[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta2-14-g97de4484e
Mon Jul 25 11:51:03 PDT 2022
the project "PostGIS".
       via  97de4484e6f0b14607ed14fd7cc6ca1fe364eaef (commit)
      from  9c39b9d98819ec91ca825798356af4ef691753d4 (commit)
revisions in full, below.
commit 97de4484e6f0b14607ed14fd7cc6ca1fe364eaef
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Jul 25 14:49:26 2022 -0400
    Use integer instead of int4.  References #5191 for PostGIS 3.3.0
diff --git a/NEWS b/NEWS
index 505abbff1..899435b90 100644
--- a/NEWS
+++ b/NEWS
@@ -11,6 +11,7 @@ Changes since PostGIS 3.3.0beta2:
   - #5157, Revise minimum_bounding_circle Cunit test
            to be tolerant of small 32-bit floating point differences
            (Regina Obe)
+  - #5191, Functions should use integer instead of int4 (Regina Obe)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 3aae1137f..22e336c56 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -486,13 +486,13 @@ CREATE OPERATOR CLASS hash_geometry_ops
 -- Availability: 2.0.0
-CREATE OR REPLACE FUNCTION geometry_gist_distance_2d(internal,geometry,int4)
+CREATE OR REPLACE FUNCTION geometry_gist_distance_2d(internal,geometry,integer)
 	RETURNS float8
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_distance_2d'
 	LANGUAGE 'c' PARALLEL SAFE;
-CREATE OR REPLACE FUNCTION geometry_gist_consistent_2d(internal,geometry,int4)
+CREATE OR REPLACE FUNCTION geometry_gist_consistent_2d(internal,geometry,integer)
 	RETURNS bool
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_consistent_2d'
@@ -578,13 +578,13 @@ CREATE OR REPLACE FUNCTION _postgis_index_extent(tbl regclass, col text)
 	LANGUAGE 'c' STABLE STRICT;
 -- Availability: 2.1.0
-CREATE OR REPLACE FUNCTION gserialized_gist_sel_2d (internal, oid, internal, int4)
+CREATE OR REPLACE FUNCTION gserialized_gist_sel_2d (internal, oid, internal, integer)
 	RETURNS float8
 	AS 'MODULE_PATHNAME', 'gserialized_gist_sel_2d'
-CREATE OR REPLACE FUNCTION gserialized_gist_sel_nd (internal, oid, internal, int4)
+CREATE OR REPLACE FUNCTION gserialized_gist_sel_nd (internal, oid, internal, integer)
 	RETURNS float8
 	AS 'MODULE_PATHNAME', 'gserialized_gist_sel_nd'
@@ -843,8 +843,8 @@ CREATE OPERATOR CLASS gist_geometry_ops_2d
 #if POSTGIS_PGSQL_VERSION >= 150
 	FUNCTION        11       geometry_gist_sortsupport_2d (internal),
 #endif
-	FUNCTION        8        geometry_gist_distance_2d (internal, geometry, int4),
-	FUNCTION        1        geometry_gist_consistent_2d (internal, geometry, int4),
+	FUNCTION        8        geometry_gist_distance_2d (internal, geometry, integer),
+	FUNCTION        1        geometry_gist_consistent_2d (internal, geometry, integer),
 	FUNCTION        2        geometry_gist_union_2d (bytea, internal),
 	FUNCTION        3        geometry_gist_compress_2d (internal),
 	FUNCTION        4        geometry_gist_decompress_2d (internal),
@@ -861,7 +861,7 @@ CREATE OPERATOR CLASS gist_geometry_ops_2d
