[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta2-16-g6906e4079
Mon Jul 25 12:41:50 PDT 2022
the project "PostGIS".
       via  6906e4079c1c084006af1aabdfc70c99b4286165 (commit)
       via  7ce341c52a38b42ec63b901668eabba5d8ff3b2d (commit)
      from  97de4484e6f0b14607ed14fd7cc6ca1fe364eaef (commit)
revisions in full, below.
commit 6906e4079c1c084006af1aabdfc70c99b4286165
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Jul 25 15:38:55 2022 -0400
    Use read only SPI to maintain parallel safety
    for ST_AsGeoJSON and ST_AsGML
    References #5139 for PostGIS 3.3.0
    Using same solution from #3952
diff --git a/NEWS b/NEWS
index 899435b90..e77dfc2c9 100644
--- a/NEWS
+++ b/NEWS
@@ -12,6 +12,9 @@ Changes since PostGIS 3.3.0beta2:
            to be tolerant of small 32-bit floating point differences
            (Regina Obe)
   - #5191, Functions should use integer instead of int4 (Regina Obe)
+  - #5139, PostGIS causes to_jsonb to no longer be parallel safe,
+           ST_AsGeoJSON and ST_AsGML are also parallel unsafe
+           (Regina Obe, Paul Ramsey)
diff --git a/libpgcommon/lwgeom_cache.c b/libpgcommon/lwgeom_cache.c
index f6934b387..7e013895d 100644
--- a/libpgcommon/lwgeom_cache.c
+++ b/libpgcommon/lwgeom_cache.c
@@ -297,7 +297,7 @@ getSRSbySRID(FunctionCallInfo fcinfo, int32_t srid, bool short_crs)
 			 postgis_spatial_ref_sys(),
 			 srid);
-	err = SPI_exec(query, 1);
+	err = SPI_execute(query, true, 1);
 	if (err < 0)
 		elog(NOTICE, "%s: error executing query %d", __func__, err);
commit 7ce341c52a38b42ec63b901668eabba5d8ff3b2d
Date:   Mon Jul 25 15:24:30 2022 -0400
    Use integer instead of int4.  References #5191 for PostGIS 3.3.0. For raster, geography, and legacy
diff --git a/postgis/geography.sql.in b/postgis/geography.sql.in
index 372124147..c48a4117d 100644
--- a/postgis/geography.sql.in
+++ b/postgis/geography.sql.in
@@ -106,7 +106,7 @@ CREATE OR REPLACE FUNCTION ST_AsText(geography)
 	_COST_MEDIUM;
 -- Availability: 2.5.0
-CREATE OR REPLACE FUNCTION ST_AsText(geography, int4)
+CREATE OR REPLACE FUNCTION ST_AsText(geography, integer)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asText'
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
@@ -206,7 +206,7 @@ CREATE CAST (geography AS geometry) WITH FUNCTION geometry(geography) ;
 -- Availability: 1.5.0
-CREATE OR REPLACE FUNCTION geography_gist_consistent(internal,geography,int4)
+CREATE OR REPLACE FUNCTION geography_gist_consistent(internal,geography,integer)
 	RETURNS bool
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_consistent'
 	LANGUAGE 'c';
@@ -275,7 +275,7 @@ CREATE OPERATOR <-> (
 -- Availability: 2.2.0
-CREATE OR REPLACE FUNCTION geography_gist_distance(internal, geography, int4)
+CREATE OR REPLACE FUNCTION geography_gist_distance(internal, geography, integer)
 	RETURNS float8
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_geog_distance'
 	LANGUAGE 'c';
@@ -292,8 +292,8 @@ CREATE OPERATOR CLASS gist_geography_ops
 	OPERATOR        13       <-> FOR ORDER BY pg_catalog.float_ops,
-	FUNCTION        8        geography_gist_distance (internal, geography, int4),
-	FUNCTION        1        geography_gist_consistent (internal, geography, int4),
