[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-72-ga3afe5ff4
Thu Jun 16 07:39:39 PDT 2022
the project "PostGIS".
       via  a3afe5ff4502b172d3edc20421fc6facb01ae814 (commit)
      from  6c5acf038ebf4b3c720d8a2cfdb5991fb9aa78eb (commit)
revisions in full, below.
commit a3afe5ff4502b172d3edc20421fc6facb01ae814
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jun 16 07:39:22 2022 -0700
    Revert "Merge branch 'lbartoletti-fix_cutpaste_isinstdportalcache'"
    This reverts commit 6c5acf038ebf4b3c720d8a2cfdb5991fb9aa78eb, reversing
    changes made to 08dcf2aa5f2e0bd9ee195183644d4c3ee8cad6c4.
diff --git a/.github/workflows/msys.yml b/.github/workflows/msys.yml
deleted file mode 100644
index ee705ff0a..000000000
--- a/.github/workflows/msys.yml
+++ /dev/null
@@ -1,53 +0,0 @@
-name: MSYS2
-on: [push, pull_request]
-jobs:
-  mingw:
-    name: mingw
-    runs-on: windows-latest
-    strategy:
-      matrix:
-        #fail-fast: false
-        include:
-          # mingw32 fail: addface
-          - { icon: '🟦', sys: mingw64 }
-          - { icon: '🟨', sys: ucrt64  } # Experimental!
-          - { icon: '🟧', sys: clang64 } # Experimental!
-    defaults:
-      run:
-        shell: msys2 {0}
-    steps:
-      # see https://github.com/msys2/setup-msys2
-    - name: checkout
-      uses: actions/checkout at v2
-    - name: '${{ matrix.icon }} Setup MSYS2'
-      uses: msys2/setup-msys2 at v2
-      with:
-        msystem: ${{ matrix.sys }}
-        update: true
-        install: >-
-          git
-          make
-          bison
-        pacboy: >-
-          toolchain:p
-          autotools:p
-          geos:p
-          proj:p
-          gdal:p
-          sfcgal:p
-          json-c:p
-          gettext:p
-          libxml2:p
-          postgresql:p
-    - name: '🚧 Build TOOL'
-      run: |
-        MSYSTEM= /${{ matrix.sys }}/bin/initdb -D D:/a/_tmp/psql
-        MSYSTEM= /${{ matrix.sys }}/bin/pg_ctl -D D:/a/_tmp/psql -l logfile start
-        MSYSTEM= /${{ matrix.sys }}/bin/pg_ctl register -N "postgresql" -U "NT AUTHORITY\NetworkService" -D D:/a/_tmp/psql -w -S demand
-        MSYSTEM= /${{ matrix.sys }}/bin/createuser -U `whoami` -s postgres
-        MSYSTEM= ./autogen.sh
-        MSYSTEM= ./configure --with-pgconfig=/${{ matrix.sys }}/bin/pg_config --without-protobuf
-        MSYSTEM= make
-        MSYSTEM= make check
diff --git a/NEWS b/NEWS
index 7f8716a29..f4a2690c9 100644
--- a/NEWS
+++ b/NEWS
@@ -3,9 +3,8 @@ PostGIS 3.3.0dev
 Changes since PostGIS 3.3.0alpha1
 * Enhancements *
   - #5158, pgtopo_import / pgtopo_export manpages (Sandro Santilli)
-  - #5170, add a optional max_rows_per_copy to -Y option to raster2pgsql to
-    control number of rows per copy statement.
-    Default to 50 when not specified (Regina Obe)
+  - #5170, add a -Z option to raster2pgsql to
+    control number of rows per copy statement (Regina Obe)
   - #4939, #5161, ST_LineMerge now has option to keep the directions of input linestrings,
     useful when processing road graphs. Requires GEOS 3.11. (Sergei Shoulbakov)
   - #5039, postgis_tiger_geocoder TIGER 2021 (Regina Obe)
diff --git a/configure.ac b/configure.ac
index 86feb8c47..695077429 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1537,6 +1537,7 @@ if test "x$with_raster" != "xno"; then
 		raster/loader/Makefile \
 		raster/test/Makefile \
 		raster/test/cunit/Makefile \
+		raster/test/regress/Makefile \
 		raster/scripts/Makefile \
 		raster/scripts/python/Makefile"
diff --git a/doc/using_raster_dataman.xml b/doc/using_raster_dataman.xml
index a344468fd..8f6e18ce9 100644
--- a/doc/using_raster_dataman.xml
+++ b/doc/using_raster_dataman.xml
@@ -284,11 +284,18 @@
                  </varlistentry>
                <varlistentry>
-                  <term>-Y  <varname>max_rows_per_copy=50</varname></term>
+                  <term>-Y</term>
                   <listitem>
                     <para>
-                      Use copy statements instead of insert statements.  Optionally specify <varname>max_rows_per_copy</varname> statement.