-CREATE OR REPLACE FUNCTION geometry_gist_consistent_nd(internal,geometry,int4)
+CREATE OR REPLACE FUNCTION geometry_gist_consistent_nd(internal,geometry,integer)
 	RETURNS bool
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_consistent'
@@ -1006,7 +1006,7 @@ CREATE OPERATOR |=| (
 -- Availability: 2.2.0
-CREATE OR REPLACE FUNCTION geometry_gist_distance_nd(internal,geometry,int4)
+CREATE OR REPLACE FUNCTION geometry_gist_distance_nd(internal,geometry,integer)
 	RETURNS float8
 	AS 'MODULE_PATHNAME', 'gserialized_gist_distance'
@@ -1028,8 +1028,8 @@ CREATE OPERATOR CLASS gist_geometry_ops_nd
 	OPERATOR        20       |=| FOR ORDER BY pg_catalog.float_ops,
-	FUNCTION        8        geometry_gist_distance_nd (internal, geometry, int4),
-	FUNCTION        1        geometry_gist_consistent_nd (internal, geometry, int4),
+	FUNCTION        8        geometry_gist_distance_nd (internal, geometry, integer),
+	FUNCTION        1        geometry_gist_consistent_nd (internal, geometry, integer),
 	FUNCTION        2        geometry_gist_union_nd (bytea, internal),
 	FUNCTION        3        geometry_gist_compress_nd (internal),
 	FUNCTION        4        geometry_gist_decompress_nd (internal),
@@ -1230,7 +1230,7 @@ CREATE OR REPLACE FUNCTION ST_QuantizeCoordinates(g geometry, prec_x int, prec_y
 CREATE OR REPLACE FUNCTION ST_MemSize(geometry)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME', 'LWGEOM_mem_size'
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_DEFAULT;
@@ -1244,14 +1244,14 @@ CREATE OR REPLACE FUNCTION ST_Summary(geometry)
 -- Availability: 1.2.2
 CREATE OR REPLACE FUNCTION ST_NPoints(geometry)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME', 'LWGEOM_npoints'
 	_COST_LOW;
 CREATE OR REPLACE FUNCTION ST_NRings(geometry)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME', 'LWGEOM_nrings'
 	_COST_LOW;
@@ -1623,21 +1623,21 @@ CREATE OR REPLACE FUNCTION ST_AsEWKT(geometry)
 	_COST_MEDIUM;
 -- Availability: 3.1.0
-CREATE OR REPLACE FUNCTION ST_AsEWKT(geometry, int4)
+CREATE OR REPLACE FUNCTION ST_AsEWKT(geometry, integer)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asEWKT'
 	_COST_MEDIUM;
-CREATE OR REPLACE FUNCTION ST_AsTWKB(geom geometry, prec int4 default NULL, prec_z int4 default NULL, prec_m int4 default NULL, with_sizes boolean default NULL, with_boxes boolean default NULL)
+CREATE OR REPLACE FUNCTION ST_AsTWKB(geom geometry, prec integer default NULL, prec_z integer default NULL, prec_m integer default NULL, with_sizes boolean default NULL, with_boxes boolean default NULL)
 	RETURNS bytea
 	AS 'MODULE_PATHNAME','TWKBFromLWGEOM'
 	LANGUAGE 'c' IMMUTABLE PARALLEL SAFE
 	_COST_LOW;
-CREATE OR REPLACE FUNCTION ST_AsTWKB(geom geometry[], ids bigint[], prec int4 default NULL, prec_z int4 default NULL, prec_m int4 default NULL, with_sizes boolean default NULL, with_boxes boolean default NULL)
+CREATE OR REPLACE FUNCTION ST_AsTWKB(geom geometry[], ids bigint[], prec integer default NULL, prec_z integer default NULL, prec_m integer default NULL, with_sizes boolean default NULL, with_boxes boolean default NULL)
