINESTRING</varname>s.
+      </para>
+    <para>The crossing number has the following meaning:
+       <itemizedlist>
+        <listitem>
+          <para> 0: LINE NO CROSS</para>
+        </listitem>
+        <listitem>
+          <para>-1: LINE CROSS LEFT</para>
+        </listitem>
+        <listitem>
+          <para> 1: LINE CROSS RIGHT</para>
+        </listitem>
+        <listitem>
+          <para>-2: LINE MULTICROSS END LEFT</para>
+        </listitem>
+        <listitem>
+          <para> 2: LINE MULTICROSS END RIGHT</para>
+        </listitem>
+        <listitem>
+          <para>-3: LINE MULTICROSS END SAME FIRST LEFT</para>
+        </listitem>
+        <listitem>
+          <para> 3: LINE MULTICROSS END SAME FIRST RIGHT</para>
+        </listitem>
+      </itemizedlist>
+    </para>
+    <para>Availability: 1.4</para>
+    <!-- optionally mention that this function uses indexes if appropriate -->
+  </refsection>
+  <refsection>
+    <title>Examples</title>
+    <para><emphasis role="bold">Example:</emphasis>
+    LINE CROSS LEFT and LINE CROSS RIGHT
+    </para>
+    <informalfigure>
+          <mediaobject>
+            <imageobject>
+            <imagedata fileref="images/st_linecrossingdirection03.png" />
+            </imageobject>
+            <caption><para>Blue: Line 1;  Green: Line 2</para></caption>
+          </mediaobject>
+          </informalfigure>
+          <programlisting>
+SELECT ST_LineCrossingDirection(foo.line1, foo.line2) As l1_cross_l2,
+       ST_LineCrossingDirection(foo.line2, foo.line1) As l2_cross_l1
+FROM (SELECT
+  ST_GeomFromText('LINESTRING(25 169,89 114,40 70,86 43)') As line1,
+  ST_GeomFromText('LINESTRING (20 140, 71 74, 161 53)') As line2
+  ) As foo;
+ l1_cross_l2 | l2_cross_l1
+          -1 |          1
+</programlisting>
+    LINE MULTICROSS END SAME FIRST LEFT and LINE MULTICROSS END SAME FIRST RIGHT
+    </para>
+    <informalfigure>
+          <mediaobject>
+            <imageobject>
+            <imagedata fileref="images/st_linecrossingdirection01.png" />
+            </imageobject>
+          </mediaobject>
+          </informalfigure>
+          <programlisting>
+FROM (SELECT
+ ST_GeomFromText('LINESTRING(171 154,20 140,71 74,161 53)') As line2
+  ) As foo;
+           3 |          -3
+</programlisting>
+      LINE MULTICROSS END LEFT and LINE MULTICROSS END RIGHT
+      </para>
+      <informalfigure>
+        <mediaobject>
+          <imageobject>
+          <imagedata fileref="images/st_linecrossingdirection04.png" />
+          </imageobject>
+        </mediaobject>
+        </informalfigure>
+        <programlisting>
+FROM (SELECT
+  ST_GeomFromText('LINESTRING(5 90, 71 74, 20 140, 171 154)') As line2
+  ) As foo;
+          -2 |          2
+</programlisting>
+      </para>
+      <informalfigure>
+        <mediaobject>
+          <imageobject>
+          <imagedata fileref="images/st_linecrossingdirection02.png" />
+          </imageobject>
+        </mediaobject>
+        </informalfigure>
+        <programlisting>
+FROM (SELECT
+  ST_GeomFromText('LINESTRING (171 154, 20 140, 71 74, 2.99 90.16)') As line2
+) As foo;
+           2 |          -2
+</programlisting>
+<programlisting>
+SELECT s1.gid, s2.gid, ST_LineCrossingDirection(s1.geom, s2.geom)
+  FROM streets s1 CROSS JOIN streets s2
+         ON (s1.gid != s2.gid AND s1.geom && s2.geom )
+WHERE ST_LineCrossingDirection(s1.geom, s2.geom) > 0;
+</programlisting>
+  </refsection>
+  <refsection>
+    <title>See Also</title>
+    <para><xref linkend="ST_Crosses" /></para>
+  </refsection>
+  </refentry>
   <refentry id="ST_OrderingEquals">
     <refnamediv>
     <refname>ST_OrderingEquals</refname>
Summary of changes:
 doc/html/image_src/st_linecrossingdirection01.wkt |   4 +-
 doc/html/image_src/st_linecrossingdirection02.wkt |   4 +-
 doc/html/image_src/st_linecrossingdirection03.wkt |   4 +-
 doc/html/image_src/st_linecrossingdirection04.wkt |   4 +-
 doc/reference_relationship.xml                    | 354 +++++++++++-----------
 5 files changed, 177 insertions(+), 193 deletions(-)
hooks/post-receive
