[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta1-2-ga887aab94
Sun Jul 3 10:05:00 PDT 2022
the project "PostGIS".
       via  a887aab94446e935112c645ef94027cf28373056 (commit)
      from  93f00ef7ef1ca1b34fcf55b8c79bdf54faed8150 (commit)
revisions in full, below.
commit a887aab94446e935112c645ef94027cf28373056
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Jul 3 13:04:22 2022 -0400
    Adjustments to winnie's scripts, and how to release
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index 0d8745185..45ca83e3a 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -123,9 +123,9 @@ Release procedure
   - PostGIS doc release versioned doc - http://postgis.net/documentation/
     - On postgis.net server, change /etc/nginx/sites-enabled/postgis.net (Versionless URL line )
-         - nginx -t #to confirm you didn't breat the config
+         - nginx -t #to confirm you didn't break the config
          - service nginx reload
-      Verify the documentation is up to date (might need to change the apache config)
+      Verify the documentation is up to date (might need to change the nginx config)
   - Post on website:
       - https://git.osgeo.org/gitea/postgis/postgis.net/src/branch/website/config/_default/params.toml#L132
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index 12760b45a..336b21087 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -73,11 +73,9 @@ export PGUSER=postgres
 export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
 export PGPATHEDB=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}edb
-export POSTGIS_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
-export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}
 if [ -n "$SOURCE_FOLDER" ]; then
   export POSTGIS_SRC=${PROJECTS}/postgis/$SOURCE_FOLDER
+  cd ${POSTGIS_SRC}
 else
   if [[ "$POSTGIS_MICRO_VERSION"  == *SVN* || "$POSTGIS_MICRO_VERSION"  == *dev* ]] ; then
     export POSTGIS_SRC=${PROJECTS}/postgis/branches/${POSTGIS_VER}
@@ -87,6 +85,10 @@ else
   fi;
 fi;
+export POSTGIS_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
+export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}
 #export POSTGIS_SRC=${PROJECTS}/postgis/trunk
 export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index 612ed763a..886ccf1a5 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -5,9 +5,7 @@
 #export OS_BUILD=64
 #export PGPORT=8442
-POSTGIS_MAJOR_VERSION=`grep ^POSTGIS_MAJOR_VERSION Version.config | cut -d= -f2`
-POSTGIS_MINOR_VERSION=`grep ^POSTGIS_MINOR_VERSION Version.config | cut -d= -f2`
-POSTGIS_MICRO_VERSION=`grep ^POSTGIS_MICRO_VERSION Version.config | cut -d= -f2`
 #export OS_BUILD=32
 #export GCC_TYPE=
@@ -89,15 +87,21 @@ echo PATH BEFORE: $PATH
 export PGPATHEDB=${PGPATH}edb
 #export PROJSO=libproj-13.dll
-export POSTGIS_MINOR_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
-echo "Version: $POSTGIS_MICRO_VER"
+	cd $POSTGIS_SRC
 fi
+export POSTGIS_MAJOR_VERSION=`grep ^POSTGIS_MAJOR_VERSION Version.config | cut -d= -f2`
+export POSTGIS_MINOR_VERSION=`grep ^POSTGIS_MINOR_VERSION Version.config | cut -d= -f2`
+export POSTGIS_MICRO_VERSION=`grep ^POSTGIS_MICRO_VERSION Version.config | cut -d= -f2`
+export POSTGIS_MINOR_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
+echo "Version: $POSTGIS_MICRO_VER"
 #POSTGIS_SVN_REVISION=will_be_passed_in_by_bot
@@ -128,11 +132,7 @@ mkdir $outdir/bin/postgisgui/share
 mkdir $outdir/bin/postgisgui/lib
 mkdir $outdir/utils
 cp ${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll  $outdir/bin/postgisgui
-# it seems 9.2 and 9.3 doesn't come with its own libiconv good grief
-# and trying to use their libiconv2.dll makes shp2pgsql crash
-if [[ "$PG_VER" == *9.2* || "$PG_VER" == *9.3* ]]; then
-	cp ${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin/*.dll  $outdir/bin
-fi;
 cp ${PGPATHEDB}/bin/libpq.dll  $outdir/bin/postgisgui
 #cp ${PGPATHEDB}/bin/libiconv2.dll  $outdir/bin/postgisgui
 cp ${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin/libicon*.dll $outdir/bin/postgisgui
@@ -170,19 +170,16 @@ cp -p ${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/
 #for protobuf
 cp ${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin/libprotobuf-c-*.dll $outdir/bin
-echo "POSTGIS: ${POSTGIS_MINOR_VER} r${POSTGIS_SVN_REVISION} http://postgis.net/source" > $verfile
+echo "POSTGIS: ${POSTGIS_MICRO_VER} http://postgis.net/source" > $verfile
 if [ "$POSTGIS_MAJOR_VERSION" > "1" ] ; then
   ## only copy gdal components if 2+.  1.5 doesn't have raster support
   cp -p ${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
   cp -rp  ${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal $outdir/gdal-data
-  if [ "$POSTGIS_MINOR_VERSION" > "0" ] ; then
-    ## only copy pagc standardizer components for 2.1+
-    cp -p ${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/bin/libpcre-1*.dll $outdir/bin
-    # cp -p ${PGPATH}/share/extension/address*.* $outdir/share/extension
-    # cp -p ${PGPATH}/share/extension/us-*.sql $outdir/share/extension
-  fi;
+	# needed for address standardizer
+  cp -p ${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/bin/libpcre-1*.dll $outdir/bin
 fi;
 if [ -n "$SFCGAL_VER"  ]; then
@@ -312,6 +309,8 @@ fi
 #echo "PAGC ADDRESS STANDARDIZER: http://sourceforge.net/p/pagc/code/HEAD/tree/branches/sew-refactor/postgresql " >> $verfile
 cd ${RELDIR}
 zip -r $package ${RELVERDIR}
+md5sum $package > ${package}.md5
 #scp $package robe at www.refractions.net:${DWN}/${REL_PGVER}/buildbot/${RELVERDIR}.zip
 cp $package ${PROJECTS}/postgis/win_web/download/windows/pg${REL_PGVER}/buildbot
+cp ${package}.md5 ${PROJECTS}/postgis/win_web/download/windows/pg${REL_PGVER}/buildbot
 cd ${POSTGIS_SRC}
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index f370a4bd3..b75f02f46 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -52,11 +52,6 @@ export PROJECTS=/projects
 export MINGPROJECTS=/projects
 export PATHOLD=$PATH
-echo "Version major minor micro: $POSTGIS_MAJOR_VERSION $POSTGIS_MINOR_VERSION $POSTGIS_MICRO_VERSION"
 if [ "$OS_BUILD" == "64" ] ; then
 	export MINGHOST=x86_64-w64-mingw32
 else
@@ -83,6 +78,7 @@ export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POS
+	cd $POSTGIS_SRC
 else
@@ -92,6 +88,11 @@ else
   fi;
 fi;
+echo "Version ${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}"
Summary of changes:
 HOWTO_RELEASE                |  4 ++--
 ci/winnie/build_postgis.sh   |  8 +++++---
 ci/winnie/package_postgis.sh | 37 ++++++++++++++++++-------------------
 ci/winnie/regress_postgis.sh | 11 ++++++-----
 4 files changed, 31 insertions(+), 29 deletions(-)
hooks/post-receive