 	RETURNS bytea
 	AS 'MODULE_PATHNAME','TWKBFromLWGEOMArray'
@@ -2791,7 +2791,7 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 -- FIND_SRID( <schema>, <table>, <geom col> )
 -- Changed: 2.1.8 improve performance
-CREATE OR REPLACE FUNCTION find_srid(varchar,varchar,varchar) RETURNS int4 AS
+CREATE OR REPLACE FUNCTION find_srid(varchar,varchar,varchar) RETURNS integer AS
 DECLARE
 	schem varchar =  $1;
@@ -2828,14 +2828,14 @@ CREATE OR REPLACE FUNCTION get_proj4_from_srid(integer) RETURNS text AS
 	LANGUAGE 'plpgsql' IMMUTABLE STRICT PARALLEL SAFE;
-CREATE OR REPLACE FUNCTION ST_SetSRID(geom geometry, srid int4)
+CREATE OR REPLACE FUNCTION ST_SetSRID(geom geometry, srid integer)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','LWGEOM_set_srid'
 	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION ST_SRID(geom geometry)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME','LWGEOM_get_srid'
 	_COST_DEFAULT;
@@ -3620,14 +3620,14 @@ CREATE TYPE valid_detail AS (
-CREATE OR REPLACE FUNCTION ST_IsValidDetail(geom geometry, flags int4 DEFAULT 0)
+CREATE OR REPLACE FUNCTION ST_IsValidDetail(geom geometry, flags integer DEFAULT 0)
 	RETURNS valid_detail
 	AS 'MODULE_PATHNAME', 'isvaliddetail'
 	_COST_HIGH;
-CREATE OR REPLACE FUNCTION ST_IsValidReason(geometry, int4)
+CREATE OR REPLACE FUNCTION ST_IsValidReason(geometry, integer)
 	RETURNS text
 	AS $$
 	SELECT CASE WHEN valid THEN 'Valid Geometry' ELSE reason END FROM (
@@ -3638,7 +3638,7 @@ CREATE OR REPLACE FUNCTION ST_IsValidReason(geometry, int4)
 	_COST_HIGH;
-CREATE OR REPLACE FUNCTION ST_IsValid(geometry, int4)
+CREATE OR REPLACE FUNCTION ST_IsValid(geometry, integer)
 	RETURNS boolean
 	AS 'SELECT (@extschema at .ST_isValidDetail($1, $2)).valid'
 	LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE
@@ -3906,7 +3906,7 @@ CREATE OR REPLACE FUNCTION ST_Node(g geometry)
 -- ST_DelaunayTriangles
--- ST_DelaunayTriangles(g1 geometry, tolerance float8, flags int4)
+-- ST_DelaunayTriangles(g1 geometry, tolerance float8, flags integer)
 -- Builds Delaunay triangulation out of geometry vertices.
@@ -3919,7 +3919,7 @@ CREATE OR REPLACE FUNCTION ST_Node(g geometry)
-CREATE OR REPLACE FUNCTION ST_DelaunayTriangles(g1 geometry, tolerance float8 DEFAULT 0.0, flags int4 DEFAULT 0)
+CREATE OR REPLACE FUNCTION ST_DelaunayTriangles(g1 geometry, tolerance float8 DEFAULT 0.0, flags integer DEFAULT 0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_DelaunayTriangles'
@@ -4276,7 +4276,7 @@ CREATE OR REPLACE FUNCTION ST_Relate(geom1 geometry, geom2 geometry)
 	_COST_HIGH;
-CREATE OR REPLACE FUNCTION ST_Relate(geom1 geometry, geom2 geometry, int4)
+CREATE OR REPLACE FUNCTION ST_Relate(geom1 geometry, geom2 geometry, integer)
 	RETURNS text
 	AS 'MODULE_PATHNAME','relate_full'
@@ -4735,14 +4735,14 @@ CREATE OR REPLACE FUNCTION Equals(geom1 geometry, geom2 geometry)
 -- GML & KML INPUT
