[postgis-tickets] [PostGIS] #5171: SELECT st_length(st_geomfromtext gives error when running on ARM processor when points input are the same
PostGIS trac at osgeo.org
Thu Jun 16 07:57:12 PDT 2022
  Reporter:  arnghosb  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  high      |  Milestone:  PostGIS 3.1.6
 Component:  postgis   |    Version:  3.2.x
Resolution:            |   Keywords:
Comment (by arnghosb):
 This is the output for the version:
 POSTGIS="3.2.1 0" [EXTENSION] PGSQL="140" GEOS="3.9.1dev-CAPI-1.14.1"
 PROJ="6.2.1" LIBXML="2.9.9" LIBJSON="0.12.99" LIBPROTOBUF="1.3.0"
 WAGYU="0.5.0 (Internal)" PostgreSQL 14.3 on aarch64-u
 nknown-linux-gnu, compiled by aarch64-unknown-linux-gnu-gcc (GCC) 7.4.0,
 64-bit
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5171#comment:5>
