[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-506-g41b5824da
Mon Feb 7 12:13:35 PST 2022
the project "PostGIS".
       via  41b5824dabca28364a4e822c42123042a9329edb (commit)
      from  981fb9390891328a9d82f2731ef81101826a73b5 (commit)
revisions in full, below.
commit 41b5824dabca28364a4e822c42123042a9329edb
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon Feb 7 12:13:31 2022 -0800
    Add doc image generator arrow style
diff --git a/doc/html/image_src/generator.c b/doc/html/image_src/generator.c
index 97b325667..6ad1b04b8 100644
--- a/doc/html/image_src/generator.c
+++ b/doc/html/image_src/generator.c
@@ -135,6 +135,61 @@ drawPointSymbol(char *output, POINTARRAY *pa, unsigned int index, int size, char
 	return (ptr - output);
+ * Draws a point in a POINTARRAY to a char* using ImageMagick SVG for styling.
+ * @param output a char reference to write the LWPOINT to
+ * @param lwp a reference to a LWPOINT
+ * @return the numbers of character written to *output
+static size_t
+drawLineArrow(char *output, POINTARRAY *pa, int size, int strokeWidth, char* color)
+	// short-circuit no-op
+	if (size <= 0) return 0;
+	if (pa->npoints <= 1) return 0;
+	char s0x[OUT_DOUBLE_BUFFER_SIZE];
+	char s0y[OUT_DOUBLE_BUFFER_SIZE];
+	char s1x[OUT_DOUBLE_BUFFER_SIZE];
+	char s1y[OUT_DOUBLE_BUFFER_SIZE];
+	char s2x[OUT_DOUBLE_BUFFER_SIZE];
+	char s2y[OUT_DOUBLE_BUFFER_SIZE];
+	POINT2D pn;
+	getPoint2d_p(pa, pa->npoints-1, &pn);
+	POINT2D pn1;
+	getPoint2d_p(pa, pa->npoints-2, &pn1);
+	double dx = pn1.x - pn.x;
+	double dy = pn1.y - pn.y;
+	double len = sqrt(dx*dx + dy*dy);
+	//-- abort if final line segment has length 0
+	if (len <= 0) return 0;
+	double offx = -0.5 * size * dy/len;
+	double offy =  0.5 * size * dx/len;
+	double p1x = pn.x + size * dx / len + offx;
+	double p1y = pn.y + size * dy / len + offy;
+	double p2x = pn.x + size * dx / len - offx;
+	double p2y = pn.y + size * dy / len - offy;
+	lwprint_double(pn.x, 10, s0x);
+	lwprint_double(pn.y, 10, s0y);
+	lwprint_double(p1x,  10, s1x);
+	lwprint_double(p1y,  10, s1y);
+	lwprint_double(p2x,  10, s2x);
+	lwprint_double(p2y,  10, s2y);
+	char *ptr = output;
+	ptr += sprintf(ptr, "-fill %s -strokewidth %d ", color, 2);
+	ptr += sprintf(ptr, "-draw \"path 'M %s,%s %s,%s %s,%s %s,%s'\" ", s0x, s0y, s1x, s1y, s2x, s2y, s0x, s0y);
+	return (ptr - output);
  * Serializes a LWPOINT to a char*.  This is a helper function that partially
  * writes the appropriate draw and fill commands used to generate an SVG image
@@ -193,6 +248,7 @@ drawLineString(char *output, LWLINE *lwl, LAYERSTYLE *style)
 	ptr += drawPointSymbol(ptr, lwl->points, 0, style->lineStartSize, style->lineColor);
 	ptr += drawPointSymbol(ptr, lwl->points, lwl->points->npoints-1, style->lineEndSize, style->lineColor);
+	ptr += drawLineArrow(ptr, lwl->points, style->lineArrowSize, style->lineWidth, style->lineColor);
diff --git a/doc/html/image_src/st_linecrossingdirection01.wkt b/doc/html/image_src/st_linecrossingdirection01.wkt
index 64b080b24..d188a59b9 100644
--- a/doc/html/image_src/st_linecrossingdirection01.wkt
+++ b/doc/html/image_src/st_linecrossingdirection01.wkt
@@ -1,2 +1,2 @@
-ArgA;GEOMETRYCOLLECTION(LINESTRING(25 169,89 114,40 70,86 43), POINT(25 169),POLYGON((78.26 40.98,83.98 50.74,86 43,78.26 40.98)) )