-CREATE OR REPLACE FUNCTION _ST_GeomFromGML(text, int4)
+CREATE OR REPLACE FUNCTION _ST_GeomFromGML(text, integer)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','geom_from_gml'
 	_COST_MEDIUM;
-CREATE OR REPLACE FUNCTION ST_GeomFromGML(text, int4)
+CREATE OR REPLACE FUNCTION ST_GeomFromGML(text, integer)
 	RETURNS geometry
@@ -4763,7 +4763,7 @@ CREATE OR REPLACE FUNCTION ST_GMLToSQL(text)
 	_COST_MEDIUM;
-CREATE OR REPLACE FUNCTION ST_GMLToSQL(text, int4)
+CREATE OR REPLACE FUNCTION ST_GMLToSQL(text, integer)
 	RETURNS geometry
@@ -4838,8 +4838,8 @@ CREATE OR REPLACE FUNCTION postgis_libjson_version()
 -- ENCODED POLYLINE INPUT
--- ST_LineFromEncodedPolyline(polyline text, precision int4)
-CREATE OR REPLACE FUNCTION ST_LineFromEncodedPolyline(txtin text, nprecision int4 DEFAULT 5)
+-- ST_LineFromEncodedPolyline(polyline text, precision integer)
+CREATE OR REPLACE FUNCTION ST_LineFromEncodedPolyline(txtin text, nprecision integer DEFAULT 5)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','line_from_encoded_polyline'
@@ -4851,8 +4851,8 @@ CREATE OR REPLACE FUNCTION ST_LineFromEncodedPolyline(txtin text, nprecision int
 -- ENCODED POLYLINE OUTPUT
--- ST_AsEncodedPolyline(geom geometry, precision int4)
-CREATE OR REPLACE FUNCTION ST_AsEncodedPolyline(geom geometry, nprecision int4 DEFAULT 5)
+-- ST_AsEncodedPolyline(geom geometry, precision integer)
+CREATE OR REPLACE FUNCTION ST_AsEncodedPolyline(geom geometry, nprecision integer DEFAULT 5)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asEncodedPolyline'
@@ -4865,7 +4865,7 @@ CREATE OR REPLACE FUNCTION ST_AsEncodedPolyline(geom geometry, nprecision int4 D
 -- Changed: 2.0.0 changed to use default args and allow calling by named args
-CREATE OR REPLACE FUNCTION ST_AsSVG(geom geometry, rel int4 DEFAULT 0, maxdecimaldigits int4 DEFAULT 15)
+CREATE OR REPLACE FUNCTION ST_AsSVG(geom geometry, rel integer DEFAULT 0, maxdecimaldigits integer DEFAULT 15)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asSVG'
@@ -4875,7 +4875,7 @@ CREATE OR REPLACE FUNCTION ST_AsSVG(geom geometry, rel int4 DEFAULT 0, maxdecima
 -- GML OUTPUT
 -- _ST_AsGML(version, geom, precision, option, prefix, id)
-CREATE OR REPLACE FUNCTION _ST_AsGML(int4, geometry, int4, int4, text, text)
+CREATE OR REPLACE FUNCTION _ST_AsGML(integer, geometry, integer, integer, text, text)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asGML'
@@ -4889,7 +4889,7 @@ CREATE OR REPLACE FUNCTION _ST_AsGML(int4, geometry, int4, int4, text, text)
 -- ST_AsGML (geom, precision, option) / version=2
 -- Availability: 1.4.0
 -- Changed: 2.0.0 to have default args
-CREATE OR REPLACE FUNCTION ST_AsGML(geom geometry, maxdecimaldigits int4 DEFAULT 15, options int4 DEFAULT 0)
+CREATE OR REPLACE FUNCTION ST_AsGML(geom geometry, maxdecimaldigits integer DEFAULT 15, options integer DEFAULT 0)
 	RETURNS TEXT
@@ -4902,7 +4902,7 @@ CREATE OR REPLACE FUNCTION ST_AsGML(geom geometry, maxdecimaldigits int4 DEFAULT
 -- Changed: 2.0.0 to use default and named args
