[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-93-g95ebf0438
Tue Jun 21 05:42:19 PDT 2022
the project "PostGIS".
       via  95ebf04389aa77c3a0d47f8f7f92b58ee0496842 (commit)
      from  8003f013ad9e9cfb57d46f65f9af9cf5b7e0e969 (commit)
revisions in full, below.
commit 95ebf04389aa77c3a0d47f8f7f92b58ee0496842
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jun 21 12:46:15 2022 +0200
    Rename postgis_proc_upgrade.pl to create_upgrade.pl, drop unused argument
diff --git a/.editorconfig b/.editorconfig
index 493a499d5..8c724db4d 100644
--- a/.editorconfig
+++ b/.editorconfig
@@ -25,8 +25,8 @@ indent_style = tab
 indent_style = space
 indent_size = 2
-# Exception: utils/postgis_proc_upgrade.pl uses 4-spaces indent
-[utils/postgis_proc_upgrade.pl]
+# Exception: utils/create_upgrade.pl uses 4-spaces indent
+[utils/create_upgrade.pl]
 indent_size = 4
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index 8dd9af610..00448571a 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -130,8 +130,8 @@ sql/postgis_upgrade_for_extension.sql: ../../postgis/postgis_before_upgrade.sql
 	# WARNING: we should make sure these are not internal to function bodies
 	cat $^ | $(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' > $@
-sql/postgis_upgrade_for_extension.sql.in: sql/postgis_for_extension.sql ../../utils/postgis_proc_upgrade.pl | sql
-	$(PERL) @top_srcdir@/utils/postgis_proc_upgrade.pl $< UNUSED > $@
+sql/postgis_upgrade_for_extension.sql.in: sql/postgis_for_extension.sql ../../utils/create_upgrade.pl | sql
+	$(PERL) @top_srcdir@/utils/create_upgrade.pl $< > $@
 sql/postgis_for_extension.sql: ../../postgis/postgis.sql.in ../../postgis_revision.h | sql
 	$(SQLPP) -I at builddir@/../../postgis $< | grep -v '^#' | \
diff --git a/extensions/postgis_raster/Makefile.in b/extensions/postgis_raster/Makefile.in
index 1cb2d2ddb..13f1966cc 100644
--- a/extensions/postgis_raster/Makefile.in
+++ b/extensions/postgis_raster/Makefile.in
@@ -106,8 +106,8 @@ sql/rtpostgis_upgrade_for_extension.sql: ../../raster/rt_pg/rtpostgis_upgrade_cl
 	echo 'COMMIT;' >> $@
-sql/rtpostgis_upgrade_for_extension.sql.in: sql/rtpostgis_for_extension.sql ../../utils/postgis_proc_upgrade.pl | sql
+sql/rtpostgis_upgrade_for_extension.sql.in: sql/rtpostgis_for_extension.sql ../../utils/create_upgrade.pl | sql
 ../../doc/raster_comments.sql:
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index 5415a538f..4e74dbd9f 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -240,8 +240,8 @@ endif
 	$(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g;s'@extschema@\.''g" > $@
 #this is redundant but trying to fold in with extension just hangs
-postgis_upgrade.sql.in: postgis.sql ../utils/postgis_proc_upgrade.pl
+postgis_upgrade.sql.in: postgis.sql ../utils/create_upgrade.pl
 postgis_upgrade.sql: postgis_before_upgrade.sql postgis_upgrade.sql.in postgis_after_upgrade.sql
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 49cfcdbdd..5dd1f4602 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2902,9 +2902,9 @@ CREATE OR REPLACE FUNCTION postgis_wagyu_version() RETURNS text
 -- IMPORTANT:
--- Starting at 1.1.0 this function is used by postgis_proc_upgrade.pl
+-- Starting at 1.1.0 this function is used by create_upgrade.pl
 -- to extract version of postgis being installed.
