[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta2-24-gadfa7138a
Fri Jul 29 03:23:54 PDT 2022
the project "PostGIS".
       via  adfa7138aba1c486e6bda495e112738892fec94b (commit)
      from  6f3c183e6f81e2c823235d26929166deb2c982d8 (commit)
revisions in full, below.
commit adfa7138aba1c486e6bda495e112738892fec94b
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jul 29 12:23:15 2022 +0200
    Simplify handling of replaced function in upgrade procedure
    Avoids unneeded multiple CREATE OR REPLACE FUNCTION blocks
diff --git a/utils/create_upgrade.pl b/utils/create_upgrade.pl
index 08bf455bd..dfa429dd2 100755
--- a/utils/create_upgrade.pl
+++ b/utils/create_upgrade.pl
@@ -208,40 +208,28 @@ while(<INPUT>)
 DO LANGUAGE 'plpgsql'
 \$postgis_proc_upgrade\$
 DECLARE
-    replaced_proc regprocedure;
-    rec RECORD;
-    new_view_def TEXT;
-    sql TEXT;
     detail TEXT;
 BEGIN
-    -- Check if the old function signature, exists
+    -- Rename the replaced function, to avoid ambiguities.
+    -- The renamed function will eventually be drop.
     BEGIN
-        replaced_proc := '$name($args)'::regprocedure;
+        ALTER FUNCTION $name( $args ) RENAME TO ${renamed};
     EXCEPTION
-    -- Catch the "function does not exist"
     WHEN undefined_function THEN
-        RAISE DEBUG 'Function $name($args) does not exist';
+        RAISE DEBUG 'Replaced function $name($args) does not exist';
     WHEN OTHERS THEN
         GET STACKED DIAGNOSTICS detail := PG_EXCEPTION_DETAIL;
-        RAISE EXCEPTION 'Got % (%)', SQLERRM, SQLSTATE
+        RAISE EXCEPTION 'Attempting to rename replaced function $name($args) got % (%)', SQLERRM, SQLSTATE
             USING DETAIL = detail;
     END;
-    IF replaced_proc IS NULL THEN
-        $def
-        RETURN;
-    END IF;
-    -- Old function signature exists
-    -- Rename old function, to avoid ambiguities and eventually drop
-    ALTER FUNCTION $name( $args ) RENAME TO ${renamed};
 END;
 \$postgis_proc_upgrade\$;
 EOF
+        # TODO: set owner to current owner, in case the new signature exists
         print $def;
Summary of changes:
 utils/create_upgrade.pl | 28 ++++++++--------------------
 1 file changed, 8 insertions(+), 20 deletions(-)
hooks/post-receive
