[postgis-tickets] [PostGIS] #5166: Remove Micro (Patch level) from our extension scripts
PostGIS trac at osgeo.org
Mon Jun 6 03:41:02 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 Is there a typo in the original description of this ticket ? I don't
 understand the `postgis--3.0` line, and I see spaces before the
 `--3.4.X.sql` which I'm not sure how to interpret.
 Also, I think Paul idea was to have upgrade scripts look like:
  `postgis-3.1.1--3.1.MAX.sql' or similar ?
 I don't see the benefit of having an upgrade path called `3.3.X--3.3.0`
 otherwise (would look like being open for downgrades) ?
 How does this simplify things ? What problem does it solve ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5166#comment:2>
