[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-25-g2ff0afaef
Fri Jun 10 21:34:12 PDT 2022
the project "PostGIS".
       via  2ff0afaef752fb447b2922b963ea987f310f0887 (commit)
       via  3f4ee2320bb2e0cf94dd2d6aaee23d5c866d2805 (commit)
      from  46e6b122f2a96c23aea37f5bcc25cf9ffc944cda (commit)
revisions in full, below.
commit 2ff0afaef752fb447b2922b963ea987f310f0887
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Jun 11 00:31:46 2022 -0400
    Add Z option to raster2pgsql that allows for specifying number of rows
    per SQL COPY.  Closes #5170
    Add credits for ST_SimplifyPolygonHull to news, References #5169
diff --git a/NEWS b/NEWS
index ffbaf04fe..88607d974 100644
--- a/NEWS
+++ b/NEWS
@@ -2,7 +2,13 @@ PostGIS 3.3.0dev
 2022/XX/XX
 Changes since PostGIS 3.3.0alpha1
 * Enhancements *
-  - #5158 pgtopo_import / pgtopo_export manpages
+  - #5158, pgtopo_import / pgtopo_export manpages (Sandro Santilli)
+  - #5170, add a -Z option to raster2pgsql to
+    control number of rows per copy statement (Regina Obe)
+* New features *
+  - #5169, ST_SimplifyPolygonHull (requires GEOS 3.11)
+    Paul Ramsey, Martin Davis
 PostGIS 3.3.0alpha1
diff --git a/raster/loader/raster2pgsql.c b/raster/loader/raster2pgsql.c
index e7317c117..cd7f772c5 100644
--- a/raster/loader/raster2pgsql.c
+++ b/raster/loader/raster2pgsql.c
@@ -428,7 +428,7 @@ usage() {
 		"  -N <nodata> NODATA value to use on bands without a NODATA value.\n"
 	printf(_(
-		"  -k  Skip NODATA value checks for each raster band.\n"
+		"  -k  Keep empty tiles by skipping NODATA value checks for each raster band. \n"
 	printf(_(
 		"  -E <endian> Control endianness of generated binary output of\n"
@@ -445,6 +445,10 @@ usage() {
 	printf(_(
 		"  -Y  Use COPY statements instead of INSERT statements.\n"
+	printf(_(
+		"  -Z  Set max insert rows per COPY statement.  Only does something with -Y. Default is 11 if not specified.\n"
 	printf(_(
 		"  -G  Print the supported GDAL raster formats.\n"
@@ -700,6 +704,7 @@ init_config(RTLOADERCFG *config) {
 	config->version = 0;
 	config->transaction = 1;
 	config->copy_statements = 0;
+	config->max_tiles_per_copy = 11;
 static void
@@ -1515,7 +1520,7 @@ build_overview(int idx, RTLOADERCFG *config, RASTERINFO *info, uint32_t ovx, STR
 			GDALClose(hdsDst);
 			/* flush if tileset gets too big */
-			if (tileset->length > 10) {
+			if (tileset->length >= config->max_tiles_per_copy) {
 				if (!insert_records(
 					config->schema, ovtable, config->raster_column,
 					(config->file_column ? config->rt_filename[idx] : NULL), config->file_column_name,
@@ -1842,7 +1847,7 @@ convert_raster(int idx, RTLOADERCFG *config, RASTERINFO *info, STRINGBUFFER *til
 					append_stringbuffer(tileset, hex);
+				if (tileset->length >= config->max_tiles_per_copy ) {
 						config->schema, config->table, config->raster_column,
@@ -1965,7 +1970,7 @@ convert_raster(int idx, RTLOADERCFG *config, RASTERINFO *info, STRINGBUFFER *til
 				GDALClose(hdsDst);
@@ -2596,6 +2601,11 @@ main(int argc, char **argv) {
 		else if (CSEQUAL(argv[argit], "-Y")) {
 			config->copy_statements = 1;
+		/* max tiles per copy */
+		else if (CSEQUAL(argv[argit], "-Z") && argit < argc - 1) {
+			config->max_tiles_per_copy = atof(argv[++argit]);
 		/* GDAL formats */
 		else if (CSEQUAL(argv[argit], "-G")) {
 			uint32_t drv_count = 0;
diff --git a/raster/loader/raster2pgsql.h b/raster/loader/raster2pgsql.h
index 85d5a1a35..62f4abec6 100644
--- a/raster/loader/raster2pgsql.h
+++ b/raster/loader/raster2pgsql.h
@@ -159,6 +159,9 @@ typedef struct raster_loader_config {
 	/* use COPY instead of INSERT */
 	int copy_statements;
+	/** max tiles per copy */
+	int max_tiles_per_copy;
 } RTLOADERCFG;
 typedef struct rasterinfo_t {
diff --git a/raster/test/regress/Makefile.in b/raster/test/regress/Makefile.in
index 6492bb99c..4cf4dc03e 100644
--- a/raster/test/regress/Makefile.in
+++ b/raster/test/regress/Makefile.in
@@ -161,7 +161,8 @@ TEST_LOADER = \
 	loader/Tiled10x10Copy \
 	loader/Tiled8x8 \
 	loader/TiledAuto \
-	loader/TiledAutoSkipNoData
+	loader/TiledAutoSkipNoData \