-                      Defaults to 50 when not specified.</para>
+                      Use copy statements instead of insert statements.</para>
+                  </listitem>
+                </varlistentry>
+                <varlistentry>
+                  <term>-Z <varname>max_rows_per_copy</varname></term>
+                  <listitem>
+                    <para>
+                      Specify max number of rows per copy statement. Only relevant when combined with -Y.</para>
                   </listitem>
                 </varlistentry>
diff --git a/extensions/address_standardizer/std_pg_hash.c b/extensions/address_standardizer/std_pg_hash.c
index f98ae4e9b..06907af0f 100644
--- a/extensions/address_standardizer/std_pg_hash.c
+++ b/extensions/address_standardizer/std_pg_hash.c
@@ -226,8 +226,8 @@ IsInStdPortalCache(StdPortalCache *STDCache,  char *lextab, char *gaztab, char *
     for (i=0; i<STD_CACHE_ITEMS; i++) {
         StdCacheItem *ci = &STDCache->StdCache[i];
         if (ci->lextab && !strcmp(ci->lextab, lextab) &&
-            ci->gaztab && !strcmp(ci->gaztab, gaztab) &&
-            ci->rultab && !strcmp(ci->rultab, rultab))
+            ci->lextab && !strcmp(ci->gaztab, gaztab) &&
+            ci->lextab && !strcmp(ci->rultab, rultab))
                 return TRUE;
diff --git a/raster/loader/raster2pgsql.c b/raster/loader/raster2pgsql.c
index 3c3edd368..9f95a395e 100644
--- a/raster/loader/raster2pgsql.c
+++ b/raster/loader/raster2pgsql.c
@@ -704,7 +704,7 @@ init_config(RTLOADERCFG *config) {
 	config->version = 0;
 	config->transaction = 1;
 	config->copy_statements = 0;
-	config->max_tiles_per_copy = 50;
+	config->max_tiles_per_copy = 11;
 static void
@@ -2600,17 +2600,12 @@ main(int argc, char **argv) {
 		/* COPY statements */
 		else if (CSEQUAL(argv[argit], "-Y")) {
 			config->copy_statements = 1;
-			/* max tiles per copy */
-			if ( argit < argc - 1) {
-				optarg = argv[argit + 1];
-				if (atoi(optarg) > 0 ) {
-					config->max_tiles_per_copy = atoi(optarg);
-					++argit;
+		/* max tiles per copy */
+		else if (CSEQUAL(argv[argit], "-Z") && argit < argc - 1) {
+			config->max_tiles_per_copy = atoi(argv[++argit]);
 		/* GDAL formats */
 		else if (CSEQUAL(argv[argit], "-G")) {
 			uint32_t drv_count = 0;
diff --git a/raster/test/Makefile.in b/raster/test/Makefile.in
index fd0ae4021..033cde4e0 100644
--- a/raster/test/Makefile.in
+++ b/raster/test/Makefile.in
@@ -23,6 +23,7 @@ check-regress:
 clean:
 	$(MAKE) -C cunit $@
+	$(MAKE) -C regress $@
 distclean: clean
 	$(MAKE) -C cunit $@
diff --git a/raster/test/regress/Makefile.in b/raster/test/regress/Makefile.in
new file mode 100644
index 000000000..4cf4dc03e
--- /dev/null
+++ b/raster/test/regress/Makefile.in
@@ -0,0 +1,194 @@
+# Copyright (c) 2009-2022 Sandro Santilli <strk at kbt.io>
+# Copyright (c) 2009 Pierre Racine <pierre.racine at sbf.ulaval.ca>
+# Copyright (c) 2011 Jorge Arevalo <jorge.arevalo at deimos-space.com>
+# Copyright (c) 2011-2013 Regents of the University of California
+#   <bkpark at ucdavis.edu>
+# This is free software; you can redistribute and/or modify it under
+# the terms of the GNU General Public Licence. See the COPYING file.
+# This program is free software; you can redistribute it and/or
+# modify it under the terms of the GNU General Public License
+# as published by the Free Software Foundation; either version 2
+# of the License, or (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software Foundation,
+# Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
+top_srcdir = @top_srcdir@
+srcdir = @srcdir@
+top_builddir = @top_builddir@
+POSTGIS_SRC=../../..
+PERL=@PERL@
+# MingW hack: rather than use PGSQL_BINDIR directly, we change
+# to the directory and then use "pwd" to return the path. This
+# ensures that the returned path is in MSYS format, otherwise
+# colons in drive letters will break PATH.
