[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-92-g8003f013a
Tue Jun 21 01:47:00 PDT 2022
the project "PostGIS".
       via  8003f013ad9e9cfb57d46f65f9af9cf5b7e0e969 (commit)
      from  8916302c8fb51e49577c37610f515f1e22d820ec (commit)
revisions in full, below.
commit 8003f013ad9e9cfb57d46f65f9af9cf5b7e0e969
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jun 21 10:29:48 2022 +0200
    Drop redundant variable topsrcdir, use top_srcdir
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 6479ebb3e..1e93ecae8 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -196,9 +196,6 @@ postgis_revision.h:
 .PHONY: utils liblwgeom ChangeLog raster
-# TODO: drop this variable, use top_srcdir directly
-topsrcdir = $(top_srcdir)
 include $(top_builddir)/regress/core/tests.mk
 include $(top_srcdir)/regress/loader/tests.mk
 include $(top_srcdir)/regress/dumper/tests.mk
diff --git a/raster/test/regress/Makefile.in b/raster/test/regress/Makefile.in
index 5232d425e..2daf91ddf 100644
--- a/raster/test/regress/Makefile.in
+++ b/raster/test/regress/Makefile.in
@@ -59,9 +59,6 @@ rtpostgis.sql: ../../rt_pg/rtpostgis.sql
 	$(PERL) -lpe "s'\\\$$libdir'$(REGRESS_INSTALLDIR)/lib'g" $< > $@
 include $(srcdir)/tests.mk
 include $(top_srcdir)/regress/runtest.mk
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index 2c5d006bc..00918e134 100644
--- a/raster/test/regress/tests.mk
+++ b/raster/test/regress/tests.mk
@@ -13,128 +13,128 @@
 override RUNTESTFLAGS := $(RUNTESTFLAGS) --raster
 override RUNTESTFLAGS_INTERNAL := \
-  --before-upgrade-script $(topsrcdir)/raster/test/regress/hooks/hook-before-upgrade-raster.sql \
+  --before-upgrade-script $(top_srcdir)/raster/test/regress/hooks/hook-before-upgrade-raster.sql \
   $(RUNTESTFLAGS_INTERNAL) \
-  --after-upgrade-script $(topsrcdir)/raster/test/regress/hooks/hook-after-upgrade-raster.sql
+  --after-upgrade-script $(top_srcdir)/raster/test/regress/hooks/hook-after-upgrade-raster.sql
 RASTER_TEST_FIRST = \
-	$(topsrcdir)/raster/test/regress/check_gdal \
-	$(topsrcdir)/raster/test/regress/loader/load_outdb
+	$(top_srcdir)/raster/test/regress/check_gdal \
+	$(top_srcdir)/raster/test/regress/loader/load_outdb
 RASTER_TEST_LAST = \
-	$(topsrcdir)/raster/test/regress/clean
+	$(top_srcdir)/raster/test/regress/clean
 RASTER_TEST_METADATA = \
-	$(topsrcdir)/raster/test/regress/check_raster_columns \
-	$(topsrcdir)/raster/test/regress/check_raster_overviews
+	$(top_srcdir)/raster/test/regress/check_raster_columns \
+	$(top_srcdir)/raster/test/regress/check_raster_overviews
 RASTER_TEST_IO = \
-	$(topsrcdir)/raster/test/regress/rt_io
+	$(top_srcdir)/raster/test/regress/rt_io
 RASTER_TEST_BASIC_FUNC = \
-	$(topsrcdir)/raster/test/regress/rt_bytea \
-	$(topsrcdir)/raster/test/regress/rt_wkb \
-	$(topsrcdir)/raster/test/regress/box3d \
-	$(topsrcdir)/raster/test/regress/rt_addband \
-	$(topsrcdir)/raster/test/regress/rt_band \
-	$(topsrcdir)/raster/test/regress/rt_tile
+	$(top_srcdir)/raster/test/regress/rt_bytea \
+	$(top_srcdir)/raster/test/regress/rt_wkb \
+	$(top_srcdir)/raster/test/regress/box3d \
+	$(top_srcdir)/raster/test/regress/rt_addband \
+	$(top_srcdir)/raster/test/regress/rt_band \
+	$(top_srcdir)/raster/test/regress/rt_tile
 RASTER_TEST_PROPS = \
-	$(topsrcdir)/raster/test/regress/rt_dimensions \
-	$(topsrcdir)/raster/test/regress/rt_scale \
-	$(topsrcdir)/raster/test/regress/rt_pixelsize \
-	$(topsrcdir)/raster/test/regress/rt_upperleft \
-	$(topsrcdir)/raster/test/regress/rt_rotation \
-	$(topsrcdir)/raster/test/regress/rt_georeference \
-	$(topsrcdir)/raster/test/regress/rt_set_properties \
-	$(topsrcdir)/raster/test/regress/rt_isempty \
-	$(topsrcdir)/raster/test/regress/rt_hasnoband \
-	$(topsrcdir)/raster/test/regress/rt_metadata \
-	$(topsrcdir)/raster/test/regress/rt_rastertoworldcoord \
-	$(topsrcdir)/raster/test/regress/rt_worldtorastercoord \
-	$(topsrcdir)/raster/test/regress/rt_convexhull \
-	$(topsrcdir)/raster/test/regress/rt_envelope
+	$(top_srcdir)/raster/test/regress/rt_dimensions \
+	$(top_srcdir)/raster/test/regress/rt_scale \
+	$(top_srcdir)/raster/test/regress/rt_pixelsize \
+	$(top_srcdir)/raster/test/regress/rt_upperleft \
+	$(top_srcdir)/raster/test/regress/rt_rotation \
+	$(top_srcdir)/raster/test/regress/rt_georeference \
+	$(top_srcdir)/raster/test/regress/rt_set_properties \
+	$(top_srcdir)/raster/test/regress/rt_isempty \
+	$(top_srcdir)/raster/test/regress/rt_hasnoband \
+	$(top_srcdir)/raster/test/regress/rt_metadata \
+	$(top_srcdir)/raster/test/regress/rt_rastertoworldcoord \
+	$(top_srcdir)/raster/test/regress/rt_worldtorastercoord \
+	$(top_srcdir)/raster/test/regress/rt_convexhull \
+	$(top_srcdir)/raster/test/regress/rt_envelope
 RASTER_TEST_BANDPROPS = \
-	$(topsrcdir)/raster/test/regress/rt_band_properties \
-	$(topsrcdir)/raster/test/regress/rt_set_band_properties \
-	$(topsrcdir)/raster/test/regress/rt_pixelaspolygons \
-	$(topsrcdir)/raster/test/regress/rt_pixelaspoints \
-	$(topsrcdir)/raster/test/regress/rt_pixelascentroids \
