[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-507-g1052dfb9f
Mon Feb 7 14:19:15 PST 2022
the project "PostGIS".
       via  1052dfb9f689a8cca8ba038a00bf9377846df1cb (commit)
      from  41b5824dabca28364a4e822c42123042a9329edb (commit)
revisions in full, below.
commit 1052dfb9f689a8cca8ba038a00bf9377846df1cb
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon Feb 7 14:19:10 2022 -0800
    Add doc ST_PointOnSurface images
diff --git a/doc/html/image_src/Makefile.in b/doc/html/image_src/Makefile.in
index fb4bf5cb2..0ac0a1359 100644
--- a/doc/html/image_src/Makefile.in
+++ b/doc/html/image_src/Makefile.in
@@ -128,6 +128,11 @@ IMAGES= \
 	../images/st_overlaps04.png \
 	../images/st_overlaps05.png \
 	../images/st_overlaps06.png \
+	../images/st_pointonsurface.png \
+	../images/st_pointonsurface01.png \
+	../images/st_pointonsurface02.png \
+	../images/st_pointonsurface03.png \
+	../images/st_pointonsurface04.png \
 	../images/st_sharedpaths01.png \
 	../images/st_sharedpaths02.png \
 	../images/st_shortestline01.png \
diff --git a/doc/html/image_src/st_pointonsurface.wkt b/doc/html/image_src/st_pointonsurface.wkt
new file mode 100644
index 000000000..9d3d39c64
--- /dev/null
+++ b/doc/html/image_src/st_pointonsurface.wkt
@@ -0,0 +1,3 @@
+ArgA;POLYGON ((130 120, 120 190, 30 140, 50 20, 190 20, 170 100, 90 60, 90 130, 130 120))
+ArgB;POINT(100.18264840182648 85.11415525114155)
+Result;POINT(62.5 110)
diff --git a/doc/html/image_src/st_pointonsurface01.wkt b/doc/html/image_src/st_pointonsurface01.wkt
index 000000000..31107ae73
--- /dev/null
+++ b/doc/html/image_src/st_pointonsurface01.wkt
@@ -0,0 +1,2 @@
+ArgA;MULTIPOINT ( 8 24, 10 92, 12 154, 17 68, 28 10, 29 52, 29 84, 55 50, 56 24, 131 14, 160 180, 189 180 )
+Result;POINT (55 50)
diff --git a/doc/html/image_src/st_pointonsurface02.wkt b/doc/html/image_src/st_pointonsurface02.wkt
index 000000000..3f90ea9d8
--- /dev/null
+++ b/doc/html/image_src/st_pointonsurface02.wkt
@@ -0,0 +1,2 @@
+ArgA;LINESTRING ( 190 160, 10 190, 40 90, 20 70, 10 10, 30 40, 30 10, 110 40, 70 10, 110 10, 140 40, 140 10, 160 30, 180 10 )
+Result;POINT (40 90)
diff --git a/doc/html/image_src/st_pointonsurface03.wkt b/doc/html/image_src/st_pointonsurface03.wkt
index 000000000..56a8ec3b7
--- /dev/null
+++ b/doc/html/image_src/st_pointonsurface03.wkt
@@ -0,0 +1,2 @@
+ArgA;POLYGON (( 190 190, 10 190, 10 10, 190 10, 190 20, 160 30, 60 30, 60 130, 190 140, 190 190 ))
+Result;POINT (35 80)
diff --git a/doc/html/image_src/st_pointonsurface04.wkt b/doc/html/image_src/st_pointonsurface04.wkt
index 000000000..2565b4533
--- /dev/null
+++ b/doc/html/image_src/st_pointonsurface04.wkt
@@ -0,0 +1,2 @@
+ArgA;GEOMETRYCOLLECTION ( POLYGON (( 190 170, 180 100, 80 140, 80 160, 130 160, 110 180, 110 190, 180 180, 190 170 )), LINESTRING ( 80 120, 120 20, 140 70, 150 30, 180 50, 190 10 ), MULTIPOINT ( 19 150, 22 49, 30 13, 32 101, 45 35, 67 88, 75 16 ))
+Result;POINT (133.57142857142856 150)
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 01a87f85c..eacb8d493 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -525,7 +525,7 @@ FROM (SELECT
     <refsection>
       <title>Examples</title>
-      <para>In the following illustrations the green dot is
+      <para>In the following illustrations the red dot is
       the centroid of the source geometry.</para>
       <informaltable>
@@ -1764,26 +1764,101 @@ MULTILINESTRING((164 1,11.7867965644036 1,1 11.7867965644036,1 195),
       <refsection>
+      <informaltable>
+        <tgroup cols="2">
+          <tbody>
+            <row>
+              <entry><para><informalfigure>
+                  <mediaobject>
+                    <imageobject>