+	loader/TiledAutoZCopy
 RASTER_TESTS := $(TEST_FIRST) \
 	$(TEST_METADATA) $(TEST_IO) $(TEST_BASIC_FUNC) \
diff --git a/raster/test/regress/loader/TiledAutoZCopy.opts b/raster/test/regress/loader/TiledAutoZCopy.opts
new file mode 100644
index 000000000..c0810c3e4
--- /dev/null
+++ b/raster/test/regress/loader/TiledAutoZCopy.opts
@@ -0,0 +1 @@
+-t auto -C -Y -Z 20
diff --git a/raster/test/regress/loader/TiledAutoZCopy.select.expected b/raster/test/regress/loader/TiledAutoZCopy.select.expected
index 000000000..8351c1939
--- /dev/null
+++ b/raster/test/regress/loader/TiledAutoZCopy.select.expected
@@ -0,0 +1 @@
+14
diff --git a/raster/test/regress/loader/TiledAutoZCopy.select.sql b/raster/test/regress/loader/TiledAutoZCopy.select.sql
index 000000000..81d831770
--- /dev/null
+++ b/raster/test/regress/loader/TiledAutoZCopy.select.sql
@@ -0,0 +1 @@
+select count(*) from loadedrast;
diff --git a/raster/test/regress/loader/TiledAutoZCopy.sql b/raster/test/regress/loader/TiledAutoZCopy.sql
--- /dev/null
+++ b/raster/test/regress/loader/TiledAutoZCopy.sql
@@ -0,0 +1 @@
diff --git a/raster/test/regress/loader/TiledAutoZCopy.tif.ref b/raster/test/regress/loader/TiledAutoZCopy.tif.ref
index 000000000..a7c066dc8
--- /dev/null
+++ b/raster/test/regress/loader/TiledAutoZCopy.tif.ref
@@ -0,0 +1 @@
+testraster2.tif
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index 7dccaeb45..92676bb42 100644
--- a/raster/test/regress/tests.mk
+++ b/raster/test/regress/tests.mk
@@ -133,7 +133,8 @@ RASTER_TEST_LOADER = \
 	$(topsrcdir)/raster/test/regress/loader/Tiled10x10Copy \
 	$(topsrcdir)/raster/test/regress/loader/Tiled8x8 \
 	$(topsrcdir)/raster/test/regress/loader/TiledAuto \
-	$(topsrcdir)/raster/test/regress/loader/TiledAutoSkipNoData
+	$(topsrcdir)/raster/test/regress/loader/TiledAutoSkipNoData \
+	$(topsrcdir)/raster/test/regress/loader/TiledAutoZCopy
 RASTER_TESTS := $(RASTER_TEST_FIRST) \
 	$(RASTER_TEST_METADATA) $(RASTER_TEST_IO) $(RASTER_TEST_BASIC_FUNC) \
commit 3f4ee2320bb2e0cf94dd2d6aaee23d5c866d2805
Date:   Fri Jun 10 23:47:06 2022 -0400
    Change berries to test against PG15
diff --git a/ci/berrie/configs.sh b/ci/berrie/configs.sh
index ca0a5ca46..b91a960a3 100644
--- a/ci/berrie/configs.sh
+++ b/ci/berrie/configs.sh
@@ -2,7 +2,7 @@ export WORKSPACE=/home/jenkins/workspace
 export GEOS_VER=3.11.0
 export OS_BUILD=32
-export PG_VER=14
+export PG_VER=15
 export GEOS_PATH=${WORKSPACE}/geos/rel-${GEOS_VER}
 #export GEOS_PATH=~/geos/rel-${GEOS_VER}
 export PGPATH=${WORKSPACE}/pg/label/${label}/rel/pg${PG_VER}w${OS_BUILD}
diff --git a/ci/berrie64/configs.sh b/ci/berrie64/configs.sh
index 5a7f90599..aa6d39049 100644
--- a/ci/berrie64/configs.sh
+++ b/ci/berrie64/configs.sh
 export OS_BUILD=64
-export PG_VER=14
+export PG_VER=15
Summary of changes:
 NEWS                                                   |  8 +++++++-
 ci/berrie/configs.sh                                   |  2 +-
 ci/berrie64/configs.sh                                 |  2 +-
 raster/loader/raster2pgsql.c                           | 18 ++++++++++++++----
 raster/loader/raster2pgsql.h                           |  3 +++
 raster/test/regress/Makefile.in                        |  3 ++-
 raster/test/regress/loader/TiledAutoZCopy.opts         |  1 +
 ....select.expected => TiledAutoZCopy.select.expected} |  0
 ...{TiledAuto.select.sql => TiledAutoZCopy.select.sql} |  0
 .../{TiledAuto.select.sql => TiledAutoZCopy.sql}       |  0
 .../{TiledAuto.tif.ref => TiledAutoZCopy.tif.ref}      |  0
 raster/test/regress/tests.mk                           |  3 ++-
 12 files changed, 31 insertions(+), 9 deletions(-)
 create mode 100644 raster/test/regress/loader/TiledAutoZCopy.opts
 copy raster/test/regress/loader/{TiledAutoSkipNoData.select.expected => TiledAutoZCopy.select.expected} (100%)
 copy raster/test/regress/loader/{TiledAuto.select.sql => TiledAutoZCopy.select.sql} (100%)
 copy raster/test/regress/loader/{TiledAuto.select.sql => TiledAutoZCopy.sql} (100%)
 copy raster/test/regress/loader/{TiledAuto.tif.ref => TiledAutoZCopy.tif.ref} (100%)
hooks/post-receive