-	$(topsrcdir)/raster/test/regress/rt_setvalues_array \
-	$(topsrcdir)/raster/test/regress/rt_summarystats \
-	$(topsrcdir)/raster/test/regress/rt_count \
-	$(topsrcdir)/raster/test/regress/rt_histogram \
-	$(topsrcdir)/raster/test/regress/rt_quantile \
-	$(topsrcdir)/raster/test/regress/rt_valuecount \
-	$(topsrcdir)/raster/test/regress/rt_valuepercent \
-	$(topsrcdir)/raster/test/regress/rt_bandmetadata \
-	$(topsrcdir)/raster/test/regress/rt_pixelvalue \
-	$(topsrcdir)/raster/test/regress/rt_neighborhood \
-	$(topsrcdir)/raster/test/regress/rt_nearestvalue \
-	$(topsrcdir)/raster/test/regress/rt_pixelofvalue \
-	$(topsrcdir)/raster/test/regress/rt_polygon \
-	$(topsrcdir)/raster/test/regress/rt_setbandpath
+	$(top_srcdir)/raster/test/regress/rt_band_properties \
+	$(top_srcdir)/raster/test/regress/rt_set_band_properties \
+	$(top_srcdir)/raster/test/regress/rt_pixelaspolygons \
+	$(top_srcdir)/raster/test/regress/rt_pixelaspoints \
+	$(top_srcdir)/raster/test/regress/rt_pixelascentroids \
+	$(top_srcdir)/raster/test/regress/rt_setvalues_array \
+	$(top_srcdir)/raster/test/regress/rt_summarystats \
+	$(top_srcdir)/raster/test/regress/rt_count \
+	$(top_srcdir)/raster/test/regress/rt_histogram \
+	$(top_srcdir)/raster/test/regress/rt_quantile \
+	$(top_srcdir)/raster/test/regress/rt_valuecount \
+	$(top_srcdir)/raster/test/regress/rt_valuepercent \
+	$(top_srcdir)/raster/test/regress/rt_bandmetadata \
+	$(top_srcdir)/raster/test/regress/rt_pixelvalue \
+	$(top_srcdir)/raster/test/regress/rt_neighborhood \
+	$(top_srcdir)/raster/test/regress/rt_nearestvalue \
+	$(top_srcdir)/raster/test/regress/rt_pixelofvalue \
+	$(top_srcdir)/raster/test/regress/rt_polygon \
+	$(top_srcdir)/raster/test/regress/rt_setbandpath
 RASTER_TEST_UTILITY = \
-	$(topsrcdir)/raster/test/regress/rt_utility \
-	$(topsrcdir)/raster/test/regress/rt_fromgdalraster \
-	$(topsrcdir)/raster/test/regress/rt_asgdalraster \
-	$(topsrcdir)/raster/test/regress/rt_astiff \
-	$(topsrcdir)/raster/test/regress/rt_asjpeg \
-	$(topsrcdir)/raster/test/regress/rt_aspng \
-	$(topsrcdir)/raster/test/regress/rt_reclass \
-	$(topsrcdir)/raster/test/regress/rt_gdalwarp \
-	$(topsrcdir)/raster/test/regress/rt_gdalcontour \
-	$(topsrcdir)/raster/test/regress/rt_asraster \
-	$(topsrcdir)/raster/test/regress/rt_dumpvalues \
-	$(topsrcdir)/raster/test/regress/rt_makeemptycoverage \
-	$(topsrcdir)/raster/test/regress/rt_createoverview
+	$(top_srcdir)/raster/test/regress/rt_utility \
+	$(top_srcdir)/raster/test/regress/rt_fromgdalraster \
+	$(top_srcdir)/raster/test/regress/rt_asgdalraster \
+	$(top_srcdir)/raster/test/regress/rt_astiff \
+	$(top_srcdir)/raster/test/regress/rt_asjpeg \
+	$(top_srcdir)/raster/test/regress/rt_aspng \
+	$(top_srcdir)/raster/test/regress/rt_reclass \
+	$(top_srcdir)/raster/test/regress/rt_gdalwarp \
+	$(top_srcdir)/raster/test/regress/rt_gdalcontour \
+	$(top_srcdir)/raster/test/regress/rt_asraster \
+	$(top_srcdir)/raster/test/regress/rt_dumpvalues \
+	$(top_srcdir)/raster/test/regress/rt_makeemptycoverage \
+	$(top_srcdir)/raster/test/regress/rt_createoverview
 RASTER_TEST_MAPALGEBRA = \
-	$(topsrcdir)/raster/test/regress/rt_mapalgebraexpr \
-	$(topsrcdir)/raster/test/regress/rt_mapalgebrafct \
-	$(topsrcdir)/raster/test/regress/rt_mapalgebraexpr_2raster \
-	$(topsrcdir)/raster/test/regress/rt_mapalgebrafct_2raster \
-	$(topsrcdir)/raster/test/regress/rt_mapalgebrafctngb \
-	$(topsrcdir)/raster/test/regress/rt_mapalgebrafctngb_userfunc \
-	$(topsrcdir)/raster/test/regress/rt_intersection \
-	$(topsrcdir)/raster/test/regress/rt_clip \
-	$(topsrcdir)/raster/test/regress/rt_mapalgebra \
-	$(topsrcdir)/raster/test/regress/rt_mapalgebra_expr \
-	$(topsrcdir)/raster/test/regress/rt_mapalgebra_mask \
-	$(topsrcdir)/raster/test/regress/rt_union \
-	$(topsrcdir)/raster/test/regress/rt_invdistweight4ma \
-	$(topsrcdir)/raster/test/regress/rt_4ma \
-	$(topsrcdir)/raster/test/regress/rt_setvalues_geomval \
-	$(topsrcdir)/raster/test/regress/rt_elevation_functions \
-	$(topsrcdir)/raster/test/regress/rt_colormap \
-	$(topsrcdir)/raster/test/regress/rt_grayscale
+	$(top_srcdir)/raster/test/regress/rt_mapalgebraexpr \
+	$(top_srcdir)/raster/test/regress/rt_mapalgebrafct \
+	$(top_srcdir)/raster/test/regress/rt_mapalgebraexpr_2raster \
+	$(top_srcdir)/raster/test/regress/rt_mapalgebrafct_2raster \
+	$(top_srcdir)/raster/test/regress/rt_mapalgebrafctngb \
+	$(top_srcdir)/raster/test/regress/rt_mapalgebrafctngb_userfunc \
+	$(top_srcdir)/raster/test/regress/rt_intersection \
+	$(top_srcdir)/raster/test/regress/rt_clip \
+	$(top_srcdir)/raster/test/regress/rt_mapalgebra \
+	$(top_srcdir)/raster/test/regress/rt_mapalgebra_expr \
+	$(top_srcdir)/raster/test/regress/rt_mapalgebra_mask \
+	$(top_srcdir)/raster/test/regress/rt_union \
+	$(top_srcdir)/raster/test/regress/rt_invdistweight4ma \
+	$(top_srcdir)/raster/test/regress/rt_4ma \
+	$(top_srcdir)/raster/test/regress/rt_setvalues_geomval \
+	$(top_srcdir)/raster/test/regress/rt_elevation_functions \
+	$(top_srcdir)/raster/test/regress/rt_colormap \