+                      <imagedata fileref="images/st_pointonsurface01.png" />
+                    </imageobject>
+                    <caption><para>PointOnSurface of a
+                    <varname>MULTIPOINT</varname></para></caption>
+                  </mediaobject>
+                </informalfigure></para></entry>
+                  <mediaobject>
+                    <imageobject>
+                      <imagedata fileref="images/st_pointonsurface02.png" />
+                    </imageobject>
+                    <varname>LINESTRING</varname></para></caption>
+                  </mediaobject>
+            </row>
+            <row>
+                  <mediaobject>
+                    <imageobject>
+                      <imagedata fileref="images/st_pointonsurface03.png" />
+                    </imageobject>
+                    <varname>POLYGON</varname></para></caption>
+                  </mediaobject>
+                  <mediaobject>
+                    <imageobject>
+                      <imagedata fileref="images/st_pointonsurface04.png" />
+                    </imageobject>
+                    <varname>GEOMETRYCOLLECTION</varname></para></caption>
+                  </mediaobject>
+            </row>
+          </tbody>
+        </tgroup>
+      </informaltable>
         <programlisting>SELECT ST_AsText(ST_PointOnSurface('POINT(0 5)'::geometry));
- st_astext
  POINT(0 5)
 SELECT ST_AsText(ST_PointOnSurface('LINESTRING(0 5, 0 10)'::geometry));
- st_astext
  POINT(0 5)
 SELECT ST_AsText(ST_PointOnSurface('POLYGON((0 0, 0 5, 5 5, 5 0, 0 0))'::geometry));
-   st_astext
  POINT(2.5 2.5)
 SELECT ST_AsEWKT(ST_PointOnSurface(ST_GeomFromEWKT('LINESTRING(0 5 1, 0 0 1, 0 10 2)')));
-   st_asewkt
  POINT(0 0 1)
 </programlisting>
+        <para><emphasis role="bold">Example:</emphasis>
+        The result of ST_PointOnSurface is guaranteed to lie within polygons,
+        whereas the point computed by <xref linkend="ST_Centroid" /> may be outside.
+        </para>
+        <informalfigure>
+            <mediaobject>
+                <imageobject>
+                <imagedata fileref="images/st_pointonsurface.png" />
+                </imageobject>
+                <caption><para>Red: point on surface; Green: centroid</para></caption>
+            </mediaobject>
+            </informalfigure>
+<programlisting>
+SELECT ST_AsText(ST_PointOnSurface(geom)) AS pt_on_surf,
+       ST_AsText(ST_Centroid(geom)) AS centroid
+    FROM (SELECT 'POLYGON ((130 120, 120 190, 30 140, 50 20, 190 20,
+                      170 100, 90 60, 90 130, 130 120))'::geometry AS geom) AS t;
+   pt_on_surf    |                  centroid
+ POINT(62.5 110) | POINT(100.18264840182648 85.11415525114155)
+</programlisting>
       </refsection>
       <refsection>
Summary of changes:
 doc/html/image_src/Makefile.in                     |  5 ++
 doc/html/image_src/st_pointonsurface.wkt           |  3 +
 .../{st_centroid01.wkt => st_pointonsurface01.wkt} |  2 +-
 .../{st_centroid02.wkt => st_pointonsurface02.wkt} |  2 +-
 ...aightskeleton01.wkt => st_pointonsurface03.wkt} |  1 +
 .../{st_centroid04.wkt => st_pointonsurface04.wkt} |  2 +-
 doc/reference_processing.xml                       | 85 ++++++++++++++++++++--
 7 files changed, 92 insertions(+), 8 deletions(-)
 create mode 100644 doc/html/image_src/st_pointonsurface.wkt
 copy doc/html/image_src/{st_centroid01.wkt => st_pointonsurface01.wkt} (69%)
 copy doc/html/image_src/{st_centroid02.wkt => st_pointonsurface02.wkt} (72%)
 copy doc/html/image_src/{st_straightskeleton01.wkt => st_pointonsurface03.wkt} (82%)
 copy doc/html/image_src/{st_centroid04.wkt => st_pointonsurface04.wkt} (83%)
hooks/post-receive