+	FUNCTION        8        geography_gist_distance (internal, geography, integer),
+	FUNCTION        1        geography_gist_consistent (internal, geography, integer),
 	FUNCTION        2        geography_gist_union (bytea, internal),
 	FUNCTION        3        geography_gist_compress (internal),
 	FUNCTION        4        geography_gist_decompress (internal),
@@ -404,7 +404,7 @@ CREATE OPERATOR CLASS btree_geography_ops
 -- Changed 2.0.0 to use default args and named args
-CREATE OR REPLACE FUNCTION ST_AsSVG(geog geography, rel int4 DEFAULT 0, maxdecimaldigits int4 DEFAULT 15)
+CREATE OR REPLACE FUNCTION ST_AsSVG(geog geography, rel integer DEFAULT 0, maxdecimaldigits integer DEFAULT 15)
 	RETURNS text
 	AS 'MODULE_PATHNAME','geography_as_svg'
@@ -426,13 +426,13 @@ CREATE OR REPLACE FUNCTION ST_AsSVG(text)
 -- Changed: 2.0.0 to use default args and allow named args
 -- Changed: 2.1.0 enhance to allow id value
-CREATE OR REPLACE FUNCTION ST_AsGML(version int4, geog geography, maxdecimaldigits int4 DEFAULT 15, options int4 DEFAULT 0, nprefix text DEFAULT 'gml', id text DEFAULT '')
+CREATE OR REPLACE FUNCTION ST_AsGML(version integer, geog geography, maxdecimaldigits integer DEFAULT 15, options integer DEFAULT 0, nprefix text DEFAULT 'gml', id text DEFAULT '')
 	RETURNS text
 	AS 'MODULE_PATHNAME','geography_as_gml'
 	_COST_MEDIUM;
-CREATE OR REPLACE FUNCTION ST_AsGML(geog geography, maxdecimaldigits int4 DEFAULT 15, options int4 DEFAULT 0, nprefix text DEFAULT 'gml', id text DEFAULT '')
+CREATE OR REPLACE FUNCTION ST_AsGML(geog geography, maxdecimaldigits integer DEFAULT 15, options integer DEFAULT 0, nprefix text DEFAULT 'gml', id text DEFAULT '')
 	RETURNS text
@@ -452,8 +452,8 @@ CREATE OR REPLACE FUNCTION ST_AsGML(text)
 -- AsKML(geography,precision)
 -- Changed: 2.0.0 to use default args and named args
--- Replaces ST_AsKML(geography, int4) deprecated in 2.0.0
-CREATE OR REPLACE FUNCTION ST_AsKML(geog geography, maxdecimaldigits int4 DEFAULT 15, nprefix text DEFAULT '')
+-- Replaces ST_AsKML(geography, integer) deprecated in 2.0.0
+CREATE OR REPLACE FUNCTION ST_AsKML(geog geography, maxdecimaldigits integer DEFAULT 15, nprefix text DEFAULT '')
 	RETURNS text
 	AS 'MODULE_PATHNAME','geography_as_kml'
@@ -471,7 +471,7 @@ CREATE OR REPLACE FUNCTION ST_AsKML(text)
 -- GeoJson Output
-CREATE OR REPLACE FUNCTION ST_AsGeoJson(geog geography, maxdecimaldigits int4 DEFAULT 9, options int4 DEFAULT 0)
+CREATE OR REPLACE FUNCTION ST_AsGeoJson(geog geography, maxdecimaldigits integer DEFAULT 9, options integer DEFAULT 0)
 	RETURNS text
 	AS 'MODULE_PATHNAME','geography_as_geojson'
@@ -711,7 +711,7 @@ CREATE OR REPLACE FUNCTION ST_AsEWKT(geography)
 	_COST_MEDIUM;
-CREATE OR REPLACE FUNCTION ST_AsEWKT(geography, int4)
+CREATE OR REPLACE FUNCTION ST_AsEWKT(geography, integer)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asEWKT'
@@ -738,7 +738,7 @@ CREATE OR REPLACE FUNCTION ST_Summary(geography)
 	_COST_LOW;
 -- Availability: 2.1.0
-CREATE OR REPLACE FUNCTION ST_GeoHash(geog geography, maxchars int4 DEFAULT 0)
+CREATE OR REPLACE FUNCTION ST_GeoHash(geog geography, maxchars integer DEFAULT 0)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME', 'ST_GeoHash'
