[postgis-tickets] [PostGIS] #5171: SELECT st_length(st_geomfromtext gives error when running on ARM processor when points input are the same
PostGIS trac at osgeo.org
Fri Jun 17 10:25:14 PDT 2022
  Reporter:  arnghosb  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  high      |  Milestone:  PostGIS 3.1.6
 Component:  postgis   |    Version:  3.2.x
Resolution:            |   Keywords:
Comment (by arnghosb):
 Could be an issue with PROJ library. Maybe this is a bug on 6.2.1.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5171#comment:7>
