[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-23-g46e6b122f
Fri Jun 10 19:40:22 PDT 2022
the project "PostGIS".
       via  46e6b122f2a96c23aea37f5bcc25cf9ffc944cda (commit)
      from  3f1349d8b85e1ef6be15c8c145c5edf3efd4b9d3 (commit)
revisions in full, below.
commit 46e6b122f2a96c23aea37f5bcc25cf9ffc944cda
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Fri Jun 10 19:40:16 2022 -0700
    Add ST_SimplifyPolygonHull availability
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 65044124a..fe1669985 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -2397,6 +2397,10 @@ FROM (SELECT ST_Buffer('POINT(1 3)', 10,12) As geom) As foo;
         </para>
         <para>To get better results with geometries that contain relatively long line segments, it might be necessary to "segmentize" the input, as shown below.</para>
+        <para>Performed by the GEOS module.</para>
+    	<para>Availability: 3.3.0 - requires GEOS >= 3.11.0 </para>
       </refsection>
       <refsection>
         <title>Examples</title>
Summary of changes:
 doc/reference_processing.xml | 4 ++++
 1 file changed, 4 insertions(+)
hooks/post-receive
