[postgis-tickets] [PostGIS] #5157: basic_test failure on i386
PostGIS trac at osgeo.org
Sun Jul 3 11:17:02 PDT 2022
  Reporter:  Bas Couwenberg  |      Owner:  strk
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.3.0
 Component:  liblwgeom       |    Version:  master
Resolution:                  |   Keywords:
Comment (by Bas Couwenberg):
 Still fails in 3.3.0beta1:
   Test: basic_test ...FAILED
     1. cu_minimum_bounding_circle.c:35  - CU_ASSERT_TRUE(d <=
 result->radius)
 Should we consider i386 no longer support and ignore test failures there?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5157#comment:3>