+PGSQL_BINDIR=$(shell cd "@PGSQL_BINDIR@" && pwd)
+# Where we put our regression installation
+REGRESS_INSTALLDIR = $(realpath $(top_builddir) )/regress/00-regress-install
+# Put path from pg_config into front of search path
+PATH := $(PGSQL_BINDIR):$(PATH)
+export PATH
+TEST_FIRST = \
+	check_gdal \
+	load_outdb
+TEST_LAST = \
+	clean
+TEST_METADATA = \
+	check_raster_columns \
+	check_raster_overviews
+TEST_IO = \
+	rt_io
+TEST_BASIC_FUNC = \
+	rt_bytea \
+	rt_wkb \
+	box3d \
+	rt_addband \
+	rt_band \
+	rt_tile
+TEST_PROPS = \
+	rt_dimensions \
+	rt_scale \
+	rt_pixelsize \
+	rt_upperleft \
+	rt_rotation \
+	rt_georeference \
+	rt_set_properties \
+	rt_isempty \
+	rt_hasnoband \
+	rt_metadata \
+	rt_rastertoworldcoord \
+	rt_worldtorastercoord \
+	rt_convexhull \
+	rt_envelope
+TEST_BANDPROPS = \
+	rt_band_properties \
+	rt_set_band_properties \
+	rt_pixelaspolygons \
+	rt_pixelaspoints \
+	rt_pixelascentroids \
+	rt_setvalues_array \
+	rt_summarystats \
+	rt_count \
+	rt_histogram \
+	rt_quantile \
+	rt_valuecount \
+	rt_valuepercent \
+	rt_bandmetadata \
+	rt_pixelvalue \
+	rt_neighborhood \
+	rt_nearestvalue \
+	rt_pixelofvalue \
+	rt_polygon \
+	rt_setbandpath
+TEST_UTILITY = \
+	rt_utility \
+	rt_fromgdalraster \
+	rt_asgdalraster \
+	rt_astiff \
+	rt_asjpeg \
+	rt_aspng \
+	rt_reclass \
+	rt_gdalwarp \
+	rt_asraster \
+	rt_dumpvalues \
+	rt_makeemptycoverage \
+	rt_createoverview
+TEST_MAPALGEBRA = \
+	rt_mapalgebraexpr \
+	rt_mapalgebrafct \
+	rt_mapalgebraexpr_2raster \
+	rt_mapalgebrafct_2raster \
+	rt_mapalgebrafctngb \
+	rt_mapalgebrafctngb_userfunc \
+	rt_intersection \
+	rt_clip \
+	rt_mapalgebra \
+	rt_mapalgebra_expr \
+	rt_mapalgebra_mask \
+	rt_union \
+	rt_invdistweight4ma \
+	rt_4ma \
+	rt_setvalues_geomval \
+	rt_elevation_functions \
+	rt_colormap \
+	rt_grayscale
+TEST_SREL = \
+	rt_gist_relationships \
+	rt_intersects \
+	rt_samealignment \
+	rt_geos_relationships \
+	rt_iscoveragetile
+TEST_BUGS = \
+	bug_test_car5 \
+	permitted_gdal_drivers \
+	tickets
+TEST_LOADER = \
+	loader/Basic \
+	loader/Projected \
+	loader/BasicCopy \
+	loader/BasicFilename \
+	loader/BasicOutDB \
+	loader/Tiled10x10 \
+	loader/Tiled10x10Copy \
+	loader/Tiled8x8 \
+	loader/TiledAuto \
+	loader/TiledAutoSkipNoData \
+	loader/TiledAutoZCopy
+RASTER_TESTS := $(TEST_FIRST) \
+	$(TEST_METADATA) $(TEST_IO) $(TEST_BASIC_FUNC) \
+	$(TEST_PROPS) $(TEST_BANDPROPS) \
+	$(TEST_UTILITY) $(TEST_MAPALGEBRA) $(TEST_SREL) \
+	$(TEST_BUGS) \
+	$(TEST_LOADER) \
+	$(TEST_LAST)
+all:
+	@echo "Use 'make check' to run all tests"
+distclean: clean
+	rm -f Makefile
+clean:
+	$(RM) -f rtpostgis.sql
+rtpostgis.sql: ../../rt_pg/rtpostgis.sql
+	$(PERL) -lpe "s'\\\$$libdir'$(REGRESS_INSTALLDIR)/lib'g" $< > $@
+# TODO: drop this variable, use top_srcdir directly
+topsrcdir = $(top_srcdir)
+include $(srcdir)/tests.mk
+include $(top_srcdir)/regress/runtest.mk
+check: check-regress
diff --git a/raster/test/regress/loader/TiledAutoCopyn.opts b/raster/test/regress/loader/TiledAutoCopyn.opts
index a3e30dafa..000000000
--- a/raster/test/regress/loader/TiledAutoCopyn.opts
+++ /dev/null
@@ -1 +0,0 @@
--t auto -C -Y 20
diff --git a/raster/test/regress/loader/TiledAutoZCopy.opts b/raster/test/regress/loader/TiledAutoZCopy.opts
index 000000000..c0810c3e4
--- /dev/null
