[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-101-g8135ef547
Sun Jun 26 14:14:50 PDT 2022
the project "PostGIS".
       via  8135ef547c13cf349660d245ea06b4b8dffb119b (commit)
      from  a6bbfd31517067559e7e4ff63f9dd614591a8d56 (commit)
revisions in full, below.
commit 8135ef547c13cf349660d245ea06b4b8dffb119b
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Jun 26 17:14:44 2022 -0400
    ST_ConcaveHull geometry collection issue. Closes #4541 for PostGIS 3.3.0 (old ST_ConcaveHull implementation)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 5dd1f4602..7d14b9674 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6606,8 +6606,9 @@ $$
 LANGUAGE 'plpgsql' IMMUTABLE STRICT PARALLEL SAFE _COST_HIGH;
 -- Availability: 2.0.0
--- Changed: 2.5.0
 -- Enhanced: 3.3.0 implements it in C, if GEOS >= 3.10
+-- Changed: 3.2.2
+-- Changed: 2.5.0
 CREATE OR REPLACE FUNCTION ST_ConcaveHull(param_geom geometry, param_pctconvex float, param_allow_holes boolean DEFAULT false) RETURNS geometry AS
 	DECLARE
@@ -6639,7 +6640,7 @@ $$
 				RETURN var_resultgeom;
 			END IF;
 		END IF;
-		IF @extschema at .ST_Dimension(var_resultgeom) > 1 AND param_pctconvex BETWEEN 0 and 0.98 THEN
+		IF @extschema at .ST_Dimension(var_resultgeom) > 1 AND param_pctconvex BETWEEN 0 and 0.99 THEN
 		-- get linestring that forms envelope of geometry
 			var_enline := @extschema at .ST_Boundary(@extschema at .ST_Envelope(var_param_geom));
 			var_buf := @extschema at .ST_Length(var_enline)/1000.0;
Summary of changes:
 postgis/postgis.sql.in | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
hooks/post-receive
