[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta1-24-g3cfba082a
Mon Jul 11 20:12:08 PDT 2022
the project "PostGIS".
       via  3cfba082aa43170ef8fa80fc8b19199a21c953c8 (commit)
       via  f4cc2ca0d80991686b0c366bd82f5e8713b2a027 (commit)
      from  66a33ac75bd247cface0670a550c97d3b8963a97 (commit)
revisions in full, below.
commit 3cfba082aa43170ef8fa80fc8b19199a21c953c8
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Jul 11 23:11:53 2022 -0400
    Set all static bots to test --with-library-minor-version so we can in future better test upgrades
diff --git a/ci/berrie/postgis_regress.sh b/ci/berrie/postgis_regress.sh
index 0573fd589..cfdfe32af 100644
--- a/ci/berrie/postgis_regress.sh
+++ b/ci/berrie/postgis_regress.sh
@@ -16,7 +16,7 @@ echo $WORKSPACE
 sh autogen.sh
 ./configure --with-pgconfig=${PGPATH}/bin/pg_config \
   --with-geosconfig=${GEOS_PATH}/bin/geos-config \
-	--without-protobuf
+	--without-protobuf --with-library-minor-version
 #make clean
 make
 export err_status=0
diff --git a/ci/berrie64/postgis_regress.sh b/ci/berrie64/postgis_regress.sh
index f29c58752..dccbf5083 100644
--- a/ci/berrie64/postgis_regress.sh
+++ b/ci/berrie64/postgis_regress.sh
@@ -15,7 +15,7 @@ echo $PATH
 cd ${WORKSPACE}/PostGIS_Worker_Run/label/${label}/$BRANCH
 sh autogen.sh
-./configure --with-pgconfig=${PGPATH}/bin/pg_config --with-geosconfig=${GEOS_PATH}/bin/geos-config
+./configure --with-pgconfig=${PGPATH}/bin/pg_config --with-geosconfig=${GEOS_PATH}/bin/geos-config --with-library-minor-version
 #make clean
 make
 export err_status=0
diff --git a/ci/bessie/postgis_regress.sh b/ci/bessie/postgis_regress.sh
index b0ce03507..af4830daf 100644
--- a/ci/bessie/postgis_regress.sh
+++ b/ci/bessie/postgis_regress.sh
@@ -5,7 +5,7 @@ set -e
 #BRANCH is passed in via jenkins which is set via webhook hook
 export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
 sh autogen.sh
-./configure --with-projdir=/usr/local --with-libiconv=/usr/local --without-interrupt-tests
+./configure --with-projdir=/usr/local --with-libiconv=/usr/local --without-interrupt-tests --with-library-minor-version
 #make distclean
 make
 export PGUSER=postgres
diff --git a/ci/bessie32/postgis_regress.sh b/ci/bessie32/postgis_regress.sh
index 6dc12f108..c3295d421 100644
--- a/ci/bessie32/postgis_regress.sh
+++ b/ci/bessie32/postgis_regress.sh
@@ -10,7 +10,7 @@ CXXFLAGS="-O2 -pipe  -fstack-protector-strong -Wl,-rpath=/usr/local/lib/gcc8  -n
 CFLAGS="-Wall -Wmissing-prototypes -Wpointer-arith -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-trunc" \
 sh autogen.sh
 #make distclean
 make
diff --git a/ci/debbie/postgis_regress.sh b/ci/debbie/postgis_regress.sh
index 15191236e..79dca1d5f 100644
--- a/ci/debbie/postgis_regress.sh
+++ b/ci/debbie/postgis_regress.sh
@@ -66,7 +66,7 @@ fi
     --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
     --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config \
     --without-interrupt-tests \
-    --prefix=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}
+    --prefix=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD} --with-library-minor-version
 make clean
 make
commit f4cc2ca0d80991686b0c366bd82f5e8713b2a027
Date:   Mon Jul 11 23:06:59 2022 -0400
    Put back gcc settings for bessie32, but set to gcc11 which is the new installed after upgrade
index ee7820a59..6dc12f108 100644
@@ -4,11 +4,10 @@ set -e
 #export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
 sh autogen.sh
-#CC=gcc8   \
-#CXX=g++8 \
-#CXXFLAGS="-O2 -pipe  -fstack-protector-strong -Wl,-rpath=/usr/local/lib/gcc8  -nostdinc++ -isystem /usr/include/c++/v1 -Wl,-rpath=/usr/local/lib/gcc8" \
-#CFLAGS="-Wall -Wmissing-prototypes -Wpointer-arith -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-trunc" \
+CC=gcc11  \
+CXX=g++11 \
+CXXFLAGS="-O2 -pipe  -fstack-protector-strong -Wl,-rpath=/usr/local/lib/gcc8  -nostdinc++ -isystem /usr/include/c++/v1 -Wl,-rpath=/usr/local/lib/gcc11" \
+CFLAGS="-Wall -Wmissing-prototypes -Wpointer-arith -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-trunc" \
 sh autogen.sh
Summary of changes:
 ci/berrie/postgis_regress.sh   |  2 +-
 ci/berrie64/postgis_regress.sh |  2 +-
 ci/bessie/postgis_regress.sh   |  2 +-
 ci/bessie32/postgis_regress.sh | 11 +++++------
 ci/debbie/postgis_regress.sh   |  2 +-
 5 files changed, 9 insertions(+), 10 deletions(-)
hooks/post-receive