--- Do not modify this w/out also changing postgis_proc_upgrade.pl
+-- Do not modify this w/out also changing create_upgrade.pl
 CREATE OR REPLACE FUNCTION postgis_scripts_installed() RETURNS text
 	AS _POSTGIS_SQL_SELECT_POSTGIS_SCRIPTS_VERSION
diff --git a/raster/rt_pg/Makefile.in b/raster/rt_pg/Makefile.in
index be8805c45..ae70a859e 100644
--- a/raster/rt_pg/Makefile.in
+++ b/raster/rt_pg/Makefile.in
@@ -146,8 +146,8 @@ $(OBJS): ../../liblwgeom/.libs/liblwgeom.a ../rt_core/librtcore.a ../../libpgcom
 $(SQL_OBJS): ../../postgis/sqldefines.h ../../postgis_revision.h
 #this is redundant but trying to fold in with the  other just hangs
-rtpostgis_upgrade.sql.in: rtpostgis.sql ../../utils/postgis_proc_upgrade.pl
+rtpostgis_upgrade.sql.in: rtpostgis.sql ../../utils/create_upgrade.pl
 rtpostgis_upgrade.sql: rtpostgis_upgrade_cleanup.sql rtpostgis_upgrade.sql.in rtpostgis_drop.sql
 	echo 'BEGIN;' > $@
diff --git a/sfcgal/Makefile.in b/sfcgal/Makefile.in
index 0c8cec8a4..9504ead5b 100644
--- a/sfcgal/Makefile.in
+++ b/sfcgal/Makefile.in
@@ -125,8 +125,8 @@ $(SQL_OBJS): ../postgis_config.h ../postgis_revision.h
 	$(SQLPP) -I at top_builddir@/postgis $< | grep -v '^#' | \
-sfcgal_upgrade.sql.in: sfcgal.sql ../utils/postgis_proc_upgrade.pl
+sfcgal_upgrade.sql.in: sfcgal.sql ../utils/create_upgrade.pl
 sfcgal_upgrade.sql: sfcgal_before_upgrade.sql sfcgal_upgrade.sql.in sfcgal_after_upgrade.sql
 	echo "BEGIN;" > $@
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 03372e862..041855dcb 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -107,7 +107,7 @@ endif
 #Generate upgrade script by stripping things that can't be reinstalled
 #e.g. don't bother with tables, types, triggers, and domains
-# TODO: use postgis_proc_upgrade.pl
+# TODO: use create_upgrade.pl
 topology_upgrade.sql.in:  topology.sql
 	$(PERL) -0777 -ne 's/^(CREATE|ALTER) (CAST|OPERATOR|TYPE|TABLE|SCHEMA|DOMAIN|TRIGGER).*?;//msg;print;' $< > $@
diff --git a/utils/Makefile.in b/utils/Makefile.in
index 650d83482..4dc63805a 100644
--- a/utils/Makefile.in
+++ b/utils/Makefile.in
@@ -36,7 +36,7 @@ SCRIPTS_built = postgis_restore.pl
 SCRIPTS = \
 	create_undef.pl \
 	repo_revision.pl \
-	postgis_proc_upgrade.pl \
+	create_upgrade.pl \
 	profile_intersects.pl \
 	test_estimation.pl \
 	test_joinestimation.pl
diff --git a/utils/README b/utils/README
index 255db0032..c8b4cc165 100644
--- a/utils/README
+++ b/utils/README
@@ -5,7 +5,7 @@ postgis_restore.pl
 	restore a spatial database dump to a (possibly updated)
 	new spatial database.
-postgis_proc_upgrade.pl
+create_upgrade.pl
 	Create a postgis procedures upgrade script. Will warn
 	if operations is not cleanly possible due to nature
 	of changes in postgis procedures.
diff --git a/utils/postgis_proc_upgrade.pl b/utils/create_upgrade.pl
similarity index 99%
rename from utils/postgis_proc_upgrade.pl
rename to utils/create_upgrade.pl
index dff97bc79..08bf455bd 100755
--- a/utils/postgis_proc_upgrade.pl
+++ b/utils/create_upgrade.pl
@@ -84,7 +84,7 @@ sub parse_missing
 ($#ARGV == 0)
   ||die
-"Usage: perl postgis_proc_upgrade.pl <postgis.sql> <version_from> [<schema>]\nCreates a new SQL script to upgrade all of the PostGIS functions.\n"
+"Usage: perl create_upgrade.pl <create_script.sql> [<schema>]\nCreates a new SQL script to upgrade all of the PostGIS functions.\n"
   if ( @ARGV < 1 || @ARGV > 3 );
 my $sql_file = $ARGV[0];
@@ -92,10 +92,8 @@ my $module = 'postgis';
 my $soname = '';
 my $version_to = "";
 my $version_to_num = 0;
-my $version_from = $ARGV[1];
-my $version_from_num = 0;
 my $schema = "";
-$schema = $ARGV[2] if @ARGV > 2;
+$schema = $ARGV[1] if @ARGV > 1;
 my @renamed_deprecated_functions = ();
Summary of changes:
 .editorconfig                                        | 4 ++--
 extensions/postgis/Makefile.in                       | 4 ++--
 extensions/postgis_raster/Makefile.in                | 4 ++--
 postgis/postgis.sql.in                               | 4 ++--
 raster/rt_pg/Makefile.in                             | 4 ++--
 sfcgal/Makefile.in                                   | 4 ++--
 topology/Makefile.in                                 | 2 +-
 utils/Makefile.in                                    | 2 +-
 utils/README                                         | 2 +-
 utils/{postgis_proc_upgrade.pl => create_upgrade.pl} | 6 ++----
 11 files changed, 19 insertions(+), 21 deletions(-)
 rename utils/{postgis_proc_upgrade.pl => create_upgrade.pl} (99%)
hooks/post-receive