@@ -746,13 +746,13 @@ CREATE OR REPLACE FUNCTION ST_GeoHash(geog geography, maxchars int4 DEFAULT 0)
 CREATE OR REPLACE FUNCTION ST_SRID(geog geography)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME', 'LWGEOM_get_srid'
 	_COST_LOW;
-CREATE OR REPLACE FUNCTION ST_SetSRID(geog geography, srid int4)
+CREATE OR REPLACE FUNCTION ST_SetSRID(geog geography, srid integer)
 	RETURNS geography
 	AS 'MODULE_PATHNAME', 'LWGEOM_set_srid'
diff --git a/postgis/legacy.sql.in b/postgis/legacy.sql.in
index c90452aee..9c90a154a 100644
--- a/postgis/legacy.sql.in
+++ b/postgis/legacy.sql.in
@@ -23,12 +23,12 @@ CREATE OR REPLACE FUNCTION hasbbox(geometry)
 -- Availability: 1.2.2 -- never deprecated but don't think anyone uses it
 CREATE OR REPLACE FUNCTION getsrid(geometry)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME','LWGEOM_get_srid'
 	LANGUAGE 'c' IMMUTABLE STRICT;
 -- Deprecation in 1.2.3
-CREATE OR REPLACE FUNCTION GeometryFromText(text, int4)
+CREATE OR REPLACE FUNCTION GeometryFromText(text, integer)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','LWGEOM_from_text'
@@ -597,14 +597,14 @@ CREATE OR REPLACE FUNCTION AsGML(geometry)
 	LANGUAGE 'sql' IMMUTABLE STRICT;
-CREATE OR REPLACE FUNCTION AsGML(geometry, int4)
+CREATE OR REPLACE FUNCTION AsGML(geometry, integer)
 	RETURNS TEXT
 	AS 'SELECT _ST_AsGML(2, $1, $2, 0, null, null)'
 -- AsKML(geom, precision) / version=2
-CREATE OR REPLACE FUNCTION AsKML(geometry, int4)
+CREATE OR REPLACE FUNCTION AsKML(geometry, integer)
 	RETURNS TEXT
 	AS 'SELECT ST_AsKML(ST_transform($1,4326), $2, null)'
@@ -618,7 +618,7 @@ CREATE OR REPLACE FUNCTION AsKML(geometry)
 -- AsKML(version, geom, precision)
-CREATE OR REPLACE FUNCTION AsKML(int4, geometry, int4)
+CREATE OR REPLACE FUNCTION AsKML(integer, geometry, integer)
 	RETURNS TEXT
 	AS 'SELECT ST_AsKML(ST_Transform($2,4326), $3, null)'
@@ -642,13 +642,13 @@ CREATE OR REPLACE FUNCTION AsSVG(geometry)
-CREATE OR REPLACE FUNCTION AsSVG(geometry,int4)
+CREATE OR REPLACE FUNCTION AsSVG(geometry,integer)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asSVG'
-CREATE OR REPLACE FUNCTION AsSVG(geometry,int4,int4)
+CREATE OR REPLACE FUNCTION AsSVG(geometry,integer,integer)
 	RETURNS TEXT
@@ -778,7 +778,7 @@ CREATE OR REPLACE FUNCTION difference(geometry,geometry)
 CREATE OR REPLACE FUNCTION Dimension(geometry)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME', 'LWGEOM_dimension'
@@ -934,7 +934,7 @@ CREATE OR REPLACE FUNCTION ForceRHR(geometry)
-CREATE OR REPLACE FUNCTION GeomCollFromText(text, int4)
+CREATE OR REPLACE FUNCTION GeomCollFromText(text, integer)
 	RETURNS geometry
 	AS '
 	SELECT CASE
@@ -1178,7 +1178,7 @@ CREATE OR REPLACE FUNCTION LineFromText(text)
-CREATE OR REPLACE FUNCTION LineFromText(text, int4)
+CREATE OR REPLACE FUNCTION LineFromText(text, integer)
 	RETURNS geometry
 	AS '
 	SELECT CASE WHEN geometrytype(GeomFromText($1, $2)) = ''LINESTRING''
@@ -1220,7 +1220,7 @@ CREATE OR REPLACE FUNCTION LineStringFromText(text)
-CREATE OR REPLACE FUNCTION LineStringFromText(text, int4)
+CREATE OR REPLACE FUNCTION LineStringFromText(text, integer)
 	RETURNS geometry
 	AS 'SELECT LineFromText($1, $2)'
@@ -1316,12 +1316,12 @@ CREATE OR REPLACE FUNCTION max_distance(geometry,geometry)
