[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta2-9-g8cff748a3
Sat Jul 23 15:01:38 PDT 2022
the project "PostGIS".
       via  8cff748a310253c20b769f13419cb2363e5160f8 (commit)
      from  d624c45fe4941ae79f3a85e48d8eca54d676597f (commit)
revisions in full, below.
commit 8cff748a310253c20b769f13419cb2363e5160f8
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Jul 23 18:00:38 2022 -0400
    Minimum Bounding Circle regress failure on i386 Debian
    Revise test to ignore micro floating point difference
    Closes #5157 for PostGIS 3.3.0
diff --git a/NEWS b/NEWS
index 066ddb944..505abbff1 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,9 @@ Requires SFCGAL 1.4.1+ for ST_AlphaShape and ST_OptimalAlphaShape.
 Changes since PostGIS 3.3.0beta2:
 * Bug fixes *
   - #5154, raster ST_Value is undercosted (Regina Obe)
+  - #5157, Revise minimum_bounding_circle Cunit test
+           to be tolerant of small 32-bit floating point differences
+           (Regina Obe)
diff --git a/liblwgeom/cunit/cu_minimum_bounding_circle.c b/liblwgeom/cunit/cu_minimum_bounding_circle.c
index 50e0395a0..3f49ec9a9 100644
--- a/liblwgeom/cunit/cu_minimum_bounding_circle.c
+++ b/liblwgeom/cunit/cu_minimum_bounding_circle.c
@@ -22,17 +22,26 @@ static void mbc_test(LWGEOM* g)
 	POINT2D p;
 	POINT4D p4;
+	char *msg1 = "mbc_test failed (got %.12f should be less than radius %.12f) \n";
 	while (lwpointiterator_next(it, &p4))
-		p.x = p4.x;
-		p.y = p4.y;
+			p.x = p4.x;
+			p.y = p4.y;
-		/* We need to store the distance in a variable before the assert so that
-		 * it is rounded from its 80-bit representation (on x86) down to 64 bits.
-		volatile double d = distance2d_pt_pt(result->center, &p);
-		CU_ASSERT_TRUE(d <= result->radius);
+			/* We need to store the distance in a variable before the assert so that
+				* it is rounded from its 80-bit representation (on x86) down to 64 bits.
+			volatile double d = distance2d_pt_pt(result->center, &p);
+			//char *msg1 = "mbc_test failed (got %.12f expected %.12f) \n";
+			if ( (d - result->radius) > 0.0000001  )
+							printf(msg1, d, result->radius);
+							CU_FAIL();
+			else
+							CU_PASS();
 	lwboundingcircle_destroy(result);
Summary of changes:
 NEWS                                         |  3 +++
 liblwgeom/cunit/cu_minimum_bounding_circle.c | 25 +++++++++++++++++--------
 2 files changed, 20 insertions(+), 8 deletions(-)
hooks/post-receive
