[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-477-g98f05d524
Thu Feb 3 14:09:19 PST 2022
the project "PostGIS".
       via  98f05d524ca0b2a59d208ad1e643479ad8c48b37 (commit)
      from  4d970198baef0c027843dc6be9e3e85e0c8e4367 (commit)
revisions in full, below.
commit 98f05d524ca0b2a59d208ad1e643479ad8c48b37
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Feb 3 14:09:15 2022 -0800
    Fix doc ST_LIneCrossingDirection
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index 8bc310f08..19de153c7 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -967,7 +967,7 @@ t
   <refsection>
     <title>Description</title>
-    <para>Given 2 linestrings, returns an integer between -3 and 3
+    <para>Given two linestrings returns an integer between -3 and 3
       indicating what kind of crossing behavior exists between them.
       0 indicates no crossing.
       This is only supported for <varname>LINESTRING</varname>s.
@@ -998,11 +998,8 @@ t
       </itemizedlist>
     </para>
     <para>Availability: 1.4</para>
-    <!-- optionally mention that this function uses indexes if appropriate -->
   </refsection>
   <refsection>
     <title>Examples</title>
@@ -1014,20 +1011,20 @@ t
             <imageobject>
             <imagedata fileref="images/st_linecrossingdirection03.png" />
             </imageobject>
-            <caption><para>Blue: Line 1;  Green: Line 2</para></caption>
+            <caption><para>Blue: Line A;  Green: Line B</para></caption>
           </mediaobject>
           </informalfigure>
           <programlisting>
-SELECT ST_LineCrossingDirection(foo.line1, foo.line2) As l1_cross_l2,
-       ST_LineCrossingDirection(foo.line2, foo.line1) As l2_cross_l1
+SELECT ST_LineCrossingDirection(lineA, lineB) As A_cross_B,
+       ST_LineCrossingDirection(lineB, lineA) As B_cross_A
 FROM (SELECT
-  ST_GeomFromText('LINESTRING(25 169,89 114,40 70,86 43)') As line1,
-  ST_GeomFromText('LINESTRING (20 140, 71 74, 161 53)') As line2
+  ST_GeomFromText('LINESTRING(25 169,89 114,40 70,86 43)') As lineA,
+  ST_GeomFromText('LINESTRING (20 140, 71 74, 161 53)') As lineB
   ) As foo;
- l1_cross_l2 | l2_cross_l1
-          -1 |          1
+ A_cross_B | B_cross_A
+        -1 |         1
 </programlisting>
     <para><emphasis role="bold">Example:</emphasis>
@@ -1038,20 +1035,20 @@ FROM (SELECT
             <imageobject>
             <imagedata fileref="images/st_linecrossingdirection01.png" />
             </imageobject>
           </mediaobject>
           </informalfigure>
           <programlisting>
 FROM (SELECT
- ST_GeomFromText('LINESTRING(171 154,20 140,71 74,161 53)') As line2
+ ST_GeomFromText('LINESTRING(171 154,20 140,71 74,161 53)') As lineB
   ) As foo;
-           3 |          -3
+         3 |        -3
 </programlisting>
@@ -1062,20 +1059,20 @@ FROM (SELECT
           <imageobject>
           <imagedata fileref="images/st_linecrossingdirection04.png" />
           </imageobject>
         </mediaobject>
         </informalfigure>
         <programlisting>
 FROM (SELECT
-  ST_GeomFromText('LINESTRING(5 90, 71 74, 20 140, 171 154)') As line2
+  ST_GeomFromText('LINESTRING(5 90, 71 74, 20 140, 171 154)') As lineB
   ) As foo;
-          -2 |          2
+        -2 |         2
 </programlisting>
@@ -1086,20 +1083,20 @@ FROM (SELECT
           <imageobject>
           <imagedata fileref="images/st_linecrossingdirection02.png" />
           </imageobject>
         </mediaobject>
         </informalfigure>
         <programlisting>
 FROM (SELECT
-  ST_GeomFromText('LINESTRING (171 154, 20 140, 71 74, 2.99 90.16)') As line2
+  ST_GeomFromText('LINESTRING (171 154, 20 140, 71 74, 2.99 90.16)') As lineB
 ) As foo;
-           2 |          -2
+         2 |        -2
 </programlisting>
 <programlisting>
Summary of changes:
 doc/reference_relationship.xml | 69 ++++++++++++++++++++----------------------
 1 file changed, 33 insertions(+), 36 deletions(-)
hooks/post-receive