 CREATE OR REPLACE FUNCTION mem_size(geometry)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME', 'LWGEOM_mem_size'
-CREATE OR REPLACE FUNCTION MLineFromText(text, int4)
+CREATE OR REPLACE FUNCTION MLineFromText(text, integer)
 	RETURNS geometry
 	AS '
 	SELECT CASE
@@ -1362,7 +1362,7 @@ CREATE OR REPLACE FUNCTION MLineFromWKB(bytea)
-CREATE OR REPLACE FUNCTION MPointFromText(text, int4)
+CREATE OR REPLACE FUNCTION MPointFromText(text, integer)
 	RETURNS geometry
 	AS '
 	SELECT CASE WHEN geometrytype(GeomFromText($1,$2)) = ''MULTIPOINT''
@@ -1402,7 +1402,7 @@ CREATE OR REPLACE FUNCTION MPointFromWKB(bytea)
-CREATE OR REPLACE FUNCTION MPolyFromText(text, int4)
+CREATE OR REPLACE FUNCTION MPolyFromText(text, integer)
 	RETURNS geometry
 	AS '
 	SELECT CASE WHEN geometrytype(GeomFromText($1, $2)) = ''MULTIPOLYGON''
@@ -1468,7 +1468,7 @@ CREATE OR REPLACE FUNCTION MultiLineStringFromText(text)
-CREATE OR REPLACE FUNCTION MultiLineStringFromText(text, int4)
+CREATE OR REPLACE FUNCTION MultiLineStringFromText(text, integer)
 	RETURNS geometry
 	AS 'SELECT MLineFromText($1, $2)'
@@ -1486,7 +1486,7 @@ CREATE OR REPLACE FUNCTION MultiPointFromText(text)
-CREATE OR REPLACE FUNCTION MultiPointFromText(text, int4)
+CREATE OR REPLACE FUNCTION MultiPointFromText(text, integer)
 	RETURNS geometry
 	AS 'SELECT MPointFromText($1, $2)'
@@ -1512,7 +1512,7 @@ CREATE OR REPLACE FUNCTION MultiPointFromWKB(bytea)
-CREATE OR REPLACE FUNCTION MultiPolygonFromText(text, int4)
+CREATE OR REPLACE FUNCTION MultiPolygonFromText(text, integer)
 	RETURNS geometry
 	AS 'SELECT MPolyFromText($1, $2)'
@@ -1537,25 +1537,25 @@ CREATE OR REPLACE FUNCTION NumInteriorRings(geometry)
 CREATE OR REPLACE FUNCTION npoints(geometry)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME', 'LWGEOM_npoints'
 CREATE OR REPLACE FUNCTION nrings(geometry)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME', 'LWGEOM_nrings'
 CREATE OR REPLACE FUNCTION NumGeometries(geometry)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME', 'LWGEOM_numgeometries_collection'
 CREATE OR REPLACE FUNCTION NumPoints(geometry)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME', 'LWGEOM_numpoints_linestring'
@@ -1596,7 +1596,7 @@ CREATE OR REPLACE FUNCTION PointFromText(text)
-CREATE OR REPLACE FUNCTION PointFromText(text, int4)
+CREATE OR REPLACE FUNCTION PointFromText(text, integer)
 	RETURNS geometry
 	AS '
 	SELECT CASE WHEN geometrytype(GeomFromText($1, $2)) = ''POINT''
@@ -1647,7 +1647,7 @@ CREATE OR REPLACE FUNCTION PolyFromText(text)
-CREATE OR REPLACE FUNCTION PolyFromText(text, int4)
+CREATE OR REPLACE FUNCTION PolyFromText(text, integer)
 	RETURNS geometry
 	AS '
 	SELECT CASE WHEN geometrytype(GeomFromText($1, $2)) = ''POLYGON''
@@ -1677,7 +1677,7 @@ CREATE OR REPLACE FUNCTION PolyFromWKB(bytea)
-CREATE OR REPLACE FUNCTION PolygonFromText(text, int4)
+CREATE OR REPLACE FUNCTION PolygonFromText(text, integer)
 	RETURNS geometry
 	AS 'SELECT PolyFromText($1, $2)'
@@ -1950,7 +1950,7 @@ CREATE OR REPLACE FUNCTION ST_find_extent(text,text)
 -- Deprecation in 2.2.0
 CREATE OR REPLACE FUNCTION ST_mem_size(geometry)
-	RETURNS int4 AS
+	RETURNS integer AS
   	'SELECT ST_MemSize($1);'
 	LANGUAGE 'sql' IMMUTABLE STRICT SECURITY INVOKER;
