[postgis-tickets] [PostGIS] #5171: SELECT st_length(st_geomfromtext gives error when running on ARM processor when points input are the same
PostGIS trac at osgeo.org
Fri Jun 17 10:31:18 PDT 2022
  Reporter:  arnghosb  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  high      |  Milestone:  PostGIS 3.1.6
 Component:  postgis   |    Version:  3.2.x
Resolution:            |   Keywords:
Comment (by robe):
 Ah I think you are right.  My earlier test where I was able to replicate
 the issue was on Amazon Aurora, not RDS.
 On RDS the test is fine -- my AMZ RDS is running below, a newer proj
 POSTGIS="3.1.4 ded6c34" [EXTENSION] PGSQL="140" GEOS="3.9.1-CAPI-1.14.2"
 PROJ="8.0.1" GDAL="GDAL 3.3.0, released 2021/04/26" LIBXML="2.9.1"
 LIBJSON="0.15" LIBPROTOBUF="1.3.2" WAGYU="0.5.0 (Internal)" RASTER
 PostgreSQL 14.1 on aarch64-unknown-linux-gnu, compiled by gcc (GCC) 7.3.1
 20180712 (Red Hat 7.3.1-6), 64-bit
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5171#comment:8>
