[postgis-tickets] [PostGIS] #5189: upgrade failing from 3.2 to 3.3 - could not find function "gserialized_gist_sortsupport_2d"
PostGIS trac at osgeo.org
Sat Jul 23 21:42:24 PDT 2022
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 3.3.0
Component:  buildbots  |    Version:  master
 Keywords:             |
 Looks like debbie's upgrades are failing going from PostGIS 3.2 to master
 (PG14) with this error:
 https://debbie.postgis.net/job/PostGIS_Regress/21785/consoleFull
 8:57:57 TMPDIR is /var/lib/jenkins/workspace/postgis/tmp/3_3_pg14w64
 18:57:57 Creating database 'postgis_reg'
 18:57:57 Loading unpackaged components from
 /var/lib/jenkins/workspace/pg/rel/pg14w64/share/postgresql/contrib/postgis-3.2
 18:57:57 Loading PostGIS into 'postgis_reg'
 18:57:57  failed (Error encountered loading
 /var/lib/jenkins/workspace/pg/rel/pg14w64/share/postgresql/contrib/postgis-3.2/postgis.sql:
 /var/lib/jenkins/workspace/postgis/tmp/3_3_pg14w64/regress_log)
 18:57:57
 psql:/var/lib/jenkins/workspace/pg/rel/pg14w64/share/postgresql/contrib/postgis-3.2/postgis.sql:564:
 ERROR:  could not find function "gserialized_gist_sortsupport_2d" in file
 "/var/lib/jenkins/workspace/pg/rel/pg14w64/lib/postgresql/postgis-3.so"
 18:57:57
 /var/lib/jenkins/workspace/pg/rel/pg14w64/share/postgresql/contrib/postgis-3.2/postgis_comments.sql:
 I suspect the postgis-3.so must be coming from 3.1, cause I had changed
 debbie to build --with-library-minor-version in master and it's quite
 possible she did a run of 3.1 branch after 3.2, so the upgrade script is
 all confused.
 I'll take out the --with-library-minor-version.  We probably should have
 one bot that builds without this switch and that does upgrades.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5189>