@@ -2191,22 +2191,22 @@ CREATE AGGREGATE ST_Extent3D(
 -- Versioned Format Export Functions --
-CREATE OR REPLACE FUNCTION ST_AsGeoJson(version int4, geog geography, maxdecimaldigits int4 DEFAULT 15, options int4 DEFAULT 0)
+CREATE OR REPLACE FUNCTION ST_AsGeoJson(version integer, geog geography, maxdecimaldigits integer DEFAULT 15, options integer DEFAULT 0)
 	RETURNS text AS
 	$$ SELECT ST_AsGeoJson($2::geometry,$3,$4); $$
-CREATE OR REPLACE FUNCTION ST_AsGeoJson(version int4, geog geometry, maxdecimaldigits int4 DEFAULT 15, options int4 DEFAULT 0)
+CREATE OR REPLACE FUNCTION ST_AsGeoJson(version integer, geog geometry, maxdecimaldigits integer DEFAULT 15, options integer DEFAULT 0)
 	RETURNS text AS
 	$$ SELECT ST_AsGeoJson($2::geometry,15,0); $$
-CREATE OR REPLACE FUNCTION ST_AsKML(version int4, geom geography, maxdecimaldigits int4 DEFAULT 15, nprefix TEXT default '')
+CREATE OR REPLACE FUNCTION ST_AsKML(version integer, geom geography, maxdecimaldigits integer DEFAULT 15, nprefix TEXT default '')
 	RETURNS text AS
 	$$ SELECT ST_AsKML($2::geometry,$3,$4); $$
-CREATE OR REPLACE FUNCTION ST_AsKML(version int4, geom geometry, maxdecimaldigits int4 DEFAULT 15, nprefix TEXT default '')
+CREATE OR REPLACE FUNCTION ST_AsKML(version integer, geom geometry, maxdecimaldigits integer DEFAULT 15, nprefix TEXT default '')
 	RETURNS text AS
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index 0726acf51..7330e065a 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -327,14 +327,14 @@ CREATE OR REPLACE FUNCTION st_summary(rast raster)
 CREATE OR REPLACE FUNCTION ST_MemSize(raster)
-	RETURNS int4
+	RETURNS integer
 	AS 'MODULE_PATHNAME', 'RASTER_memsize'
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE;
 -- Constructor ST_MakeEmptyRaster
-CREATE OR REPLACE FUNCTION st_makeemptyraster(width int, height int, upperleftx float8, upperlefty float8, scalex float8, scaley float8, skewx float8, skewy float8, srid int4 DEFAULT 0)
+CREATE OR REPLACE FUNCTION st_makeemptyraster(width int, height int, upperleftx float8, upperlefty float8, scalex float8, scaley float8, skewx float8, skewy float8, srid integer DEFAULT 0)
     RETURNS RASTER
     AS 'MODULE_PATHNAME', 'RASTER_makeEmpty'
@@ -8758,7 +8758,7 @@ END;
 $$ LANGUAGE 'plpgsql' VOLATILE STRICT;
 -- Availability: 2.4.0
-CREATE OR REPLACE FUNCTION st_makeemptycoverage(tilewidth int, tileheight int, width int, height int, upperleftx float8, upperlefty float8, scalex float8, scaley float8, skewx float8, skewy float8, srid int4 DEFAULT 0)
+CREATE OR REPLACE FUNCTION st_makeemptycoverage(tilewidth int, tileheight int, width int, height int, upperleftx float8, upperlefty float8, scalex float8, scaley float8, skewx float8, skewy float8, srid integer DEFAULT 0)
     RETURNS SETOF RASTER AS $$
     DECLARE
         ulx double precision;  -- upper left x of raster
Summary of changes:
 NEWS                          |  3 +++
 libpgcommon/lwgeom_cache.c    |  2 +-
 postgis/geography.sql.in      | 30 +++++++++++-----------
 postgis/legacy.sql.in         | 60 +++++++++++++++++++++----------------------
 raster/rt_pg/rtpostgis.sql.in |  6 ++---
 5 files changed, 52 insertions(+), 49 deletions(-)
hooks/post-receive