 -- ST_AsGML(version, geom, precision, option, prefix, id)
-CREATE OR REPLACE FUNCTION ST_AsGML(version int4, geom geometry, maxdecimaldigits int4 DEFAULT 15, options int4 DEFAULT 0, nprefix text DEFAULT null, id text DEFAULT null)
+CREATE OR REPLACE FUNCTION ST_AsGML(version integer, geom geometry, maxdecimaldigits integer DEFAULT 15, options integer DEFAULT 0, nprefix text DEFAULT null, id text DEFAULT null)
 	RETURNS TEXT
@@ -4914,8 +4914,8 @@ CREATE OR REPLACE FUNCTION ST_AsGML(version int4, geom geometry, maxdecimaldigit
 -- Changed: 2.0.0 to use default args and allow named args
--- Replaces ST_AsKML(geometry, int4) deprecated in 2.0.0
-CREATE OR REPLACE FUNCTION ST_AsKML(geom geometry, maxdecimaldigits int4 DEFAULT 15, nprefix TEXT default '')
+-- Replaces ST_AsKML(geometry, integer) deprecated in 2.0.0
+CREATE OR REPLACE FUNCTION ST_AsKML(geom geometry, maxdecimaldigits integer DEFAULT 15, nprefix TEXT default '')
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asKML'
@@ -4929,14 +4929,14 @@ CREATE OR REPLACE FUNCTION ST_AsKML(geom geometry, maxdecimaldigits int4 DEFAULT
 -- ST_AsGeoJson(geom, precision, options) / version=1
 -- Changed: 2.0.0 to use default args and named args
 -- Changed: 3.0.0 change default args mode
-CREATE OR REPLACE FUNCTION ST_AsGeoJson(geom geometry, maxdecimaldigits int4 DEFAULT 9, options int4 DEFAULT 8)
+CREATE OR REPLACE FUNCTION ST_AsGeoJson(geom geometry, maxdecimaldigits integer DEFAULT 9, options integer DEFAULT 8)
 	RETURNS text
 	AS 'MODULE_PATHNAME','LWGEOM_asGeoJson'
 	_COST_MEDIUM;
 -- Availability: 3.0.0
-CREATE OR REPLACE FUNCTION ST_AsGeoJson(r record, geom_column text DEFAULT '', maxdecimaldigits int4 DEFAULT 9, pretty_bool bool DEFAULT false)
+CREATE OR REPLACE FUNCTION ST_AsGeoJson(r record, geom_column text DEFAULT '', maxdecimaldigits integer DEFAULT 9, pretty_bool bool DEFAULT false)
 	RETURNS text
 	AS 'MODULE_PATHNAME','ST_AsGeoJsonRow'
 	LANGUAGE 'c' STABLE STRICT PARALLEL SAFE
@@ -4981,21 +4981,21 @@ CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement, text)
 	_COST_MEDIUM;
 -- Availability: 2.4.0
-CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement, text, int4)
+CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement, text, integer)
 	RETURNS internal
 	AS 'MODULE_PATHNAME', 'pgis_asmvt_transfn'
 	_COST_MEDIUM;
-CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement, text, int4, text)
+CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement, text, integer, text)
 	RETURNS internal
 	_COST_MEDIUM;
-CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement, text, int4, text, text)
+CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, anyelement, text, integer, text, text)
 	RETURNS internal
@@ -5060,7 +5060,7 @@ CREATE AGGREGATE ST_AsMVT(anyelement, text)
 -- Changed: 3.3.0
 -- Changed: 3.2.0
-CREATE AGGREGATE ST_AsMVT(anyelement, text, int4)
+CREATE AGGREGATE ST_AsMVT(anyelement, text, integer)
 	sfunc = pgis_asmvt_transfn,
