[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-74-gdf6221f03
Thu Jun 16 07:55:51 PDT 2022
the project "PostGIS".
       via  df6221f03f9b538b106cee9d1230cffceb30339f (commit)
      from  6bbcbef15ea2453add883d25058b38b5774d0303 (commit)
revisions in full, below.
commit df6221f03f9b538b106cee9d1230cffceb30339f
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Jun 16 01:08:39 2022 -0400
    Get rid of obsolete raster regress makefile. Was replaced by tests.mk a while ago
diff --git a/configure.ac b/configure.ac
index 695077429..86feb8c47 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1537,7 +1537,6 @@ if test "x$with_raster" != "xno"; then
 		raster/loader/Makefile \
 		raster/test/Makefile \
 		raster/test/cunit/Makefile \
-		raster/test/regress/Makefile \
 		raster/scripts/Makefile \
 		raster/scripts/python/Makefile"
diff --git a/raster/test/regress/Makefile.in b/raster/test/regress/Makefile.in
deleted file mode 100644
index 4cf4dc03e..000000000
--- a/raster/test/regress/Makefile.in
+++ /dev/null
@@ -1,194 +0,0 @@
-# Copyright (c) 2009-2022 Sandro Santilli <strk at kbt.io>
-# Copyright (c) 2009 Pierre Racine <pierre.racine at sbf.ulaval.ca>
-# Copyright (c) 2011 Jorge Arevalo <jorge.arevalo at deimos-space.com>
-# Copyright (c) 2011-2013 Regents of the University of California
-#   <bkpark at ucdavis.edu>
-# This is free software; you can redistribute and/or modify it under
-# the terms of the GNU General Public Licence. See the COPYING file.
-# This program is free software; you can redistribute it and/or
-# modify it under the terms of the GNU General Public License
-# as published by the Free Software Foundation; either version 2
-# of the License, or (at your option) any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software Foundation,
-# Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
-top_srcdir = @top_srcdir@
-srcdir = @srcdir@
-top_builddir = @top_builddir@
-POSTGIS_SRC=../../..
-PERL=@PERL@
-# MingW hack: rather than use PGSQL_BINDIR directly, we change
-# to the directory and then use "pwd" to return the path. This
-# ensures that the returned path is in MSYS format, otherwise
-# colons in drive letters will break PATH.
-PGSQL_BINDIR=$(shell cd "@PGSQL_BINDIR@" && pwd)
-# Where we put our regression installation
-REGRESS_INSTALLDIR = $(realpath $(top_builddir) )/regress/00-regress-install
-# Put path from pg_config into front of search path
-PATH := $(PGSQL_BINDIR):$(PATH)
-export PATH
-TEST_FIRST = \
-	check_gdal \
-	load_outdb
-TEST_LAST = \
-	clean
-TEST_METADATA = \
-	check_raster_columns \
-	check_raster_overviews
-TEST_IO = \
-	rt_io
-TEST_BASIC_FUNC = \
-	rt_bytea \
-	rt_wkb \
-	box3d \
-	rt_addband \
-	rt_band \
-	rt_tile
-TEST_PROPS = \
-	rt_dimensions \
-	rt_scale \
-	rt_pixelsize \
-	rt_upperleft \
-	rt_rotation \
-	rt_georeference \
-	rt_set_properties \
-	rt_isempty \
-	rt_hasnoband \
-	rt_metadata \
-	rt_rastertoworldcoord \
-	rt_worldtorastercoord \
-	rt_convexhull \
-	rt_envelope
-TEST_BANDPROPS = \
-	rt_band_properties \
-	rt_set_band_properties \
-	rt_pixelaspolygons \
-	rt_pixelaspoints \
-	rt_pixelascentroids \
-	rt_setvalues_array \
-	rt_summarystats \
-	rt_count \
-	rt_histogram \
-	rt_quantile \
-	rt_valuecount \
-	rt_valuepercent \
-	rt_bandmetadata \
-	rt_pixelvalue \
-	rt_neighborhood \
-	rt_nearestvalue \
-	rt_pixelofvalue \
-	rt_polygon \
-	rt_setbandpath
-TEST_UTILITY = \
-	rt_utility \
-	rt_fromgdalraster \
-	rt_asgdalraster \
-	rt_astiff \
-	rt_asjpeg \
-	rt_aspng \
-	rt_reclass \
-	rt_gdalwarp \
-	rt_asraster \
-	rt_dumpvalues \
-	rt_makeemptycoverage \
-	rt_createoverview
-TEST_MAPALGEBRA = \
-	rt_mapalgebraexpr \
-	rt_mapalgebrafct \
-	rt_mapalgebraexpr_2raster \
-	rt_mapalgebrafct_2raster \
-	rt_mapalgebrafctngb \
-	rt_mapalgebrafctngb_userfunc \
-	rt_intersection \
-	rt_clip \
-	rt_mapalgebra \
-	rt_mapalgebra_expr \
-	rt_mapalgebra_mask \
-	rt_union \
-	rt_invdistweight4ma \
-	rt_4ma \
-	rt_setvalues_geomval \
-	rt_elevation_functions \
-	rt_colormap \
-	rt_grayscale
-TEST_SREL = \
-	rt_gist_relationships \
-	rt_intersects \
-	rt_samealignment \
-	rt_geos_relationships \
-	rt_iscoveragetile
-TEST_BUGS = \
-	bug_test_car5 \
-	permitted_gdal_drivers \
-	tickets
-TEST_LOADER = \
-	loader/Basic \
-	loader/Projected \
-	loader/BasicCopy \
-	loader/BasicFilename \
-	loader/BasicOutDB \
-	loader/Tiled10x10 \
-	loader/Tiled10x10Copy \
-	loader/Tiled8x8 \
-	loader/TiledAuto \
-	loader/TiledAutoSkipNoData \
-	loader/TiledAutoZCopy
-RASTER_TESTS := $(TEST_FIRST) \
-	$(TEST_METADATA) $(TEST_IO) $(TEST_BASIC_FUNC) \
-	$(TEST_PROPS) $(TEST_BANDPROPS) \
-	$(TEST_UTILITY) $(TEST_MAPALGEBRA) $(TEST_SREL) \
-	$(TEST_BUGS) \
-	$(TEST_LOADER) \
-	$(TEST_LAST)
-all:
-	@echo "Use 'make check' to run all tests"
-distclean: clean
-	rm -f Makefile
-clean:
-	$(RM) -f rtpostgis.sql
-rtpostgis.sql: ../../rt_pg/rtpostgis.sql
-	$(PERL) -lpe "s'\\\$$libdir'$(REGRESS_INSTALLDIR)/lib'g" $< > $@
-# TODO: drop this variable, use top_srcdir directly
-topsrcdir = $(top_srcdir)
-include $(srcdir)/tests.mk
-include $(top_srcdir)/regress/runtest.mk
-check: check-regress
Summary of changes:
 configure.ac                    |   1 -
 raster/test/regress/Makefile.in | 194 ----------------------------------------
 2 files changed, 195 deletions(-)
 delete mode 100644 raster/test/regress/Makefile.in
hooks/post-receive
