[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta2-25-gd6d8401ed
Fri Jul 29 11:25:39 PDT 2022
the project "PostGIS".
       via  d6d8401ed968cd40d442e11d384597313a3f6405 (commit)
      from  adfa7138aba1c486e6bda495e112738892fec94b (commit)
revisions in full, below.
commit d6d8401ed968cd40d442e11d384597313a3f6405
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Jul 29 14:25:34 2022 -0400
    Remove overreplacement. Closes #5193 for PostGIS 3.3.0
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 22e336c56..6644db42e 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -545,7 +545,7 @@ CREATE OR REPLACE FUNCTION geometry_gist_sortsupport_2d(internal)
 -- Given a table, column and query geometry, returns the estimate of what proportion
 -- of the table would be returned by a query using the &&/&&& operators. The mode
 -- changes whether the estimate is in x/y only or in all available dimensions.
-CREATE OR REPLACE FUNCTION _postgis_selectivity(tbl pg_catalog.regclass, att_name text, geom geometry, mode text default '2')
+CREATE OR REPLACE FUNCTION _postgis_selectivity(tbl regclass, att_name text, geom geometry, mode text default '2')
 	RETURNS float8
 	AS 'MODULE_PATHNAME', '_postgis_gserialized_sel'
 	LANGUAGE 'c' STRICT PARALLEL SAFE;
Summary of changes:
 postgis/postgis.sql.in | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