 	stype = internal,
@@ -5075,7 +5075,7 @@ CREATE AGGREGATE ST_AsMVT(anyelement, text, int4)
 -- Changed: 3.3.0
 -- Changed: 3.2.0
-CREATE AGGREGATE ST_AsMVT(anyelement, text, int4, text)
+CREATE AGGREGATE ST_AsMVT(anyelement, text, integer, text)
 	stype = internal,
@@ -5090,7 +5090,7 @@ CREATE AGGREGATE ST_AsMVT(anyelement, text, int4, text)
 -- Changed: 3.3.0
 -- Changed: 3.2.0
-CREATE AGGREGATE ST_AsMVT(anyelement, text, int4, text, text)
+CREATE AGGREGATE ST_AsMVT(anyelement, text, integer, text, text)
 	stype = internal,
@@ -5103,7 +5103,7 @@ CREATE AGGREGATE ST_AsMVT(anyelement, text, int4, text, text)
-CREATE OR REPLACE FUNCTION ST_AsMVTGeom(geom geometry, bounds box2d, extent int4 default 4096, buffer int4 default 256, clip_geom bool default true)
+CREATE OR REPLACE FUNCTION ST_AsMVTGeom(geom geometry, bounds box2d, extent integer default 4096, buffer integer default 256, clip_geom bool default true)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','ST_AsMVTGeom'
@@ -5248,7 +5248,7 @@ CREATE OR REPLACE FUNCTION ST_FromFlatGeobuf(anyelement, bytea)
 -- Availability 1.4.0
 -- Changed 2.0.0 to use default args and named args
-CREATE OR REPLACE FUNCTION ST_GeoHash(geom geometry, maxchars int4 DEFAULT 0)
+CREATE OR REPLACE FUNCTION ST_GeoHash(geom geometry, maxchars integer DEFAULT 0)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME', 'ST_GeoHash'
@@ -5266,22 +5266,22 @@ CREATE OR REPLACE FUNCTION _ST_SortableHash(geom geometry)
 -- GeoHash input
 -- Availability: 2.0.?
--- ST_Box2dFromGeoHash(geohash text, precision int4)
-CREATE OR REPLACE FUNCTION ST_Box2dFromGeoHash(text, int4 DEFAULT NULL)
+-- ST_Box2dFromGeoHash(geohash text, precision integer)
+CREATE OR REPLACE FUNCTION ST_Box2dFromGeoHash(text, integer DEFAULT NULL)
 	RETURNS box2d
 	AS 'MODULE_PATHNAME','box2d_from_geohash'
 	_COST_LOW;
--- ST_PointFromGeoHash(geohash text, precision int4)
-CREATE OR REPLACE FUNCTION ST_PointFromGeoHash(text, int4 DEFAULT NULL)
+-- ST_PointFromGeoHash(geohash text, precision integer)
+CREATE OR REPLACE FUNCTION ST_PointFromGeoHash(text, integer DEFAULT NULL)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','point_from_geohash'
 	_COST_LOW;
--- ST_GeomFromGeoHash(geohash text, precision int4)
-CREATE OR REPLACE FUNCTION ST_GeomFromGeoHash(text, int4 DEFAULT NULL)
+-- ST_GeomFromGeoHash(geohash text, precision integer)
+CREATE OR REPLACE FUNCTION ST_GeomFromGeoHash(text, integer DEFAULT NULL)
 	RETURNS geometry
 	AS $$ SELECT CAST(@extschema at .ST_Box2dFromGeoHash($1, $2) AS geometry); $$
 	LANGUAGE 'sql' IMMUTABLE PARALLEL SAFE
@@ -5292,14 +5292,14 @@ CREATE OR REPLACE FUNCTION ST_GeomFromGeoHash(text, int4 DEFAULT NULL)
 -- PostGIS equivalent function: NumPoints(geometry)
 CREATE OR REPLACE FUNCTION ST_NumPoints(geometry)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME', 'LWGEOM_numpoints_linestring'
 	_COST_LOW;
 -- PostGIS equivalent function: NumGeometries(geometry)