+	$(top_srcdir)/raster/test/regress/rt_grayscale
 RASTER_TEST_SREL = \
-	$(topsrcdir)/raster/test/regress/rt_gist_relationships \
-	$(topsrcdir)/raster/test/regress/rt_intersects \
-	$(topsrcdir)/raster/test/regress/rt_samealignment \
-	$(topsrcdir)/raster/test/regress/rt_geos_relationships \
-	$(topsrcdir)/raster/test/regress/rt_iscoveragetile
+	$(top_srcdir)/raster/test/regress/rt_gist_relationships \
+	$(top_srcdir)/raster/test/regress/rt_intersects \
+	$(top_srcdir)/raster/test/regress/rt_samealignment \
+	$(top_srcdir)/raster/test/regress/rt_geos_relationships \
+	$(top_srcdir)/raster/test/regress/rt_iscoveragetile
 RASTER_TEST_BUGS = \
-	$(topsrcdir)/raster/test/regress/bug_test_car5 \
-	$(topsrcdir)/raster/test/regress/permitted_gdal_drivers \
-	$(topsrcdir)/raster/test/regress/tickets
+	$(top_srcdir)/raster/test/regress/bug_test_car5 \
+	$(top_srcdir)/raster/test/regress/permitted_gdal_drivers \
+	$(top_srcdir)/raster/test/regress/tickets
 RASTER_TEST_LOADER = \
-	$(topsrcdir)/raster/test/regress/loader/Basic \
-	$(topsrcdir)/raster/test/regress/loader/Projected \
-	$(topsrcdir)/raster/test/regress/loader/BasicCopy \
-	$(topsrcdir)/raster/test/regress/loader/BasicFilename \
-	$(topsrcdir)/raster/test/regress/loader/BasicOutDB \
-	$(topsrcdir)/raster/test/regress/loader/Tiled10x10 \
-	$(topsrcdir)/raster/test/regress/loader/Tiled10x10Copy \
-	$(topsrcdir)/raster/test/regress/loader/Tiled8x8 \
-	$(topsrcdir)/raster/test/regress/loader/TiledAuto \
-	$(topsrcdir)/raster/test/regress/loader/TiledAutoSkipNoData \
-	$(topsrcdir)/raster/test/regress/loader/TiledAutoCopyn
+	$(top_srcdir)/raster/test/regress/loader/Basic \
+	$(top_srcdir)/raster/test/regress/loader/Projected \
+	$(top_srcdir)/raster/test/regress/loader/BasicCopy \
+	$(top_srcdir)/raster/test/regress/loader/BasicFilename \
+	$(top_srcdir)/raster/test/regress/loader/BasicOutDB \
+	$(top_srcdir)/raster/test/regress/loader/Tiled10x10 \
+	$(top_srcdir)/raster/test/regress/loader/Tiled10x10Copy \
+	$(top_srcdir)/raster/test/regress/loader/Tiled8x8 \
+	$(top_srcdir)/raster/test/regress/loader/TiledAuto \
+	$(top_srcdir)/raster/test/regress/loader/TiledAutoSkipNoData \
+	$(top_srcdir)/raster/test/regress/loader/TiledAutoCopyn
 RASTER_TESTS := $(RASTER_TEST_FIRST) \
 	$(RASTER_TEST_METADATA) $(RASTER_TEST_IO) $(RASTER_TEST_BASIC_FUNC) \
diff --git a/regress/Makefile.in b/regress/Makefile.in
index 3d227fb5e..7aad562f5 100644
--- a/regress/Makefile.in
+++ b/regress/Makefile.in
@@ -49,9 +49,6 @@ check: check-regress
 check-unit:
 include $(builddir)/core/tests.mk
 include $(srcdir)/loader/tests.mk
 include $(srcdir)/dumper/tests.mk
diff --git a/regress/core/Makefile.in b/regress/core/Makefile.in
index 693f9b7be..d4be6dc14 100644
--- a/regress/core/Makefile.in
+++ b/regress/core/Makefile.in
@@ -17,9 +17,6 @@ top_builddir = @top_builddir@
 PERL=@PERL@
 include $(builddir)/tests.mk
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index ed0555cef..bf1fe5643 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -21,193 +21,193 @@ INTERRUPTTESTS=@INTERRUPTTESTS@
 current_dir := $(dir $(abspath $(lastword $(MAKEFILE_LIST))))
 RUNTESTFLAGS_INTERNAL += \
-  --before-upgrade-script $(topsrcdir)/regress/hooks/hook-before-upgrade.sql \
-  --after-upgrade-script  $(topsrcdir)/regress/hooks/hook-after-upgrade.sql \
-  --after-create-script   $(topsrcdir)/regress/hooks/hook-after-create.sql \
-  --before-uninstall-script $(topsrcdir)/regress/hooks/hook-before-uninstall.sql
+  --before-upgrade-script $(top_srcdir)/regress/hooks/hook-before-upgrade.sql \
+  --after-upgrade-script  $(top_srcdir)/regress/hooks/hook-after-upgrade.sql \
+  --after-create-script   $(top_srcdir)/regress/hooks/hook-after-create.sql \
+  --before-uninstall-script $(top_srcdir)/regress/hooks/hook-before-uninstall.sql
 TESTS += \
-	$(topsrcdir)/regress/core/affine \
-	$(topsrcdir)/regress/core/bestsrid \
-	$(topsrcdir)/regress/core/binary \
-	$(topsrcdir)/regress/core/boundary \
-	$(topsrcdir)/regress/core/chaikin \
-	$(topsrcdir)/regress/core/filterm \
-	$(topsrcdir)/regress/core/cluster \
-	$(topsrcdir)/regress/core/ctors \
-	$(topsrcdir)/regress/core/curvetoline \
-	$(topsrcdir)/regress/core/dump \
-	$(topsrcdir)/regress/core/dumppoints \
-	$(topsrcdir)/regress/core/dumpsegments \
-	$(topsrcdir)/regress/core/empty \
-	$(topsrcdir)/regress/core/estimatedextent \
-	$(topsrcdir)/regress/core/forcecurve \
-	$(topsrcdir)/regress/core/flatgeobuf \
-	$(topsrcdir)/regress/core/geography \
-	$(topsrcdir)/regress/core/geometric_median \
-  $(topsrcdir)/regress/core/geos_noop \
-	$(topsrcdir)/regress/core/hausdorff \
-	$(topsrcdir)/regress/core/in_flatgeobuf \
-	$(topsrcdir)/regress/core/in_geohash \
-	$(topsrcdir)/regress/core/in_gml \
-	$(topsrcdir)/regress/core/in_kml \
-	$(topsrcdir)/regress/core/in_marc21 \
-	$(topsrcdir)/regress/core/out_marc21 \
-	$(topsrcdir)/regress/core/in_encodedpolyline \
-	$(topsrcdir)/regress/core/iscollection \
-	$(topsrcdir)/regress/core/legacy \