-ArgB;GEOMETRYCOLLECTION(LINESTRING(171 154,20 140,71 74,161 53),POINT(171 154),POLYGON((153.15 48.12,156.12 60.85,161 53,153.15 48.12)) )
+ArgA-arrow;LINESTRING(25 169,89 114,40 70,86 43)
+ArgB-arrow;LINESTRING(171 154,20 140,71 74,161 53)
diff --git a/doc/html/image_src/st_linecrossingdirection02.wkt b/doc/html/image_src/st_linecrossingdirection02.wkt
index f26dcf2f5..a9b31dffd 100644
--- a/doc/html/image_src/st_linecrossingdirection02.wkt
+++ b/doc/html/image_src/st_linecrossingdirection02.wkt
@@ -1,2 +1,2 @@
-ArgA;GEOMETRYCOLLECTION(LINESTRING(25 169,89 114,40 70,86 43), POINT(25 169), POLYGON((80.84 41.66,84.66 48.16,86 43,80.84 41.66)) )
-ArgB;GEOMETRYCOLLECTION(LINESTRING(171 154, 20 140, 71 74, 2.99 90.16),POINT(171 154),POLYGON((6.66 84.21,2.99 90.16,8.94 93.83,6.66 84.21)) )
+ArgA-arrow;LINESTRING(25 169,89 114,40 70, 86 43)
+ArgB-arrow;LINESTRING(171 154, 20 140, 71 74, 2.99 90)
diff --git a/doc/html/image_src/st_linecrossingdirection03.wkt b/doc/html/image_src/st_linecrossingdirection03.wkt
index 072ce4dc3..9987afd2b 100644
--- a/doc/html/image_src/st_linecrossingdirection03.wkt
+++ b/doc/html/image_src/st_linecrossingdirection03.wkt
@@ -1,2 +1,2 @@
-ArgA;GEOMETRYCOLLECTION(LINESTRING(25 169,89 114,40 70,86 43), POINT(25 169), POLYGON((78.26 40.98,83.98 50.74,86 43,78.26 40.98)) )
-ArgB;GEOMETRYCOLLECTION(LINESTRING (20 140, 71 74, 161 53), POINT(20 140), POLYGON ((153.15 48.12, 156.12 60.85, 161 53, 153.15 48.12)))
+ArgB-arrow;LINESTRING (20 140, 71 74, 161 53)
diff --git a/doc/html/image_src/st_linecrossingdirection04.wkt b/doc/html/image_src/st_linecrossingdirection04.wkt
index b46305346..cbd0ac7ac 100644
--- a/doc/html/image_src/st_linecrossingdirection04.wkt
+++ b/doc/html/image_src/st_linecrossingdirection04.wkt
@@ -1,2 +1,2 @@
-ArgB;GEOMETRYCOLLECTION(LINESTRING(5 90,71 74,20 140,171 154),POINT(5 90),POLYGON((159.33 163.69,171 154,161.31 142.33,159.33 163.69)) )
+ArgB-arrow;LINESTRING(5 90,71 74,20 140,171 154)
diff --git a/doc/html/image_src/styles.c b/doc/html/image_src/styles.c
index 0a6fd1acf..ae07860d7 100644
--- a/doc/html/image_src/styles.c
+++ b/doc/html/image_src/styles.c
@@ -48,6 +48,7 @@ getStyles( const char *filename, LAYERSTYLE **headRef )
 			char *lineColor = "Grey";
 			int lineStartSize = 0;
 			int lineEndSize = 0;
+			int lineArrowSize = 0;
 			char *polygonFillColor = "Grey";
 			char *polygonStrokeColor = "Grey";
 			int polygonStrokeWidth = 0;
@@ -93,6 +94,11 @@ getStyles( const char *filename, LAYERSTYLE **headRef )
 						lineEndSize = atoi(ptr);
 						free(ptr);
+					else if (strncmp(line, "lineArrowSize", 3) == 0)
+						lineArrowSize = atoi(ptr);
+						free(ptr);
 					else if (strncmp(line, "polygonFillColor", 16) == 0)
 						polygonFillColor = ptr;
 					else if (strncmp(line, "polygonStrokeColor", 18) == 0)
@@ -106,7 +112,7 @@ getStyles( const char *filename, LAYERSTYLE **headRef )
 				getResults = fgets ( line, sizeof line, pFile );
 			addStyle(headRef, styleName, pointSize, pointColor,
-				lineWidth, lineColor, lineStartSize, lineEndSize,
+				lineWidth, lineColor, lineStartSize, lineEndSize, lineArrowSize,
 				polygonFillColor, polygonStrokeColor, polygonStrokeWidth);
