[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-606-g62e5bf117
Fri Feb 25 01:30:07 PST 2022
the project "PostGIS".
       via  62e5bf1177595eee23190fc4be4ad6011778f0c7 (commit)
      from  b6fadaf4ece60d5143f2fe88bb66e26986be4687 (commit)
revisions in full, below.
commit 62e5bf1177595eee23190fc4be4ad6011778f0c7
Author: sergei sh <managerzf168 at gmail.com>
Date:   Thu Feb 24 02:06:29 2022 +0300
    Allowing archiver program and flags options in ./configure
diff --git a/configure.ac b/configure.ac
index 2603299e7..586d5da3a 100644
--- a/configure.ac
+++ b/configure.ac
@@ -26,6 +26,8 @@ AC_CONFIG_MACRO_DIR([macros])
 AC_CONFIG_AUX_DIR([build-aux])
 AC_PROG_INSTALL
+# Set default AR_FLAGS before libtool does
+: ${AR_FLAGS=rs}
 dnl Invoke libtool: we do this as it is the easiest way to find the PIC
 dnl flags required to build liblwgeom
@@ -62,7 +64,7 @@ AC_SUBST([SQLPP])
 dnl
 dnl Silence warning: ar: 'u' modifier ignored since 'D' is the default
 dnl
-AC_SUBST(AR_FLAGS, [cr])
+AC_ARG_VAR(AR_FLAGS, [Archiver flags])
 dnl
 dnl Define PIC flags in PICFLAGS (note: this variable is set as part of libtool initialisation above)
@@ -1758,6 +1760,7 @@ fi
 AC_MSG_RESULT([  CPPFLAGS:             $CPPFLAGS])
 AC_MSG_RESULT([  LDFLAGS:              $LDFLAGS])
 AC_MSG_RESULT([  SQL preprocessor:     ${SQLPP}])
+AC_MSG_RESULT([  Archiver:             $AR $AR_FLAGS])
 AC_MSG_RESULT()
 AC_MSG_RESULT([ -------------- Additional Info ------------- ])
 if test "x$LIBINCLUDEMINORVERSION" = "xyes"; then
diff --git a/deps/flatgeobuf/Makefile.in b/deps/flatgeobuf/Makefile.in
index 17e35b556..2510cad89 100644
--- a/deps/flatgeobuf/Makefile.in
+++ b/deps/flatgeobuf/Makefile.in
@@ -50,7 +50,7 @@ FLATGEOBUF_HEADERS = \
 all: @FLATGEOBUF_LIB@
 @FLATGEOBUF_LIB@: $(FLATGEOBUF_OBJS)
-	ar rs @FLATGEOBUF_LIB@ $(FLATGEOBUF_OBJS)
+	@AR@ @AR_FLAGS@ @FLATGEOBUF_LIB@ $(FLATGEOBUF_OBJS)
 $(FLATGEOBUF_OBJS): %.o: %.cpp ../../liblwgeom/liblwgeom.h $(FLATGEOBUF_HEADERS)
 	$(CXX) $(CXXFLAGS) -c -o $@ $<
diff --git a/deps/wagyu/Makefile.in b/deps/wagyu/Makefile.in
index 98b5cb76d..348b4bedd 100644
--- a/deps/wagyu/Makefile.in
+++ b/deps/wagyu/Makefile.in
@@ -84,7 +84,7 @@ WAGYU_HEADERS = \
 all: @WAGYU_LIB@
 @WAGYU_LIB@: $(WAGYU_OBJS)
-	ar rs @WAGYU_LIB@ $(WAGYU_OBJS)
+	@AR@ @AR_FLAGS@ @WAGYU_LIB@ $(WAGYU_OBJS)
 $(WAGYU_OBJS): %.o: %.cpp ../../liblwgeom/liblwgeom.h $(WAGYU_HEADERS)
diff --git a/libpgcommon/Makefile.in b/libpgcommon/Makefile.in
index fb66c6895..b99b02c89 100644
--- a/libpgcommon/Makefile.in
+++ b/libpgcommon/Makefile.in
@@ -43,7 +43,7 @@ all: libpgcommon.a
 install uninstall:
 libpgcommon.a: $(SA_OBJS) $(SA_HEADERS)
-	ar rs libpgcommon.a $(SA_OBJS)
+	@AR@ @AR_FLAGS@ libpgcommon.a $(SA_OBJS)
 maintainer-clean: clean
diff --git a/raster/rt_core/Makefile.in b/raster/rt_core/Makefile.in
index 385ff9b26..9680ef9a0 100644
--- a/raster/rt_core/Makefile.in
+++ b/raster/rt_core/Makefile.in
@@ -23,7 +23,7 @@ top_srcdir = @top_srcdir@
 builddir = @builddir@
 top_builddir = @top_builddir@
-AR = ar rs
+AR = @AR@ @AR_FLAGS@
 CC = @CC@
 LIBLWGEOM_LDFLAGS = $(top_builddir)/liblwgeom/.libs/liblwgeom.a
Summary of changes:
 configure.ac                | 5 ++++-
 deps/flatgeobuf/Makefile.in | 2 +-
 deps/wagyu/Makefile.in      | 2 +-
 libpgcommon/Makefile.in     | 2 +-
 raster/rt_core/Makefile.in  | 2 +-
 5 files changed, 8 insertions(+), 5 deletions(-)
hooks/post-receive
