[postgis-tickets] [PostGIS] #5150: postgis_extension_AddToSearchPath should take input as text instead of varchar, helpers should use CREATE FUNCTION
PostGIS trac at osgeo.org
Sun Jul 17 14:32:22 PDT 2022
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  assigned
  Priority:  medium                 |  Milestone:  PostGIS 2.5.7
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"7e6980e41bc978875cbfd884cfb851c7cbd458a2/git"
 7e6980e4/git]:
 {{{#!CommitTicketReference repository="git"
 revision="7e6980e41bc978875cbfd884cfb851c7cbd458a2"
 References #5150 - Change signature of AddToSearchPath
 References #5155, More schema qual fixes
 for PostGIS 2.5.7
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5150#comment:4>