@@ -143,7 +149,7 @@ addStyle(
     char* styleName,
     int pointSize, char* pointColor,
     int lineWidth, char* lineColor,
-	int lineStartSize, int lineEndSize,
+	int lineStartSize, int lineEndSize, int lineArrowSize,
     char* polygonFillColor, char* polygonStrokeColor, int polygonStrokeWidth)
 	LAYERSTYLE *style = malloc( sizeof(LAYERSTYLE) );
@@ -155,6 +161,7 @@ addStyle(
 	style->lineColor = lineColor;
 	style->lineStartSize = lineStartSize;
 	style->lineEndSize = lineEndSize;
+	style->lineArrowSize = lineArrowSize;
 	style->polygonFillColor = polygonFillColor;
 	style->polygonStrokeColor = polygonStrokeColor;
 	style->polygonStrokeWidth = polygonStrokeWidth;
diff --git a/doc/html/image_src/styles.conf b/doc/html/image_src/styles.conf
index e7e7d0875..20df8d2e8 100644
--- a/doc/html/image_src/styles.conf
+++ b/doc/html/image_src/styles.conf
@@ -64,6 +64,18 @@ polygonFillColor = "#C0D0F080"
 polygonStrokeColor = "#6495ED"
 polygonStrokeWidth = 2
+[Style]
+styleName = ArgA-arrow
+pointSize = 5
+pointColor = "#6495ED"
+lineWidth = 4
+lineColor = "#6495ED"
+lineStartSize = 5
+lineArrowSize = 10
+polygonFillColor = "#C0D0F080"
+polygonStrokeColor = "#6495ED"
+polygonStrokeWidth = 2
 [Style]
 # Argument B
 styleName = ArgB
@@ -99,6 +111,18 @@ polygonFillColor = "#00ffa040"
 polygonStrokeColor = "#7ACAC4"
+[Style]
+styleName = ArgB-arrow
+pointSize = 5
+pointColor = "#7ACAC4"
+lineWidth = 4
+lineColor = "#7ACAC4"
+lineStartSize = 5
+lineArrowSize = 10
+polygonFillColor = "#00ffa040"
+polygonStrokeColor = "#7ACAC4"
 [Style]
 # Result
 styleName = Result
diff --git a/doc/html/image_src/styles.h b/doc/html/image_src/styles.h
index cf1688d35..fff87ad1e 100644
--- a/doc/html/image_src/styles.h
+++ b/doc/html/image_src/styles.h
@@ -28,6 +28,7 @@ struct layerStyle
 	int   lineStartSize;
 	int   lineEndSize;
+	int   lineArrowSize;
 	char *polygonFillColor;
 	char *polygonStrokeColor;
@@ -38,7 +39,9 @@ struct layerStyle
 void getStyles( const char *filename, LAYERSTYLE **headRef );
 void freeStyles( LAYERSTYLE **headRef );
-void addStyle( LAYERSTYLE **headRef, char* styleName, int pointSize, char* pointColor, int lineWidth, char* lineColor, int lineStartSize, int lineEndSize, char* polygonFillColor, char* polygonStrokeColor, int polygonStrokeWidth );
+void addStyle( LAYERSTYLE **headRef, char* styleName, int pointSize, char* pointColor,
+	int lineWidth, char* lineColor, int lineStartSize, int lineEndSize, int lineArrowSize,
+	char* polygonFillColor, char* polygonStrokeColor, int polygonStrokeWidth );
 int length( LAYERSTYLE *headRef );
 LAYERSTYLE* getStyle( LAYERSTYLE *headRef, char* styleName );
Summary of changes:
 doc/html/image_src/generator.c                    | 56 +++++++++++++++++++++++
 doc/html/image_src/st_linecrossingdirection01.wkt |  4 +-
 doc/html/image_src/st_linecrossingdirection02.wkt |  4 +-
 doc/html/image_src/st_linecrossingdirection03.wkt |  4 +-
 doc/html/image_src/st_linecrossingdirection04.wkt |  4 +-
 doc/html/image_src/styles.c                       | 11 ++++-
 doc/html/image_src/styles.conf                    | 24 ++++++++++
 doc/html/image_src/styles.h                       |  5 +-
 8 files changed, 101 insertions(+), 11 deletions(-)
hooks/post-receive
