[postgis-tickets] [PostGIS] #5150: postgis_extension_AddToSearchPath should take input as text instead of varchar, helpers should use CREATE FUNCTION
PostGIS trac at osgeo.org
Sun Jul 17 15:42:50 PDT 2022
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.5.7
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"d5d3dfe8f558485cf63037601a5dc114ca21f4e1/git" d5d3dfe/git]:
 {{{#!CommitTicketReference repository="git"
 revision="d5d3dfe8f558485cf63037601a5dc114ca21f4e1"
 Search path and schema qual changes.  Closes #5150 Closes #5155 for
 PostGIS 3.0.6
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5150#comment:5>