-	$(topsrcdir)/regress/core/letters \
-	$(topsrcdir)/regress/core/long_xact \
-	$(topsrcdir)/regress/core/lwgeom_regress \
-	$(topsrcdir)/regress/core/measures \
-	$(topsrcdir)/regress/core/minimum_bounding_circle \
-	$(topsrcdir)/regress/core/normalize \
-	$(topsrcdir)/regress/core/operators \
-	$(topsrcdir)/regress/core/orientation \
-	$(topsrcdir)/regress/core/out_flatgeobuf \
-	$(topsrcdir)/regress/core/out_geometry \
-	$(topsrcdir)/regress/core/out_geography \
-	$(topsrcdir)/regress/core/polygonize \
-	$(topsrcdir)/regress/core/polyhedralsurface \
-	$(topsrcdir)/regress/core/postgis_type_name \
-	$(topsrcdir)/regress/core/quantize_coordinates \
-	$(topsrcdir)/regress/core/regress \
-	$(topsrcdir)/regress/core/regress_bdpoly \
-	$(topsrcdir)/regress/core/regress_buffer_params \
-	$(topsrcdir)/regress/core/regress_gist_index_nd \
-	$(topsrcdir)/regress/core/regress_index \
-	$(topsrcdir)/regress/core/regress_index_nulls \
-	$(topsrcdir)/regress/core/regress_management \
-	$(topsrcdir)/regress/core/regress_selectivity \
-	$(topsrcdir)/regress/core/regress_lrs \
-	$(topsrcdir)/regress/core/regress_ogc \
-	$(topsrcdir)/regress/core/regress_ogc_cover \
-	$(topsrcdir)/regress/core/regress_ogc_prep \
-	$(topsrcdir)/regress/core/regress_proj_basic \
-	$(topsrcdir)/regress/core/regress_proj_adhoc \
-	$(topsrcdir)/regress/core/regress_proj_cache_overflow \
-	$(topsrcdir)/regress/core/regress_proj_4890 \
-	$(topsrcdir)/regress/core/relate \
-	$(topsrcdir)/regress/core/remove_repeated_points \
-	$(topsrcdir)/regress/core/removepoint \
-	$(topsrcdir)/regress/core/reverse \
-	$(topsrcdir)/regress/core/scroll \
-	$(topsrcdir)/regress/core/setpoint \
-	$(topsrcdir)/regress/core/simplify \
-	$(topsrcdir)/regress/core/simplifyvw \
-	$(topsrcdir)/regress/core/size \
-	$(topsrcdir)/regress/core/snaptogrid \
-	$(topsrcdir)/regress/core/split \
-	$(topsrcdir)/regress/core/sql-mm-serialize \
-	$(topsrcdir)/regress/core/sql-mm-circularstring \
-	$(topsrcdir)/regress/core/sql-mm-compoundcurve \
-	$(topsrcdir)/regress/core/sql-mm-curvepoly \
-	$(topsrcdir)/regress/core/sql-mm-general \
-	$(topsrcdir)/regress/core/sql-mm-multicurve \
-	$(topsrcdir)/regress/core/sql-mm-multisurface \
-	$(topsrcdir)/regress/core/swapordinates \
-	$(topsrcdir)/regress/core/summary \
-	$(topsrcdir)/regress/core/temporal \
-	$(topsrcdir)/regress/core/temporal_knn \
-	$(topsrcdir)/regress/core/tickets \
-	$(topsrcdir)/regress/core/twkb \
-	$(topsrcdir)/regress/core/typmod \
-	$(topsrcdir)/regress/core/wkb \
-	$(topsrcdir)/regress/core/wkt \
-	$(topsrcdir)/regress/core/wmsservers \
-	$(topsrcdir)/regress/core/offsetcurve \
-	$(topsrcdir)/regress/core/relatematch \
-	$(topsrcdir)/regress/core/isvaliddetail \
-	$(topsrcdir)/regress/core/sharedpaths \
-	$(topsrcdir)/regress/core/snap \
-	$(topsrcdir)/regress/core/node \
-	$(topsrcdir)/regress/core/unaryunion \
-	$(topsrcdir)/regress/core/clean \
-	$(topsrcdir)/regress/core/relate_bnr \
-	$(topsrcdir)/regress/core/delaunaytriangles \
-	$(topsrcdir)/regress/core/clipbybox2d \
-	$(topsrcdir)/regress/core/subdivide \
-	$(topsrcdir)/regress/core/voronoi \
-	$(topsrcdir)/regress/core/regress_brin_index \
-	$(topsrcdir)/regress/core/regress_brin_index_3d \
-	$(topsrcdir)/regress/core/regress_brin_index_geography \
-	$(topsrcdir)/regress/core/minimum_clearance \
-	$(topsrcdir)/regress/core/oriented_envelope \
-	$(topsrcdir)/regress/core/point_coordinates \
-	$(topsrcdir)/regress/core/out_geojson \
-  $(topsrcdir)/regress/core/wrapx
+	$(top_srcdir)/regress/core/affine \
+	$(top_srcdir)/regress/core/bestsrid \
+	$(top_srcdir)/regress/core/binary \
+	$(top_srcdir)/regress/core/boundary \
+	$(top_srcdir)/regress/core/chaikin \
+	$(top_srcdir)/regress/core/filterm \
+	$(top_srcdir)/regress/core/cluster \
+	$(top_srcdir)/regress/core/ctors \
+	$(top_srcdir)/regress/core/curvetoline \
+	$(top_srcdir)/regress/core/dump \
+	$(top_srcdir)/regress/core/dumppoints \
+	$(top_srcdir)/regress/core/dumpsegments \
+	$(top_srcdir)/regress/core/empty \
+	$(top_srcdir)/regress/core/estimatedextent \
+	$(top_srcdir)/regress/core/forcecurve \
+	$(top_srcdir)/regress/core/flatgeobuf \
+	$(top_srcdir)/regress/core/geography \
+	$(top_srcdir)/regress/core/geometric_median \
+  $(top_srcdir)/regress/core/geos_noop \
+	$(top_srcdir)/regress/core/hausdorff \
+	$(top_srcdir)/regress/core/in_flatgeobuf \
+	$(top_srcdir)/regress/core/in_geohash \
+	$(top_srcdir)/regress/core/in_gml \
+	$(top_srcdir)/regress/core/in_kml \
+	$(top_srcdir)/regress/core/in_marc21 \
+	$(top_srcdir)/regress/core/out_marc21 \
+	$(top_srcdir)/regress/core/in_encodedpolyline \
+	$(top_srcdir)/regress/core/iscollection \
+	$(top_srcdir)/regress/core/legacy \
+	$(top_srcdir)/regress/core/letters \
+	$(top_srcdir)/regress/core/long_xact \
+	$(top_srcdir)/regress/core/lwgeom_regress \
+	$(top_srcdir)/regress/core/measures \
+	$(top_srcdir)/regress/core/minimum_bounding_circle \
+	$(top_srcdir)/regress/core/normalize \
+	$(top_srcdir)/regress/core/operators \
+	$(top_srcdir)/regress/core/orientation \
