[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-102-ga86fef4ea
Mon Jun 27 14:22:53 PDT 2022
the project "PostGIS".
       via  a86fef4eaa7a383a08b30b48a221dcc3c0da7771 (commit)
      from  8135ef547c13cf349660d245ea06b4b8dffb119b (commit)
revisions in full, below.
commit a86fef4eaa7a383a08b30b48a221dcc3c0da7771
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon Jun 27 14:22:48 2022 -0700
    Improve doc for processing functions
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 39606a170..11f73528e 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -1358,7 +1358,7 @@ LINESTRING Z (-30 -29.7 5,-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 1,-46 -32 11
     <refentry id="ST_MaximumInscribedCircle">
       <refnamediv>
         <refname>ST_MaximumInscribedCircle</refname>
-        <refpurpose>Computes the largest circle that is fully contained within a geometry.</refpurpose>
+        <refpurpose>Computes the largest circle contained within a geometry.</refpurpose>
       </refnamediv>
       <refsynopsisdiv>
@@ -1372,12 +1372,19 @@ LINESTRING Z (-30 -29.7 5,-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 1,-46 -32 11
       <refsection>
         <title>Description</title>
-        <para>Finds the largest circle that is fully contained within a geometry.
-        Returns a record with the center point of the circle,
-        a point on the geometry that is nearest to the center, and the radius of the circle. </para>
+        <para>Finds the largest circle that is contained within a (multi)polygon,
+        or which does not overlap any lines and points.
+        Returns a record with fields:
+        </para>
+        <itemizedlist>
+            <listitem><para> <varname>center</varname> - center point of the circle </para></listitem>
+            <listitem><para> <varname>nearest</varname> - a point on the geometry nearest to the center </para></listitem>
+            <listitem><para> <varname>radius</varname> - radius of the circle </para></listitem>
+        </itemizedlist>
-        <para>For polygonal inputs, the circle is inscribed within the external ring, using the internal rings as boundaries.
-        For linear and point inputs, the circle is inscribed within the convex hull of the input, using the input as further boundaries.</para>
+        <para>For polygonal inputs, the circle is inscribed within the boundary rings, using the internal rings as boundaries.
+        For linear and point inputs, the circle is inscribed within the convex hull of the input,
+        using the input lines and points as further boundaries.</para>
         <para>Availability: 3.1.0 - requires GEOS >= 3.9.0.</para>
@@ -1419,7 +1426,7 @@ LINESTRING Z (-30 -29.7 5,-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 1,-46 -32 11
       </refsection>
       <refsection>
         <title>See Also</title>
-        <para><xref linkend="ST_Collect" />, <xref linkend="ST_MinimumBoundingRadius" /></para>
+        <para><xref linkend="ST_MinimumBoundingRadius" /></para>
       </refsection>
     </refentry>
@@ -1442,14 +1449,17 @@ LINESTRING Z (-30 -29.7 5,-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 1,-46 -32 11
       <refsection>
             <para>Returns the smallest circle polygon that contains a geometry. </para>
-            <note><para>The circle is approximated by a polygon with a default of 48 segments per quarter circle.  Because the polygon is an approximation of the minimum bounding circle, some points in the input geometry may not be contained within the polygon.  The approximation can be improved by increasing the number of segments, with little performance penalty.  For applications where a polygonal approximation is not suitable, ST_MinimumBoundingRadius may be used.</para></note>
-            <para>It is often used with MULTI and Geometry Collections.
-        Although it is not an aggregate - you can use it in conjunction
-        with ST_Collect to get the minimum bounding circle of a set of geometries.
-        ST_MinimumBoundingCircle(ST_Collect(somepointfield)).</para>
+            <note><para>The bounding circle is approximated by a polygon with a default of 48 segments per quarter circle.
+            Because the polygon is an approximation of the minimum bounding circle, some points in the input geometry may not be contained within the polygon.
+            The approximation can be improved by increasing the number of segments.
+            For applications where an approximation is not suitable <xref linkend="ST_MinimumBoundingRadius" /> may be used.</para></note>
+            <para>This function is not an aggregate. It can be used
+            with <xref linkend="ST_Collect" /> to get the minimum bounding circle of a set of geometries.</para>
-        <para>The ratio of the area of a polygon divided by the area of its Minimum Bounding Circle is often referred to as the Roeck test.</para>
+        <para>The ratio of the area of a polygon divided by the area of its Minimum Bounding Circle
+        is referred to as the <emphasis>Reock compactness score</emphasis>.</para>
         <para>Performed by the GEOS module.</para>
         <para>Availability: 1.4.0</para>
@@ -1490,7 +1500,7 @@ POLYGON((135.59714732062 115,134.384753327498 102.690357210921,130.79416296937 9
       </refsection>
       <refsection>
+        <para><xref linkend="ST_Collect" />, <xref linkend="ST_MinimumBoundingRadius" /> </para>
       </refsection>
     </refentry>
@@ -1511,7 +1521,14 @@ POLYGON((135.59714732062 115,134.384753327498 102.690357210921,130.79416296937 9
     <refsection>
-        <para>Returns a record containing the center point and radius of the smallest circle that contains a geometry.</para>
+        <para>Computes the center point and radius of the smallest circle that contains a geometry.
+        </para>
+        <itemizedlist>
+        </itemizedlist>
         <para>Use in conjunction with <xref linkend="ST_Collect"/> to get the minimum bounding circle of a set of geometries.</para>
         <para>Availability - 2.3.0</para>
     </refsection>
Summary of changes:
 doc/reference_processing.xml | 47 ++++++++++++++++++++++++++++++--------------
 1 file changed, 32 insertions(+), 15 deletions(-)
hooks/post-receive
