[postgis-tickets] [PostGIS] #5166: Remove Micro (Patch level) from our extension scripts
PostGIS trac at osgeo.org
Mon Jun 6 07:12:10 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Description changed by robe:
Old description:
> This will be for PostGIS 3.3.0 moving forward.  We discussed the idea of
> doing that for all minors, but decided that was too drastic.
> So sadly we've still got to carry all those scripts.
> 3.3 will have scripts
> # these all 0 byte
>  postgis--3.0
>  postgis--3.1.0 --3.3.X.sql
>  postgis--3.1.1 --3.3.X.sql
>  postgis--3.1.2 --3.3.X.sql
> postgis--3.2.1 --3.3.X.sql
> # these not 0 byte
> postgis--3.3.X--3.3.sql (not 0 byte)
> postgis-3.3next--3.3.sql (not 0 byte)
> postgis-3.3next-3.3.sql (not 0 byte)
> (the 3.3next 3.3.sql I am thinking if we decided we want our alter
> extension scripts to have CREATE OR REPLACE only for existing and CREATE
> for net-net new, we'd still keep the CREATE OR REPLACE for the 3.3next
> even for net-net new and for the 3.3X--3.3.sql this would be CREATE for
> net-net new functionality.
> and so most we will use 0 byte files as Paul proposed here -
> https://trac.osgeo.org/postgis/wiki/PostGISExtensionPaths#SOLUTION3
> postgis 3.4 would then look like
> # these all 0 byte
>  postgis--3.0
>  postgis--3.1.0 --3.4.X.sql
>  postgis--3.1.1 --3.4.X.sql
>  postgis--3.1.2 --3.4.X.sql
> postgis--3.2.1 --3.4.X.sql
> postgis--3.3 --3.4.X.sql #regardless which 3.3 micro release, no new
> files
> # these not 0 byte
> postgis--3.4.X--3.4.sql (not 0 byte)
> postgis-3.4next--3.4.sql (not 0 byte)
> postgis-3.4-3.4next.sql (not 0 byte)
New description:
 # these all 0 byte
  postgis--3.0.0--3.3.X.sql
  postgis--3.0.1--3.3.X.sql
  postgis--3.1.0--3.3.X.sql
  postgis--3.1.1--3.3.X.sql
  postgis--3.1.2--3.3.X.sql
 postgis--3.2.1--3.3.X.sql
 postgis--3.3.0alpha1--3.3.X.sql
 postgis--3.3.0dev--3.3.X.sql
 # these not 0 byte
 postgis-3.3--3.3next.sql
 # these all 0 byte
  postgis--3.0
  postgis--3.1.0--3.4.X.sql
  postgis--3.1.1--3.4.X.sql
  postgis--3.1.2--3.4.X.sql
 postgis--3.2.1--3.4.X.sql
 postgis--3.3--3.4.X.sql #regardless which 3.3 micro release, no new files
 # these not 0 byte
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5166#comment:3>
