[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-480-g0ffe2870e
Thu Feb 3 15:43:54 PST 2022
the project "PostGIS".
       via  0ffe2870eade1a26a1573eb11e7540eacc207783 (commit)
       via  d59be353157fd3944779c7291cf1fb2d5334453e (commit)
       via  8cc96d62a72f7356a9dbf90e412c0a5705cc1c9c (commit)
      from  98f05d524ca0b2a59d208ad1e643479ad8c48b37 (commit)
revisions in full, below.
commit 0ffe2870eade1a26a1573eb11e7540eacc207783
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Feb 3 19:46:44 2022 +0100
    Add script based upgrade testing in check_all_upgrades
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 20e96f8ee..ace5ad351 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -1,7 +1,6 @@
 #!/bin/sh
 EXIT_ON_FIRST_FAILURE=0
-BUILDDIR=$PWD
 EXTDIR=`pg_config --sharedir`/extension/
 CTBDIR=`pg_config --sharedir`/contrib/
 TMPDIR=/tmp/check_all_upgrades-$$-tmp
@@ -9,6 +8,12 @@ PGVER=`pg_config --version | awk '{print $2}'`
 PGVER_MAJOR=$(echo "${PGVER}" | sed 's/\.[^\.]*//')
 echo "INFO: PostgreSQL version: ${PGVER} [${PGVER_MAJOR}]"
+BUILDDIR=$PWD # TODO: allow override ?
+cd $(dirname $0)/..
+SRCDIR=$PWD # TODO: allow override ?
+cd -
 if test "$1" = "-s"; then
   EXIT_ON_FIRST_FAILURE=1
@@ -208,6 +213,30 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
   done
+  # Check unpackaged->unpackaged upgrades
+  CURRENTVERSION=`grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | paste -sd '.'`
+  if test ${to_version} = "${CURRENTVERSION}"; then
+    for majmin in `'ls' -d ${CTBDIR}/postgis-* | sed 's/.*postgis-//'`
+    do #{
+      UPGRADE_PATH="unpackaged${majmin}--:auto"
+      test_label="${EXT} script-based upgrade ${UPGRADE_PATH}"
+      if expr $to_version_param : ':auto' >/dev/null; then
+        test_label="${test_label} ($to_version)"
+      fi
+      compatible_upgrade "${test_label}" ${majmin} ${to_version} || continue
+      echo "Testing ${test_label}"
+      RUNTESTFLAGS="-v --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
+      make -C ${REGDIR} check && {
+        echo "PASS: ${EXT} script-based upgrade $UPGRADE_PATH"
+        echo "FAIL: ${EXT} script-based upgrade $UPGRADE_PATH"
+        failed
+    done #}
+  else #}{
+    echo "SKIP: ${EXT} script-based upgrades (${to_version_param} [${to_version}] does not match built version ${CURRENTVERSION})"
+  fi #}
 done
 exit $failures
commit d59be353157fd3944779c7291cf1fb2d5334453e
Date:   Thu Feb 3 14:40:59 2022 +0100
    Add test for views using ST_ClusterKMeans on upgrade
    References #5080
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index 0ca56e675..7f95eb762 100644
--- a/regress/hooks/hook-after-upgrade.sql
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -5,6 +5,7 @@ DROP VIEW IF EXISTS upgrade_view_test_union;
 DROP VIEW IF EXISTS upgrade_view_test_force_dims;
 DROP VIEW IF EXISTS upgrade_view_test_askml;
 DROP VIEW IF EXISTS upgrade_view_test_dwithin;
+DROP VIEW IF EXISTS upgrade_view_test_clusterkmeans;
 DROP TABLE upgrade_test;
 -- Drop functions deprecated on upgrade
@@ -21,3 +22,4 @@ DROP FUNCTION IF EXISTS st_askml_deprecated_by_postgis_200(geometry,integer);
 DROP FUNCTION IF EXISTS st_askml_deprecated_by_postgis_200(geography,integer);
 DROP FUNCTION IF EXISTS st_dwithin_deprecated_by_postgis_300(geography,geography,float8);
 DROP FUNCTION IF EXISTS st_dwithin_deprecated_by_postgis_300(text,text,float8);
+DROP FUNCTION IF EXISTS st_clusterkmeans_deprecated_by_postgis_302(geometry,integer);
diff --git a/regress/hooks/hook-before-upgrade.sql b/regress/hooks/hook-before-upgrade.sql
index 7185b56bc..f15b71111 100644
--- a/regress/hooks/hook-before-upgrade.sql
+++ b/regress/hooks/hook-before-upgrade.sql
@@ -75,6 +75,13 @@ SELECT
 	ST_DWithin(g2, g2, 1) as geography_dwithin
 FROM upgrade_test;
+-- Add view using ST_ClusterKMeans windowing function
+-- NOTE: 3.2.0 changed it to add max_radius parameter
+CREATE VIEW upgrade_view_test_clusterkmeans AS
+SELECT
+	ST_ClusterKMeans(g1, 1) OVER ()
+FROM upgrade_test;
 -- Break probin of all postgis functions, as we expect
 -- the upgrade procedure to replace them all
 UPDATE pg_proc SET probin = probin || '-uninstalled'
commit 8cc96d62a72f7356a9dbf90e412c0a5705cc1c9c
Date:   Thu Feb 3 15:52:18 2022 +0100
    Handle exception upon attempts to rewrite deprecated functions
    Closes #5080
    Also rewrite deprecated as wrappers only after trying to drop them
diff --git a/utils/postgis_proc_upgrade.pl b/utils/postgis_proc_upgrade.pl
