[postgis-tickets] [PostGIS] #5184: bessie32 is failing after upgrade
PostGIS trac at osgeo.org
Fri Jul 22 12:15:26 PDT 2022
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  Website Management, Bots
 Component:  buildbots  |    Version:  3.2.x
Resolution:  fixed      |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Old description:
> Undefined symbol "_ZNSt8ios_base4InitD1Ev"
> Note this is also noted here -
> https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=262768
> I had upgraded the gcc, but I had also taken out some harded coded gcc8
> someone put in.  Perhaps it was to get around this issue.  I'll try
> putting it back with latest gcc. Strange that bessie (64-bit) never
> needed those settings.
New description:
 putting it back with latest gcc. Strange that bessie (64-bit) never needed
 those settings.
Comment:
 This is resolved thanks to Loïc Bartoletti's pull request
 https://git.osgeo.org/gitea/postgis/postgis/pulls/102
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5184#comment:1>