+	$(top_srcdir)/regress/core/out_flatgeobuf \
+	$(top_srcdir)/regress/core/out_geometry \
+	$(top_srcdir)/regress/core/out_geography \
+	$(top_srcdir)/regress/core/polygonize \
+	$(top_srcdir)/regress/core/polyhedralsurface \
+	$(top_srcdir)/regress/core/postgis_type_name \
+	$(top_srcdir)/regress/core/quantize_coordinates \
+	$(top_srcdir)/regress/core/regress \
+	$(top_srcdir)/regress/core/regress_bdpoly \
+	$(top_srcdir)/regress/core/regress_buffer_params \
+	$(top_srcdir)/regress/core/regress_gist_index_nd \
+	$(top_srcdir)/regress/core/regress_index \
+	$(top_srcdir)/regress/core/regress_index_nulls \
+	$(top_srcdir)/regress/core/regress_management \
+	$(top_srcdir)/regress/core/regress_selectivity \
+	$(top_srcdir)/regress/core/regress_lrs \
+	$(top_srcdir)/regress/core/regress_ogc \
+	$(top_srcdir)/regress/core/regress_ogc_cover \
+	$(top_srcdir)/regress/core/regress_ogc_prep \
+	$(top_srcdir)/regress/core/regress_proj_basic \
+	$(top_srcdir)/regress/core/regress_proj_adhoc \
+	$(top_srcdir)/regress/core/regress_proj_cache_overflow \
+	$(top_srcdir)/regress/core/regress_proj_4890 \
+	$(top_srcdir)/regress/core/relate \
+	$(top_srcdir)/regress/core/remove_repeated_points \
+	$(top_srcdir)/regress/core/removepoint \
+	$(top_srcdir)/regress/core/reverse \
+	$(top_srcdir)/regress/core/scroll \
+	$(top_srcdir)/regress/core/setpoint \
+	$(top_srcdir)/regress/core/simplify \
+	$(top_srcdir)/regress/core/simplifyvw \
+	$(top_srcdir)/regress/core/size \
+	$(top_srcdir)/regress/core/snaptogrid \
+	$(top_srcdir)/regress/core/split \
+	$(top_srcdir)/regress/core/sql-mm-serialize \
+	$(top_srcdir)/regress/core/sql-mm-circularstring \
+	$(top_srcdir)/regress/core/sql-mm-compoundcurve \
+	$(top_srcdir)/regress/core/sql-mm-curvepoly \
+	$(top_srcdir)/regress/core/sql-mm-general \
+	$(top_srcdir)/regress/core/sql-mm-multicurve \
+	$(top_srcdir)/regress/core/sql-mm-multisurface \
+	$(top_srcdir)/regress/core/swapordinates \
+	$(top_srcdir)/regress/core/summary \
+	$(top_srcdir)/regress/core/temporal \
+	$(top_srcdir)/regress/core/temporal_knn \
+	$(top_srcdir)/regress/core/tickets \
+	$(top_srcdir)/regress/core/twkb \
+	$(top_srcdir)/regress/core/typmod \
+	$(top_srcdir)/regress/core/wkb \
+	$(top_srcdir)/regress/core/wkt \
+	$(top_srcdir)/regress/core/wmsservers \
+	$(top_srcdir)/regress/core/offsetcurve \
+	$(top_srcdir)/regress/core/relatematch \
+	$(top_srcdir)/regress/core/isvaliddetail \
+	$(top_srcdir)/regress/core/sharedpaths \
+	$(top_srcdir)/regress/core/snap \
+	$(top_srcdir)/regress/core/node \
+	$(top_srcdir)/regress/core/unaryunion \
+	$(top_srcdir)/regress/core/clean \
+	$(top_srcdir)/regress/core/relate_bnr \
+	$(top_srcdir)/regress/core/delaunaytriangles \
+	$(top_srcdir)/regress/core/clipbybox2d \
+	$(top_srcdir)/regress/core/subdivide \
+	$(top_srcdir)/regress/core/voronoi \
+	$(top_srcdir)/regress/core/regress_brin_index \
+	$(top_srcdir)/regress/core/regress_brin_index_3d \
+	$(top_srcdir)/regress/core/regress_brin_index_geography \
+	$(top_srcdir)/regress/core/minimum_clearance \
+	$(top_srcdir)/regress/core/oriented_envelope \
+	$(top_srcdir)/regress/core/point_coordinates \
+	$(top_srcdir)/regress/core/out_geojson \
+  $(top_srcdir)/regress/core/wrapx
 # Slow slow tests
 TESTS_SLOW = \
-	$(topsrcdir)/regress/core/concave_hull_hard \
-	$(topsrcdir)/regress/core/knn_recheck
+	$(top_srcdir)/regress/core/concave_hull_hard \
+	$(top_srcdir)/regress/core/knn_recheck
 ifeq ($(shell expr "$(POSTGIS_PGSQL_VERSION)" ">=" 120),1)
 	TESTS += \
-		$(topsrcdir)/regress/core/computed_columns
+		$(top_srcdir)/regress/core/computed_columns
 endif
 ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 30700),1)
 	# GEOS-3.7 adds:
 	# ST_FrechetDistance
 	TESTS += \
-		$(topsrcdir)/regress/core/frechet
+		$(top_srcdir)/regress/core/frechet
 endif
 ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 30800),1)
 	# GEOS-3.8 adds stable pointonsurface implementation
 	TESTS += \
-		$(topsrcdir)/regress/core/geos38
+		$(top_srcdir)/regress/core/geos38
 endif
 ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 30900),1)
 	# GEOS-3.9 adds stable maximuminscribedcircle implementation
 	TESTS += \
-		$(topsrcdir)/regress/core/geos39 \
-		$(topsrcdir)/regress/core/fixedoverlay
+		$(top_srcdir)/regress/core/geos39 \
+		$(top_srcdir)/regress/core/fixedoverlay
 endif
 ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 31000),1)
 	TESTS += \
-		$(topsrcdir)/regress/core/geos310
+		$(top_srcdir)/regress/core/geos310
 endif
 ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 31100),1)
 	TESTS += \
-		$(topsrcdir)/regress/core/geos311
+		$(top_srcdir)/regress/core/geos311
 # Only run the old internal concavehull tests for GEOS < 3.11
 else
 	TESTS += \
 endif
 ifeq ($(INTERRUPTTESTS),yes)
 	# Allow CI servers to configure --with-interrupt-tests
 	TESTS += \
-		$(topsrcdir)/regress/core/interrupt \
-		$(topsrcdir)/regress/core/interrupt_relate \
-		$(topsrcdir)/regress/core/interrupt_buffer
+		$(top_srcdir)/regress/core/interrupt \
