[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta2-10-gd0b68e84a
Sat Jul 23 21:16:09 PDT 2022
the project "PostGIS".
       via  d0b68e84ab91d4966925f0781a953aae26278957 (commit)
      from  8cff748a310253c20b769f13419cb2363e5160f8 (commit)
revisions in full, below.
commit d0b68e84ab91d4966925f0781a953aae26278957
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Jul 24 00:16:04 2022 -0400
    Clean up the formatting of last commit.
diff --git a/liblwgeom/cunit/cu_minimum_bounding_circle.c b/liblwgeom/cunit/cu_minimum_bounding_circle.c
index 3f49ec9a9..663572c5e 100644
--- a/liblwgeom/cunit/cu_minimum_bounding_circle.c
+++ b/liblwgeom/cunit/cu_minimum_bounding_circle.c
@@ -25,23 +25,22 @@ static void mbc_test(LWGEOM* g)
 	char *msg1 = "mbc_test failed (got %.12f should be less than radius %.12f) \n";
 	while (lwpointiterator_next(it, &p4))
-			p.x = p4.x;
-			p.y = p4.y;
+		p.x = p4.x;
+		p.y = p4.y;
-			/* We need to store the distance in a variable before the assert so that
-				* it is rounded from its 80-bit representation (on x86) down to 64 bits.
-			volatile double d = distance2d_pt_pt(result->center, &p);
-			//char *msg1 = "mbc_test failed (got %.12f expected %.12f) \n";
-			if ( (d - result->radius) > 0.0000001  )
-							printf(msg1, d, result->radius);
-							CU_FAIL();
-			else
-							CU_PASS();
+		/* We need to store the distance in a variable before the assert so that
+		* it is rounded from its 80-bit representation (on x86) down to 64 bits.
+		volatile double d = distance2d_pt_pt(result->center, &p);
+		if ( (d - result->radius) > 0.0000001  )
+			printf(msg1, d, result->radius);
+			CU_FAIL();
+		else
+			CU_PASS();
 	lwboundingcircle_destroy(result);
Summary of changes:
 liblwgeom/cunit/cu_minimum_bounding_circle.c | 31 ++++++++++++++--------------
 1 file changed, 15 insertions(+), 16 deletions(-)
hooks/post-receive