index 62c28022e..a7fd59061 100755
--- a/utils/postgis_proc_upgrade.pl
+++ b/utils/postgis_proc_upgrade.pl
@@ -586,6 +586,8 @@ DO LANGUAGE 'plpgsql'
 \$postgis_proc_upgrade\$
 DECLARE
     deprecated_functions regprocedure[];
+    new_name TEXT;
+    rewrote_as_wrapper BOOLEAN;
     rec RECORD;
     extrec RECORD;
     procrec RECORD;
@@ -600,6 +602,8 @@ BEGIN
     WHERE proname = ANY ('${deprecated_names}'::name[])
     INTO deprecated_functions;
+    RAISE DEBUG 'Handling deprecated functions: %', deprecated_functions;
 --    -- Rewrite views using deprecated functions
 --    -- to improve the odds of being able to drop them
@@ -641,42 +645,13 @@ BEGIN
     FOR rec IN SELECT unnest(deprecated_functions) as proc
     LOOP --{
-        -- Rewrite the function as an SQL WRAPPER
-        SELECT pg_get_functiondef(oid) def, pronargs
-        FROM pg_proc WHERE oid = rec.proc
-        INTO procrec;
-        -- Force LANGUAGE to be SQL
-        sql := regexp_replace(procrec.def, 'LANGUAGE [^ \n]*', 'LANGUAGE sql');
-        --RAISE DEBUG 'SQL (LANGUAGE): %', sql;
-        -- Change body to be a wrapper
-            sql,
-			-- Find a stricted match here ?
-            'AS .*',
-            format(
-                -- TODO: have the function raise a warning too ?
-                'AS \$\$ SELECT %s(%s) \$\$',
-                regexp_replace(
-                    rec.proc::text,
-                    '_deprecated_by_postgis[^(]*\\(.*',
-                    SELECT array_to_string(
-                        array_agg('\$' || x),
-                    FROM generate_series(1, procrec.pronargs) x
+        RAISE DEBUG 'Handling deprecated function %', rec.proc;
-        RAISE DEBUG 'SQL: %', sql;
-        EXECUTE sql;
+        new_name := regexp_replace(
+            rec.proc::text,
+            '_deprecated_by_postgis[^(]*\\(.*',
         sql := format('DROP FUNCTION %s', rec.proc);
         --RAISE DEBUG 'SQL: %', sql;
@@ -690,13 +665,63 @@ BEGIN
                 hint = format(
                     'Replace the view changing all occurrences of %s in its definition with %s',
                     rec.proc,
-                    regexp_replace(rec.proc::text, '_deprecated_by_postgis[^(]*', '')
+                    new_name
             END IF;
             hint = hint || ' and upgrade again';
-            RAISE WARNING 'Deprecated function % left behind as a wrapper: %', rec.proc, SQLERRM
+            RAISE WARNING 'Deprecated function % left behind: %',
+                rec.proc, SQLERRM
             USING DETAIL = detail, HINT = hint;
+            -- Try to rewrite the function as an SQL WRAPPER
+            SELECT pg_get_functiondef(oid) def, pronargs
+            FROM pg_proc WHERE oid = rec.proc
+            INTO procrec;
+            -- TODO: don't even try if it's an aggregate or windowing
+            --       function (procrec.prokind)
+            -- TODO: don't even try if it's a scripting language function
+            -- Force LANGUAGE to be SQL
+            sql := regexp_replace(procrec.def, 'LANGUAGE [^ \n]*', 'LANGUAGE sql');
+            --RAISE DEBUG 'SQL (LANGUAGE): %', sql;
+            -- Change body to be a wrapper
+                sql,
+                -- Find a stricted match here ?
+                'AS .*',
+                format(
+                    -- TODO: have the function raise a warning too ?
+                    'AS \$\$ SELECT %s(%s) \$\$',
+                    new_name,
+                        SELECT array_to_string(
+                            array_agg('\$' || x),
+                        FROM generate_series(1, procrec.pronargs) x
+            RAISE DEBUG 'SQL: %', sql;
+            rewrote_as_wrapper := false;
+            BEGIN
+                EXECUTE sql;
+                rewrote_as_wrapper := true;
+            EXCEPTION
+            WHEN OTHERS THEN
+                RAISE WARNING
+                    'Deprecated function % could not be rewritten as a wrapper: % (%)',
+                    rec.proc, SQLERRM, SQLSTATE;
+            END;
             -- Drop the function from any extension it is part of
             -- so dump/reloads still work
             FOR extrec IN
Summary of changes:
 regress/hooks/hook-after-upgrade.sql  |  2 +
 regress/hooks/hook-before-upgrade.sql |  7 +++
 utils/check_all_upgrades.sh           | 31 ++++++++++-
 utils/postgis_proc_upgrade.pl         | 99 ++++++++++++++++++++++-------------
 4 files changed, 101 insertions(+), 38 deletions(-)
hooks/post-receive