+		$(top_srcdir)/regress/core/interrupt_relate \
+		$(top_srcdir)/regress/core/interrupt_buffer
 endif
 ifeq ($(HAVE_JSON),yes)
 	# JSON-C adds:
 	# ST_GeomFromGeoJSON()
 	TESTS += \
-		$(topsrcdir)/regress/core/in_geojson
+		$(top_srcdir)/regress/core/in_geojson
 endif
 ifeq ($(HAVE_SPGIST),yes)
 	TESTS += \
-	$(topsrcdir)/regress/core/regress_spgist_index_2d \
-	$(topsrcdir)/regress/core/regress_spgist_index_3d \
-	$(topsrcdir)/regress/core/regress_spgist_index_nd
+	$(top_srcdir)/regress/core/regress_spgist_index_2d \
+	$(top_srcdir)/regress/core/regress_spgist_index_3d \
+	$(top_srcdir)/regress/core/regress_spgist_index_nd
 endif
 ifeq (@HAVE_PROTOBUF@,yes)
 	# protobuf-c adds:
 	# ST_AsMVT, ST_AsGeobuf
 	TESTS += \
-		$(topsrcdir)/regress/core/mvt \
-		$(topsrcdir)/regress/core/mvt_jsonb \
-		$(topsrcdir)/regress/core/geobuf
+		$(top_srcdir)/regress/core/mvt \
+		$(top_srcdir)/regress/core/mvt_jsonb \
+		$(top_srcdir)/regress/core/geobuf
 endif
diff --git a/regress/dumper/Makefile.in b/regress/dumper/Makefile.in
index db5eb3a48..2204b4c9b 100644
--- a/regress/dumper/Makefile.in
+++ b/regress/dumper/Makefile.in
 PERL=@PERL@
diff --git a/regress/dumper/tests.mk b/regress/dumper/tests.mk
index 18b4b71d1..d3417dc8f 100644
--- a/regress/dumper/tests.mk
+++ b/regress/dumper/tests.mk
@@ -11,9 +11,9 @@
 TESTS += \
-	$(topsrcdir)/regress/dumper/mfiledmp \
-	$(topsrcdir)/regress/dumper/literalsrid \
-	$(topsrcdir)/regress/dumper/realtable \
-	$(topsrcdir)/regress/dumper/nullsintable \
-	$(topsrcdir)/regress/dumper/null3d \
-	$(topsrcdir)/regress/dumper/withclause
+	$(top_srcdir)/regress/dumper/mfiledmp \
+	$(top_srcdir)/regress/dumper/literalsrid \
+	$(top_srcdir)/regress/dumper/realtable \
+	$(top_srcdir)/regress/dumper/nullsintable \
+	$(top_srcdir)/regress/dumper/null3d \
+	$(top_srcdir)/regress/dumper/withclause
diff --git a/regress/loader/Makefile.in b/regress/loader/Makefile.in
index fdc937aff..2204b4c9b 100644
--- a/regress/loader/Makefile.in
+++ b/regress/loader/Makefile.in
@@ -17,11 +17,7 @@ top_builddir = @top_builddir@
 PERL=@PERL@
diff --git a/regress/loader/tests.mk b/regress/loader/tests.mk
index f6be1df56..30c7d07b2 100644
--- a/regress/loader/tests.mk
+++ b/regress/loader/tests.mk
@@ -12,31 +12,31 @@
 TESTS += \
-	$(topsrcdir)/regress/loader/Point \
-	$(topsrcdir)/regress/loader/PointM \
-	$(topsrcdir)/regress/loader/PointZ \
-	$(topsrcdir)/regress/loader/MultiPoint \
-	$(topsrcdir)/regress/loader/MultiPointM \
-	$(topsrcdir)/regress/loader/MultiPointZ \
-	$(topsrcdir)/regress/loader/Arc \
-	$(topsrcdir)/regress/loader/ArcM \
-	$(topsrcdir)/regress/loader/ArcZ \
-	$(topsrcdir)/regress/loader/Polygon \
-	$(topsrcdir)/regress/loader/PolygonM \
-	$(topsrcdir)/regress/loader/PolygonZ \
-	$(topsrcdir)/regress/loader/TSTPolygon \
-	$(topsrcdir)/regress/loader/TSIPolygon \
-	$(topsrcdir)/regress/loader/TSTIPolygon \
-	$(topsrcdir)/regress/loader/PointWithSchema \
-	$(topsrcdir)/regress/loader/NoTransPoint \
-	$(topsrcdir)/regress/loader/NotReallyMultiPoint \
-	$(topsrcdir)/regress/loader/MultiToSinglePoint \
-	$(topsrcdir)/regress/loader/ReprojectPts \
-	$(topsrcdir)/regress/loader/ReprojectPtsD \
-	$(topsrcdir)/regress/loader/ReprojectPtsGeog \
-	$(topsrcdir)/regress/loader/ReprojectPtsGeogD \
-	$(topsrcdir)/regress/loader/Latin1 \
-	$(topsrcdir)/regress/loader/Latin1-implicit \
-	$(topsrcdir)/regress/loader/mfile \
-	$(topsrcdir)/regress/loader/TestSkipANALYZE \
-	$(topsrcdir)/regress/loader/TestANALYZE
+	$(top_srcdir)/regress/loader/Point \
+	$(top_srcdir)/regress/loader/PointM \
+	$(top_srcdir)/regress/loader/PointZ \
+	$(top_srcdir)/regress/loader/MultiPoint \
+	$(top_srcdir)/regress/loader/MultiPointM \
+	$(top_srcdir)/regress/loader/MultiPointZ \
+	$(top_srcdir)/regress/loader/Arc \
+	$(top_srcdir)/regress/loader/ArcM \
+	$(top_srcdir)/regress/loader/ArcZ \
+	$(top_srcdir)/regress/loader/Polygon \
+	$(top_srcdir)/regress/loader/PolygonM \
+	$(top_srcdir)/regress/loader/PolygonZ \
+	$(top_srcdir)/regress/loader/TSTPolygon \
+	$(top_srcdir)/regress/loader/TSIPolygon \
+	$(top_srcdir)/regress/loader/TSTIPolygon \
+	$(top_srcdir)/regress/loader/PointWithSchema \
+	$(top_srcdir)/regress/loader/NoTransPoint \
+	$(top_srcdir)/regress/loader/NotReallyMultiPoint \
+	$(top_srcdir)/regress/loader/MultiToSinglePoint \
+	$(top_srcdir)/regress/loader/ReprojectPts \
+	$(top_srcdir)/regress/loader/ReprojectPtsD \
+	$(top_srcdir)/regress/loader/ReprojectPtsGeog \
+	$(top_srcdir)/regress/loader/ReprojectPtsGeogD \
+	$(top_srcdir)/regress/loader/Latin1 \
+	$(top_srcdir)/regress/loader/Latin1-implicit \
+	$(top_srcdir)/regress/loader/mfile \
+	$(top_srcdir)/regress/loader/TestSkipANALYZE \
+	$(top_srcdir)/regress/loader/TestANALYZE
diff --git a/regress/runtest.mk b/regress/runtest.mk
index b337ee4ae..c051f0379 100644
--- a/regress/runtest.mk
+++ b/regress/runtest.mk
@@ -10,23 +10,23 @@
-abstopsrcdir := $(realpath $(top_srcdir))
-abssrcdir := $(realpath .)
+abs_top_srcdir := $(realpath $(top_srcdir))
+abs_srcdir := $(realpath .)