 CREATE OR REPLACE FUNCTION ST_NumGeometries(geometry)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME', 'LWGEOM_numgeometries_collection'
 	_COST_LOW;
@@ -5313,7 +5313,7 @@ CREATE OR REPLACE FUNCTION ST_GeometryN(geometry,integer)
 -- PostGIS equivalent function: Dimension(geometry)
 CREATE OR REPLACE FUNCTION ST_Dimension(geometry)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME', 'LWGEOM_dimension'
 	_COST_LOW;
@@ -5369,7 +5369,7 @@ CREATE OR REPLACE FUNCTION ST_PointN(geometry,integer)
 CREATE OR REPLACE FUNCTION ST_NumPatches(geometry)
-	RETURNS int4
+	RETURNS integer
 	AS '
 	SELECT CASE WHEN @extschema at .ST_GeometryType($1) = ''ST_PolyhedralSurface''
 	THEN @extschema at .ST_NumGeometries($1)
@@ -5439,8 +5439,8 @@ CREATE OR REPLACE FUNCTION ST_AsText(geometry)
 	_COST_MEDIUM;
 -- Availability: 2.5.0
--- PostGIS equivalent function: AsText(geometry, int4)
-CREATE OR REPLACE FUNCTION ST_AsText(geometry, int4)
+-- PostGIS equivalent function: AsText(geometry, integer)
+CREATE OR REPLACE FUNCTION ST_AsText(geometry, integer)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asText'
@@ -5454,7 +5454,7 @@ CREATE OR REPLACE FUNCTION ST_GeometryFromText(text)
 	_COST_MEDIUM;
-CREATE OR REPLACE FUNCTION ST_GeometryFromText(text, int4)
+CREATE OR REPLACE FUNCTION ST_GeometryFromText(text, integer)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','LWGEOM_from_text'
@@ -5467,8 +5467,8 @@ CREATE OR REPLACE FUNCTION ST_GeomFromText(text)
 	_COST_MEDIUM;
--- PostGIS equivalent function: ST_GeometryFromText(text, int4)
-CREATE OR REPLACE FUNCTION ST_GeomFromText(text, int4)
+-- PostGIS equivalent function: ST_GeometryFromText(text, integer)
+CREATE OR REPLACE FUNCTION ST_GeomFromText(text, integer)
 	RETURNS geometry
@@ -5493,9 +5493,9 @@ CREATE OR REPLACE FUNCTION ST_PointFromText(text)
 	_COST_MEDIUM;
--- PostGIS equivalent function: PointFromText(text, int4)
+-- PostGIS equivalent function: PointFromText(text, integer)
 -- TODO: improve this ... by not duplicating constructor time.
-CREATE OR REPLACE FUNCTION ST_PointFromText(text, int4)
+CREATE OR REPLACE FUNCTION ST_PointFromText(text, integer)
 	RETURNS geometry
 	AS '
 	SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1, $2)) = ''POINT''
@@ -5516,8 +5516,8 @@ CREATE OR REPLACE FUNCTION ST_LineFromText(text)
 	_COST_MEDIUM;
--- PostGIS equivalent function: LineFromText(text, int4)
-CREATE OR REPLACE FUNCTION ST_LineFromText(text, int4)
+-- PostGIS equivalent function: LineFromText(text, integer)
+CREATE OR REPLACE FUNCTION ST_LineFromText(text, integer)
 	RETURNS geometry
 	AS '
 	SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1, $2)) = ''LINESTRING''
@@ -5538,8 +5538,8 @@ CREATE OR REPLACE FUNCTION ST_PolyFromText(text)
 	_COST_MEDIUM;
--- PostGIS equivalent function: ST_PolygonFromText(text, int4)
-CREATE OR REPLACE FUNCTION ST_PolyFromText(text, int4)
+-- PostGIS equivalent function: ST_PolygonFromText(text, integer)
+CREATE OR REPLACE FUNCTION ST_PolyFromText(text, integer)
 	RETURNS geometry