+++ b/raster/test/regress/loader/TiledAutoZCopy.opts
@@ -0,0 +1 @@
+-t auto -C -Y -Z 20
diff --git a/raster/test/regress/loader/TiledAutoCopyn.select.expected b/raster/test/regress/loader/TiledAutoZCopy.select.expected
similarity index 100%
rename from raster/test/regress/loader/TiledAutoCopyn.select.expected
rename to raster/test/regress/loader/TiledAutoZCopy.select.expected
diff --git a/raster/test/regress/loader/TiledAutoCopyn.select.sql b/raster/test/regress/loader/TiledAutoZCopy.select.sql
copy from raster/test/regress/loader/TiledAutoCopyn.select.sql
copy to raster/test/regress/loader/TiledAutoZCopy.select.sql
diff --git a/raster/test/regress/loader/TiledAutoCopyn.select.sql b/raster/test/regress/loader/TiledAutoZCopy.sql
rename from raster/test/regress/loader/TiledAutoCopyn.select.sql
rename to raster/test/regress/loader/TiledAutoZCopy.sql
diff --git a/raster/test/regress/loader/TiledAutoCopyn.tif.ref b/raster/test/regress/loader/TiledAutoZCopy.tif.ref
rename from raster/test/regress/loader/TiledAutoCopyn.tif.ref
rename to raster/test/regress/loader/TiledAutoZCopy.tif.ref
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index 2c5d006bc..92676bb42 100644
--- a/raster/test/regress/tests.mk
+++ b/raster/test/regress/tests.mk
@@ -134,7 +134,7 @@ RASTER_TEST_LOADER = \
 	$(topsrcdir)/raster/test/regress/loader/Tiled8x8 \
 	$(topsrcdir)/raster/test/regress/loader/TiledAuto \
 	$(topsrcdir)/raster/test/regress/loader/TiledAutoSkipNoData \
-	$(topsrcdir)/raster/test/regress/loader/TiledAutoCopyn
+	$(topsrcdir)/raster/test/regress/loader/TiledAutoZCopy
 RASTER_TESTS := $(RASTER_TEST_FIRST) \
 	$(RASTER_TEST_METADATA) $(RASTER_TEST_IO) $(RASTER_TEST_BASIC_FUNC) \
Summary of changes:
 .github/workflows/msys.yml                         |  53 ------
 NEWS                                               |   5 +-
 configure.ac                                       |   1 +
 doc/using_raster_dataman.xml                       |  13 +-
 extensions/address_standardizer/std_pg_hash.c      |   4 +-
 raster/loader/raster2pgsql.c                       |  15 +-
 raster/test/Makefile.in                            |   1 +
 raster/test/regress/Makefile.in                    | 194 +++++++++++++++++++++
 raster/test/regress/loader/TiledAutoCopyn.opts     |   1 -
 raster/test/regress/loader/TiledAutoZCopy.opts     |   1 +
 ...ect.expected => TiledAutoZCopy.select.expected} |   0
 ...oCopyn.select.sql => TiledAutoZCopy.select.sql} |   0
 .../{TiledAuto.select.sql => TiledAutoZCopy.sql}   |   0
 ...ledAutoCopyn.tif.ref => TiledAutoZCopy.tif.ref} |   0
 raster/test/regress/tests.mk                       |   2 +-
 15 files changed, 217 insertions(+), 73 deletions(-)
 delete mode 100644 .github/workflows/msys.yml
 create mode 100644 raster/test/regress/Makefile.in
 delete mode 100644 raster/test/regress/loader/TiledAutoCopyn.opts
 create mode 100644 raster/test/regress/loader/TiledAutoZCopy.opts
 rename raster/test/regress/loader/{TiledAutoCopyn.select.expected => TiledAutoZCopy.select.expected} (100%)
 rename raster/test/regress/loader/{TiledAutoCopyn.select.sql => TiledAutoZCopy.select.sql} (100%)
 copy raster/test/regress/loader/{TiledAuto.select.sql => TiledAutoZCopy.sql} (100%)
 rename raster/test/regress/loader/{TiledAutoCopyn.tif.ref => TiledAutoZCopy.tif.ref} (100%)
hooks/post-receive