 abs_top_builddir := $(realpath $(top_builddir))
-TESTS := $(patsubst $(topsrcdir)/%,$(abstopsrcdir)/%,$(TESTS))
-TESTS := $(patsubst $(abssrcdir)/%,./%,$(TESTS))
+TESTS := $(patsubst $(top_srcdir)/%,$(abs_top_srcdir)/%,$(TESTS))
+TESTS := $(patsubst $(abs_srcdir)/%,./%,$(TESTS))
 .PHONY: check-regress
 check-regress:
 	@echo "RUNTESTFLAGS: $(RUNTESTFLAGS)"
 	@echo "RUNTESTFLAGS_INTERNAL: $(RUNTESTFLAGS_INTERNAL)"
-	POSTGIS_TOP_BUILD_DIR=$(abs_top_builddir) $(PERL) $(topsrcdir)/regress/run_test.pl $(RUNTESTFLAGS) $(RUNTESTFLAGS_INTERNAL) $(TESTS)
+	POSTGIS_TOP_BUILD_DIR=$(abs_top_builddir) $(PERL) $(top_srcdir)/regress/run_test.pl $(RUNTESTFLAGS) $(RUNTESTFLAGS_INTERNAL) $(TESTS)
 	@if echo "$(RUNTESTFLAGS)" | grep -vq -- --upgrade; then \
 		echo "Running upgrade test as RUNTESTFLAGS did not contain that"; \
-		POSTGIS_TOP_BUILD_DIR=$(abs_top_builddir) $(PERL) $(topsrcdir)/regress/run_test.pl \
+		POSTGIS_TOP_BUILD_DIR=$(abs_top_builddir) $(PERL) $(top_srcdir)/regress/run_test.pl \
       --upgrade \
       $(RUNTESTFLAGS) \
@@ -36,5 +36,5 @@ check-regress:
 	fi
 check-long:
-	$(PERL) $(topsrcdir)/regress/run_test.pl $(RUNTESTFLAGS) $(TESTS) $(TESTS_SLOW)
+	$(PERL) $(top_srcdir)/regress/run_test.pl $(RUNTESTFLAGS) $(TESTS) $(TESTS_SLOW)
diff --git a/sfcgal/regress/Makefile.in b/sfcgal/regress/Makefile.in
index 72eda6822..93f889788 100644
--- a/sfcgal/regress/Makefile.in
+++ b/sfcgal/regress/Makefile.in
@@ -19,9 +19,6 @@ PERL=@PERL@
 override RUNTESTFLAGS := $(RUNTESTFLAGS) --sfcgal
diff --git a/sfcgal/regress/tests.mk.in b/sfcgal/regress/tests.mk.in
index 0879e9f99..92d969f92 100644
--- a/sfcgal/regress/tests.mk.in
+++ b/sfcgal/regress/tests.mk.in
@@ -14,10 +14,10 @@ POSTGIS_GEOS_VERSION=@POSTGIS_GEOS_VERSION@
 POSTGIS_SFCGAL_VERSION=@POSTGIS_SFCGAL_VERSION@
 TESTS += \
-		$(topsrcdir)/sfcgal/regress/regress_sfcgal \
-		$(topsrcdir)/sfcgal/regress/approximatemedialaxis.sql
+		$(top_srcdir)/sfcgal/regress/regress_sfcgal \
+		$(top_srcdir)/sfcgal/regress/approximatemedialaxis.sql
 ifeq ($(shell expr "$(POSTGIS_SFCGAL_VERSION)" ">=" 10401),1)
 	TESTS += \
-		$(topsrcdir)/sfcgal/regress/alphashape.sql
+		$(top_srcdir)/sfcgal/regress/alphashape.sql
 endif
diff --git a/topology/test/Makefile.in b/topology/test/Makefile.in
index 9f6c8020d..190c1c77f 100644
--- a/topology/test/Makefile.in
+++ b/topology/test/Makefile.in
@@ -58,8 +58,5 @@ check-regress: check-regress-deps
 check-regress-deps: topo_predicates.sql load_topology.sql load_topology-4326.sql
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 8f28e38f7..2fbb08541 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -13,69 +13,69 @@
 override RUNTESTFLAGS := $(RUNTESTFLAGS) --topology
-  --before-upgrade-script $(topsrcdir)/topology/test/regress/hooks/hook-before-upgrade-topology.sql \
+  --before-upgrade-script $(top_srcdir)/topology/test/regress/hooks/hook-before-upgrade-topology.sql \
-  --after-upgrade-script $(topsrcdir)/topology/test/regress/hooks/hook-after-upgrade-topology.sql
+  --after-upgrade-script $(top_srcdir)/topology/test/regress/hooks/hook-after-upgrade-topology.sql
 TESTS += \
-	$(topsrcdir)/topology/test/regress/addedge.sql \
-	$(topsrcdir)/topology/test/regress/addface2.5d.sql \
-	$(topsrcdir)/topology/test/regress/addface.sql \
-	$(topsrcdir)/topology/test/regress/addnode.sql \
-	$(topsrcdir)/topology/test/regress/addtopogeometrycolumn.sql \
-	$(topsrcdir)/topology/test/regress/cleartopogeom.sql \
-	$(topsrcdir)/topology/test/regress/copytopology.sql \
-	$(topsrcdir)/topology/test/regress/createtopogeom.sql \
-	$(topsrcdir)/topology/test/regress/createtopology.sql \
-	$(topsrcdir)/topology/test/regress/droptopogeometrycolumn.sql \
-	$(topsrcdir)/topology/test/regress/droptopology.sql \
-	$(topsrcdir)/topology/test/regress/findlayer.sql \
-	$(topsrcdir)/topology/test/regress/findtopology.sql \
-	$(topsrcdir)/topology/test/regress/geometry_cast.sql \
-	$(topsrcdir)/topology/test/regress/getedgebypoint.sql \
-	$(topsrcdir)/topology/test/regress/getfacebypoint.sql \
-	$(topsrcdir)/topology/test/regress/getfacecontainingpoint.sql \
-	$(topsrcdir)/topology/test/regress/getnodebypoint.sql \
-	$(topsrcdir)/topology/test/regress/getnodeedges.sql \
-	$(topsrcdir)/topology/test/regress/getringedges.sql \
-	$(topsrcdir)/topology/test/regress/gettopogeomelements.sql \
-	$(topsrcdir)/topology/test/regress/gml.sql \
-	$(topsrcdir)/topology/test/regress/layertrigger.sql \
-	$(topsrcdir)/topology/test/regress/legacy_invalid.sql \
-	$(topsrcdir)/topology/test/regress/legacy_predicate.sql \
-	$(topsrcdir)/topology/test/regress/legacy_query.sql \
-	$(topsrcdir)/topology/test/regress/legacy_validate.sql \
-	$(topsrcdir)/topology/test/regress/polygonize.sql \
-	$(topsrcdir)/topology/test/regress/sqlmm.sql \
-	$(topsrcdir)/topology/test/regress/st_addedgemodface.sql \
-	$(topsrcdir)/topology/test/regress/st_addedgenewfaces.sql \
-	$(topsrcdir)/topology/test/regress/st_addisoedge.sql \
-	$(topsrcdir)/topology/test/regress/st_addisonode.sql \
-	$(topsrcdir)/topology/test/regress/st_changeedgegeom.sql \
-	$(topsrcdir)/topology/test/regress/st_createtopogeo.sql \
-	$(topsrcdir)/topology/test/regress/st_getfaceedges.sql \
-	$(topsrcdir)/topology/test/regress/st_getfacegeometry.sql \
-	$(topsrcdir)/topology/test/regress/st_modedgeheal.sql \
-	$(topsrcdir)/topology/test/regress/st_modedgesplit.sql \
-	$(topsrcdir)/topology/test/regress/st_moveisonode.sql \
-	$(topsrcdir)/topology/test/regress/st_newedgeheal.sql \
-	$(topsrcdir)/topology/test/regress/st_newedgessplit.sql \
-	$(topsrcdir)/topology/test/regress/st_remedgemodface.sql \
-	$(topsrcdir)/topology/test/regress/st_remedgenewface.sql \
-	$(topsrcdir)/topology/test/regress/st_removeisoedge.sql \
-	$(topsrcdir)/topology/test/regress/st_removeisonode.sql \
