[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-73-g6bbcbef15
Thu Jun 16 07:55:10 PDT 2022
the project "PostGIS".
       via  6bbcbef15ea2453add883d25058b38b5774d0303 (commit)
      from  a3afe5ff4502b172d3edc20421fc6facb01ae814 (commit)
revisions in full, below.
commit 6bbcbef15ea2453add883d25058b38b5774d0303
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Jun 16 00:52:37 2022 -0400
    Replace -Z option as  optional argument to -Y option.
    Increase default of copy to 50 rows from 11.  References #5170
diff --git a/NEWS b/NEWS
index f4a2690c9..7f8716a29 100644
--- a/NEWS
+++ b/NEWS
@@ -3,8 +3,9 @@ PostGIS 3.3.0dev
 Changes since PostGIS 3.3.0alpha1
 * Enhancements *
   - #5158, pgtopo_import / pgtopo_export manpages (Sandro Santilli)
-  - #5170, add a -Z option to raster2pgsql to
-    control number of rows per copy statement (Regina Obe)
+  - #5170, add a optional max_rows_per_copy to -Y option to raster2pgsql to
+    control number of rows per copy statement.
+    Default to 50 when not specified (Regina Obe)
   - #4939, #5161, ST_LineMerge now has option to keep the directions of input linestrings,
     useful when processing road graphs. Requires GEOS 3.11. (Sergei Shoulbakov)
   - #5039, postgis_tiger_geocoder TIGER 2021 (Regina Obe)
diff --git a/doc/using_raster_dataman.xml b/doc/using_raster_dataman.xml
index 8f6e18ce9..a344468fd 100644
--- a/doc/using_raster_dataman.xml
+++ b/doc/using_raster_dataman.xml
@@ -284,18 +284,11 @@
                  </varlistentry>
                <varlistentry>
-                  <term>-Y</term>
+                  <term>-Y  <varname>max_rows_per_copy=50</varname></term>
                   <listitem>
                     <para>
-                      Use copy statements instead of insert statements.</para>
-                  </listitem>
-                </varlistentry>
-                <varlistentry>
-                  <term>-Z <varname>max_rows_per_copy</varname></term>
-                  <listitem>
-                    <para>
-                      Specify max number of rows per copy statement. Only relevant when combined with -Y.</para>
+                      Use copy statements instead of insert statements.  Optionally specify <varname>max_rows_per_copy</varname> statement.
+                      Defaults to 50 when not specified.</para>
                   </listitem>
                 </varlistentry>
diff --git a/raster/loader/raster2pgsql.c b/raster/loader/raster2pgsql.c
index 9f95a395e..3c3edd368 100644
--- a/raster/loader/raster2pgsql.c
+++ b/raster/loader/raster2pgsql.c
@@ -704,7 +704,7 @@ init_config(RTLOADERCFG *config) {
 	config->version = 0;
 	config->transaction = 1;
 	config->copy_statements = 0;
-	config->max_tiles_per_copy = 11;
+	config->max_tiles_per_copy = 50;
 static void
@@ -2600,12 +2600,17 @@ main(int argc, char **argv) {
 		/* COPY statements */
 		else if (CSEQUAL(argv[argit], "-Y")) {
 			config->copy_statements = 1;
+			/* max tiles per copy */
+			if ( argit < argc - 1) {
+				optarg = argv[argit + 1];
+				if (atoi(optarg) > 0 ) {
+					config->max_tiles_per_copy = atoi(optarg);
+					++argit;
-		/* max tiles per copy */
-		else if (CSEQUAL(argv[argit], "-Z") && argit < argc - 1) {
-			config->max_tiles_per_copy = atoi(argv[++argit]);
 		/* GDAL formats */
 		else if (CSEQUAL(argv[argit], "-G")) {
 			uint32_t drv_count = 0;
