[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-605-gb6fadaf4e
Fri Feb 25 01:19:01 PST 2022
the project "PostGIS".
       via  b6fadaf4ece60d5143f2fe88bb66e26986be4687 (commit)
      from  e3d6a2357286acb4cc5e52c77b1e7e82e00bc00c (commit)
revisions in full, below.
commit b6fadaf4ece60d5143f2fe88bb66e26986be4687
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Feb 25 10:18:08 2022 +0100
    Stop automatically configuring on top-level make
    References #5103
diff --git a/Makefile b/Makefile
index d27eefbe2..db75fbe81 100644
--- a/Makefile
+++ b/Makefile
@@ -2,7 +2,12 @@
 # this file copied and adapted from PostgreSQL source
 # to allow easy build on BSD systems
-all install uninstall staged-install clean distclean maintainer-clean test check docs docs-install docs-uninstall utils: build/GNUmakefile
+all install uninstall staged-install clean distclean maintainer-clean test check docs docs-install docs-uninstall utils:
+	@if [ ! -f GNUmakefile ] ; then \
+		echo "You need to run the 'configure' program first. See the file"; \
+		echo "'README.postgis' for installation instructions" ; \
+		false ; \
+	fi
 	@IFS=':' ; \
 	 for dir in $$PATH; do \
 	   for prog in gmake gnumake make; do \
@@ -15,17 +20,8 @@ all install uninstall staged-install clean distclean maintainer-clean test check
 	 if [ x"$${GMAKE+set}" = xset ]; then \
 	   echo "Using GNU make found at $${GMAKE}"; \
-	   $${GMAKE} -C build/ $@ ; \
+	   $${GMAKE} $@ ; \
 	 else \
 	   echo "You must use GNU make to build PostGIS." ; \
 	   false; \
 	 fi
-configure: configure.ac
-	./autogen.sh
-build-dir:
-	mkdir -p build
-build/GNUmakefile: configure build-dir
-	cd build && ../configure
Summary of changes:
 Makefile | 18 +++++++-----------
 1 file changed, 7 insertions(+), 11 deletions(-)
hooks/post-receive