-	$(topsrcdir)/topology/test/regress/st_simplify.sql \
-	$(topsrcdir)/topology/test/regress/topo2.5d.sql \
-	$(topsrcdir)/topology/test/regress/topoelementarray_agg.sql \
-	$(topsrcdir)/topology/test/regress/topoelement.sql \
-	$(topsrcdir)/topology/test/regress/topogeo_addlinestring.sql \
-	$(topsrcdir)/topology/test/regress/topogeo_addpoint.sql \
-	$(topsrcdir)/topology/test/regress/topogeo_addpolygon.sql \
-	$(topsrcdir)/topology/test/regress/topogeom_addtopogeom.sql \
-	$(topsrcdir)/topology/test/regress/topogeom_edit.sql \
-	$(topsrcdir)/topology/test/regress/topogeometry_srid.sql \
-	$(topsrcdir)/topology/test/regress/topogeometry_type.sql \
-	$(topsrcdir)/topology/test/regress/topojson.sql \
-	$(topsrcdir)/topology/test/regress/topologysummary.sql \
-	$(topsrcdir)/topology/test/regress/totopogeom.sql \
-	$(topsrcdir)/topology/test/regress/validatetopology.sql
+	$(top_srcdir)/topology/test/regress/addedge.sql \
+	$(top_srcdir)/topology/test/regress/addface2.5d.sql \
+	$(top_srcdir)/topology/test/regress/addface.sql \
+	$(top_srcdir)/topology/test/regress/addnode.sql \
+	$(top_srcdir)/topology/test/regress/addtopogeometrycolumn.sql \
+	$(top_srcdir)/topology/test/regress/cleartopogeom.sql \
+	$(top_srcdir)/topology/test/regress/copytopology.sql \
+	$(top_srcdir)/topology/test/regress/createtopogeom.sql \
+	$(top_srcdir)/topology/test/regress/createtopology.sql \
+	$(top_srcdir)/topology/test/regress/droptopogeometrycolumn.sql \
+	$(top_srcdir)/topology/test/regress/droptopology.sql \
+	$(top_srcdir)/topology/test/regress/findlayer.sql \
+	$(top_srcdir)/topology/test/regress/findtopology.sql \
+	$(top_srcdir)/topology/test/regress/geometry_cast.sql \
+	$(top_srcdir)/topology/test/regress/getedgebypoint.sql \
+	$(top_srcdir)/topology/test/regress/getfacebypoint.sql \
+	$(top_srcdir)/topology/test/regress/getfacecontainingpoint.sql \
+	$(top_srcdir)/topology/test/regress/getnodebypoint.sql \
+	$(top_srcdir)/topology/test/regress/getnodeedges.sql \
+	$(top_srcdir)/topology/test/regress/getringedges.sql \
+	$(top_srcdir)/topology/test/regress/gettopogeomelements.sql \
+	$(top_srcdir)/topology/test/regress/gml.sql \
+	$(top_srcdir)/topology/test/regress/layertrigger.sql \
+	$(top_srcdir)/topology/test/regress/legacy_invalid.sql \
+	$(top_srcdir)/topology/test/regress/legacy_predicate.sql \
+	$(top_srcdir)/topology/test/regress/legacy_query.sql \
+	$(top_srcdir)/topology/test/regress/legacy_validate.sql \
+	$(top_srcdir)/topology/test/regress/polygonize.sql \
+	$(top_srcdir)/topology/test/regress/sqlmm.sql \
+	$(top_srcdir)/topology/test/regress/st_addedgemodface.sql \
+	$(top_srcdir)/topology/test/regress/st_addedgenewfaces.sql \
+	$(top_srcdir)/topology/test/regress/st_addisoedge.sql \
+	$(top_srcdir)/topology/test/regress/st_addisonode.sql \
+	$(top_srcdir)/topology/test/regress/st_changeedgegeom.sql \
+	$(top_srcdir)/topology/test/regress/st_createtopogeo.sql \
+	$(top_srcdir)/topology/test/regress/st_getfaceedges.sql \
+	$(top_srcdir)/topology/test/regress/st_getfacegeometry.sql \
+	$(top_srcdir)/topology/test/regress/st_modedgeheal.sql \
+	$(top_srcdir)/topology/test/regress/st_modedgesplit.sql \
+	$(top_srcdir)/topology/test/regress/st_moveisonode.sql \
+	$(top_srcdir)/topology/test/regress/st_newedgeheal.sql \
+	$(top_srcdir)/topology/test/regress/st_newedgessplit.sql \
+	$(top_srcdir)/topology/test/regress/st_remedgemodface.sql \
+	$(top_srcdir)/topology/test/regress/st_remedgenewface.sql \
+	$(top_srcdir)/topology/test/regress/st_removeisoedge.sql \
+	$(top_srcdir)/topology/test/regress/st_removeisonode.sql \
+	$(top_srcdir)/topology/test/regress/st_simplify.sql \
+	$(top_srcdir)/topology/test/regress/topo2.5d.sql \
+	$(top_srcdir)/topology/test/regress/topoelementarray_agg.sql \
+	$(top_srcdir)/topology/test/regress/topoelement.sql \
+	$(top_srcdir)/topology/test/regress/topogeo_addlinestring.sql \
+	$(top_srcdir)/topology/test/regress/topogeo_addpoint.sql \
+	$(top_srcdir)/topology/test/regress/topogeo_addpolygon.sql \
+	$(top_srcdir)/topology/test/regress/topogeom_addtopogeom.sql \
+	$(top_srcdir)/topology/test/regress/topogeom_edit.sql \
+	$(top_srcdir)/topology/test/regress/topogeometry_srid.sql \
+	$(top_srcdir)/topology/test/regress/topogeometry_type.sql \
+	$(top_srcdir)/topology/test/regress/topojson.sql \
+	$(top_srcdir)/topology/test/regress/topologysummary.sql \
+	$(top_srcdir)/topology/test/regress/totopogeom.sql \
+	$(top_srcdir)/topology/test/regress/validatetopology.sql
diff --git a/utils/check_tests_enabled.sh b/utils/check_tests_enabled.sh
index c7a289c30..b8f69f83c 100755
--- a/utils/check_tests_enabled.sh
+++ b/utils/check_tests_enabled.sh
@@ -25,8 +25,8 @@ check_enabled() {
   #echo "Suffix: ${suffix}"
   #echo "Basedir: ${bd}"
-  grep 'topsrcdir)' ${mk} |
-      sed 's|.*topsrcdir)/||;s/ .*$//' |
+  grep 'top_srcdir)' ${mk} |
+      sed 's|.*top_srcdir)/||;s/ .*$//' |
       sed 's|\\||' |
       sed 's/\.sql$//' > ${TMPDIR}/enabled_tests
Summary of changes:
 GNUmakefile.in                  |   3 -
 raster/test/regress/Makefile.in |   3 -
 raster/test/regress/tests.mk    | 194 ++++++++++++++---------------
 regress/core/Makefile.in        |   3 -
 regress/core/tests.mk.in        | 266 ++++++++++++++++++++--------------------
 regress/dumper/Makefile.in      |   3 -
 regress/dumper/tests.mk         |  12 +-
 regress/loader/Makefile.in      |   4 -
 regress/loader/tests.mk         |  56 ++++-----
 regress/runtest.mk              |  14 +--
 sfcgal/regress/Makefile.in      |   3 -
 sfcgal/regress/tests.mk.in      |   6 +-
 topology/test/Makefile.in       |   3 -
 topology/test/tests.mk          | 126 +++++++++----------
 utils/check_tests_enabled.sh    |   4 +-
 16 files changed, 339 insertions(+), 364 deletions(-)
hooks/post-receive
