[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta2-8-gd624c45fe
Sat Jul 23 11:52:56 PDT 2022
the project "PostGIS".
       via  d624c45fe4941ae79f3a85e48d8eca54d676597f (commit)
      from  9591bf8933672a744b42bfb636fd0193472f425c (commit)
revisions in full, below.
commit d624c45fe4941ae79f3a85e48d8eca54d676597f
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Jul 23 14:42:47 2022 -0400
    1. Introduce a  &max_postgres_version; so we can use in docs in the
    multiple places it is needed
    2. Change docs where it says PostgreSQL &min_postgres_version; or higher to PostgreSQL
    &min_postgres_version; - &max_postgres_version;
diff --git a/doc/installation.xml b/doc/installation.xml
index 1058d1427..77b7eda72 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -44,7 +44,7 @@ in each individual database you want to use it in.
 	  The PostGIS module is an extension to the PostgreSQL backend server. As
 	  such, PostGIS &last_release_version; <emphasis>requires</emphasis> full
 	  PostgreSQL server headers access in order to compile. It can be built
-	  against PostgreSQL versions &min_postgres_version; or higher. Earlier
+	  against PostgreSQL versions &min_postgres_version; - &max_postgres_version;. Earlier
 	  versions of PostgreSQL are <emphasis>not</emphasis> supported.
 	</para>
@@ -133,7 +133,7 @@ tar -xvzf postgis-&last_release_version;.tar.gz</programlisting>
 	<itemizedlist>
 	  <listitem>
 		<para>
-		  PostgreSQL &min_postgres_version; or higher. A complete installation
+		  PostgreSQL &min_postgres_version; - &max_postgres_version;. A complete installation
 		  of PostgreSQL (including server headers) is required. PostgreSQL
 		  is available from
 		  <ulink url="http://www.postgresql.org">
@@ -241,7 +241,7 @@ tar -xvzf postgis-&last_release_version;.tar.gz</programlisting>
 	  <listitem>
 		<para>
-			SFCGAL, version 1.3.1 (or higher), 1.4.0 or higher is recommended. SFCGAL can be used to provide additional 2D and 3D advanced analysis functions to PostGIS cf <xref linkend="reference_sfcgal" />. And also allow to use SFCGAL rather than GEOS for some 2D functions provided by both backends (like ST_Intersection or ST_Area, for instance). A PostgreSQL configuration variable <code>postgis.backend</code> allow end user to control which backend he want to use if SFCGAL is installed (GEOS by default). Nota: SFCGAL 1.2 require at least CGAL 4.3 and Boost 1.54 (cf: <ulink url="https://oslandia.gitlab.io/SFCGAL/dev.html">https://oslandia.gitlab.io/SFCGAL/dev.html</ulink>)
+			SFCGAL, version 1.3.1 (or higher), 1.4.1 or higher is recommended. SFCGAL can be used to provide additional 2D and 3D advanced analysis functions to PostGIS cf <xref linkend="reference_sfcgal" />. And also allow to use SFCGAL rather than GEOS for some 2D functions provided by both backends (like ST_Intersection or ST_Area, for instance). A PostgreSQL configuration variable <code>postgis.backend</code> allow end user to control which backend he want to use if SFCGAL is installed (GEOS by default). Nota: SFCGAL 1.2 require at least CGAL 4.3 and Boost 1.54 (cf: <ulink url="https://oslandia.gitlab.io/SFCGAL/dev.html">https://oslandia.gitlab.io/SFCGAL/dev.html</ulink>)
 		  <ulink url="https://gitlab.com/Oslandia/SFCGAL/">https://gitlab.com/Oslandia/SFCGAL/</ulink>.
 		</para>
diff --git a/doc/postgis.xml b/doc/postgis.xml
index 5399f5819..b47f7c893 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -11,9 +11,10 @@
 <!ENTITY postgis_download_url "@@POSTGIS_DOWNLOAD_URL@@/postgis-@@LAST_RELEASE_VERSION@@.tar.gz">
 <!-- Change these values to update the version numbers referenced within the documentation -->
-<!ENTITY last_proj_release_version "8.2.1">
-<!ENTITY last_geos_release_version "3.10.1">
+<!ENTITY last_proj_release_version "9.0.1">
+<!ENTITY last_geos_release_version "3.11.0">
 <!ENTITY min_postgres_version "11">
+<!ENTITY max_postgres_version "15">
 <!ENTITY introduction SYSTEM "introduction.xml">
 <!ENTITY installation SYSTEM "installation.xml">
Summary of changes:
 doc/installation.xml | 6 +++---
 doc/postgis.xml      | 5 +++--
 2 files changed, 6 insertions(+), 5 deletions(-)
hooks/post-receive
