[postgis-tickets] [PostGIS] #5171: SELECT st_length(st_geomfromtext gives error when running on ARM processor when points input are the same
PostGIS trac at osgeo.org
Fri Jun 17 10:20:54 PDT 2022
  Reporter:  arnghosb  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  high      |  Milestone:  PostGIS 3.1.6
 Component:  postgis   |    Version:  3.2.x
Resolution:            |   Keywords:
Comment (by robe):
 Thanks.  I'll try 3.2.1 next to see if I can replicate.  Might be a GCC
 bug issue is another thought as I'm running a newer GCC on my ARM.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5171#comment:6>