 	AS '
 	SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1, $2)) = ''POLYGON''
@@ -5550,7 +5550,7 @@ CREATE OR REPLACE FUNCTION ST_PolyFromText(text, int4)
 	_COST_MEDIUM;
-CREATE OR REPLACE FUNCTION ST_PolygonFromText(text, int4)
+CREATE OR REPLACE FUNCTION ST_PolygonFromText(text, integer)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_PolyFromText($1, $2)'
@@ -5563,8 +5563,8 @@ CREATE OR REPLACE FUNCTION ST_PolygonFromText(text)
 	_COST_MEDIUM;
--- PostGIS equivalent function: MLineFromText(text, int4)
-CREATE OR REPLACE FUNCTION ST_MLineFromText(text, int4)
+-- PostGIS equivalent function: MLineFromText(text, integer)
+CREATE OR REPLACE FUNCTION ST_MLineFromText(text, integer)
 	RETURNS geometry
 	AS '
 	SELECT CASE
@@ -5594,14 +5594,14 @@ CREATE OR REPLACE FUNCTION ST_MultiLineStringFromText(text)
 	_COST_MEDIUM;
-CREATE OR REPLACE FUNCTION ST_MultiLineStringFromText(text, int4)
+CREATE OR REPLACE FUNCTION ST_MultiLineStringFromText(text, integer)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_MLineFromText($1, $2)'
 	_COST_MEDIUM;
--- PostGIS equivalent function: MPointFromText(text, int4)
-CREATE OR REPLACE FUNCTION ST_MPointFromText(text, int4)
+-- PostGIS equivalent function: MPointFromText(text, integer)
+CREATE OR REPLACE FUNCTION ST_MPointFromText(text, integer)
 	RETURNS geometry
 	AS '
 	SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1, $2)) = ''MULTIPOINT''
@@ -5629,8 +5629,8 @@ CREATE OR REPLACE FUNCTION ST_MultiPointFromText(text)
 	_COST_MEDIUM;
--- PostGIS equivalent function: MPolyFromText(text, int4)
-CREATE OR REPLACE FUNCTION ST_MPolyFromText(text, int4)
+-- PostGIS equivalent function: MPolyFromText(text, integer)
+CREATE OR REPLACE FUNCTION ST_MPolyFromText(text, integer)
 	RETURNS geometry
 	AS '
 	SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1, $2)) = ''MULTIPOLYGON''
@@ -5652,7 +5652,7 @@ CREATE OR REPLACE FUNCTION ST_MPolyFromText(text)
 	_COST_MEDIUM;
-CREATE OR REPLACE FUNCTION ST_MultiPolygonFromText(text, int4)
+CREATE OR REPLACE FUNCTION ST_MultiPolygonFromText(text, integer)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_MPolyFromText($1, $2)'
@@ -5666,7 +5666,7 @@ CREATE OR REPLACE FUNCTION ST_MultiPolygonFromText(text)
 	_COST_MEDIUM;
-CREATE OR REPLACE FUNCTION ST_GeomCollFromText(text, int4)
+CREATE OR REPLACE FUNCTION ST_GeomCollFromText(text, integer)
 	RETURNS geometry
 	AS '
 	SELECT CASE
@@ -6817,7 +6817,7 @@ LANGUAGE 'plpgsql' IMMUTABLE STRICT PARALLEL SAFE _COST_HIGH;
 -- X3D OUTPUT
 -- _ST_AsX3D(version, geom, precision, option, attribs)
-CREATE OR REPLACE FUNCTION _ST_AsX3D(int4, geometry, int4, int4, text)
+CREATE OR REPLACE FUNCTION _ST_AsX3D(integer, geometry, integer, integer, text)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asX3D'
Summary of changes:
 NEWS                   |   1 +
 postgis/postgis.sql.in | 160 ++++++++++++++++++++++++-------------------------
 2 files changed, 81 insertions(+), 80 deletions(-)
hooks/post-receive