diff --git a/raster/test/regress/loader/TiledAutoCopyn.opts b/raster/test/regress/loader/TiledAutoCopyn.opts
new file mode 100644
index 000000000..a3e30dafa
--- /dev/null
+++ b/raster/test/regress/loader/TiledAutoCopyn.opts
@@ -0,0 +1 @@
+-t auto -C -Y 20
diff --git a/raster/test/regress/loader/TiledAutoZCopy.select.expected b/raster/test/regress/loader/TiledAutoCopyn.select.expected
similarity index 100%
rename from raster/test/regress/loader/TiledAutoZCopy.select.expected
rename to raster/test/regress/loader/TiledAutoCopyn.select.expected
diff --git a/raster/test/regress/loader/TiledAutoZCopy.select.sql b/raster/test/regress/loader/TiledAutoCopyn.select.sql
rename from raster/test/regress/loader/TiledAutoZCopy.select.sql
rename to raster/test/regress/loader/TiledAutoCopyn.select.sql
diff --git a/raster/test/regress/loader/TiledAutoZCopy.tif.ref b/raster/test/regress/loader/TiledAutoCopyn.tif.ref
rename from raster/test/regress/loader/TiledAutoZCopy.tif.ref
rename to raster/test/regress/loader/TiledAutoCopyn.tif.ref
diff --git a/raster/test/regress/loader/TiledAutoZCopy.opts b/raster/test/regress/loader/TiledAutoZCopy.opts
deleted file mode 100644
index c0810c3e4..000000000
--- a/raster/test/regress/loader/TiledAutoZCopy.opts
+++ /dev/null
@@ -1 +0,0 @@
--t auto -C -Y -Z 20
diff --git a/raster/test/regress/loader/TiledAutoZCopy.sql b/raster/test/regress/loader/TiledAutoZCopy.sql
index 81d831770..000000000
--- a/raster/test/regress/loader/TiledAutoZCopy.sql
+++ /dev/null
@@ -1 +0,0 @@
-select count(*) from loadedrast;
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index 92676bb42..2c5d006bc 100644
--- a/raster/test/regress/tests.mk
+++ b/raster/test/regress/tests.mk
@@ -134,7 +134,7 @@ RASTER_TEST_LOADER = \
 	$(topsrcdir)/raster/test/regress/loader/Tiled8x8 \
 	$(topsrcdir)/raster/test/regress/loader/TiledAuto \
 	$(topsrcdir)/raster/test/regress/loader/TiledAutoSkipNoData \
-	$(topsrcdir)/raster/test/regress/loader/TiledAutoZCopy
+	$(topsrcdir)/raster/test/regress/loader/TiledAutoCopyn
 RASTER_TESTS := $(RASTER_TEST_FIRST) \
 	$(RASTER_TEST_METADATA) $(RASTER_TEST_IO) $(RASTER_TEST_BASIC_FUNC) \
Summary of changes:
 NEWS                                                      |  5 +++--
 doc/using_raster_dataman.xml                              | 13 +++----------
 raster/loader/raster2pgsql.c                              | 15 ++++++++++-----
 raster/test/regress/loader/TiledAutoCopyn.opts            |  1 +
 ...opy.select.expected => TiledAutoCopyn.select.expected} |  0
 ...iledAutoZCopy.select.sql => TiledAutoCopyn.select.sql} |  0
 .../{TiledAutoZCopy.tif.ref => TiledAutoCopyn.tif.ref}    |  0
 raster/test/regress/loader/TiledAutoZCopy.opts            |  1 -
 raster/test/regress/loader/TiledAutoZCopy.sql             |  1 -
 raster/test/regress/tests.mk                              |  2 +-
 10 files changed, 18 insertions(+), 20 deletions(-)
 create mode 100644 raster/test/regress/loader/TiledAutoCopyn.opts
 rename raster/test/regress/loader/{TiledAutoZCopy.select.expected => TiledAutoCopyn.select.expected} (100%)
 rename raster/test/regress/loader/{TiledAutoZCopy.select.sql => TiledAutoCopyn.select.sql} (100%)
 rename raster/test/regress/loader/{TiledAutoZCopy.tif.ref => TiledAutoCopyn.tif.ref} (100%)
 delete mode 100644 raster/test/regress/loader/TiledAutoZCopy.opts
 delete mode 100644 raster/test/regress/loader/TiledAutoZCopy.sql
hooks/post-receive
