[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-658-gb6b188849
Mon Mar 28 12:59:06 PDT 2022
the project "PostGIS".
       via  b6b188849a2b9e1af37cd560a8fae8455e3db43b (commit)
      from  bb3842bfeef613f32e5dd032cad85599159ffb76 (commit)
revisions in full, below.
commit b6b188849a2b9e1af37cd560a8fae8455e3db43b
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Mar 28 21:56:47 2022 +0200
    Fix missing TopoGeometries count with wrong layer_id in deploy tables
    Includes regress test
diff --git a/topology/sql/manage/TopologySummary.sql.in b/topology/sql/manage/TopologySummary.sql.in
index 8bc5b1f37..47c64496f 100644
--- a/topology/sql/manage/TopologySummary.sql.in
+++ b/topology/sql/manage/TopologySummary.sql.in
@@ -18,7 +18,7 @@
 CREATE OR REPLACE FUNCTION topology.TopologySummary(atopology varchar)
 RETURNS text
 AS
+$BODY$
 DECLARE
   rec RECORD;
   rec2 RECORD;
@@ -142,14 +142,26 @@ BEGIN
                   || quote_ident(rec.feature_column);
         IF n > 0 THEN
-          sql := 'SELECT count(*) FROM ( SELECT topogeo_id FROM '
-            || quote_ident(atopology)
-            || '.relation r WHERE r.layer_id = ' || rec.layer_id
-            || ' EXCEPT SELECT DISTINCT id('
-            || quote_ident(rec.feature_column) || ') FROM '
-            || quote_ident(rec.schema_name) || '.'
-            || quote_ident(rec.table_name) || ') as foo';
+          sql := format(
+SELECT count(*) FROM (
+  SELECT topogeo_id
+  FROM %1$I.relation r
+  WHERE r.layer_id = %2$L
+    EXCEPT
+  SELECT DISTINCT id(%3$I)
+  FROM %4$I.%5$I
+  WHERE layer_id(%3$I) = %2$L
+) as foo
+            atopology,
+            rec.layer_id,
+            rec.feature_column,
+            rec.schema_name,
+            rec.table_name
           BEGIN
+            RAISE DEBUG 'Executing %', sql;
             EXECUTE sql INTO STRICT missing;
             IF missing > 0 THEN
               ret = ret || ' (' || missing || ' missing topogeoms)';
@@ -193,7 +205,7 @@ BEGIN
   RETURN ret;
 END
+$BODY$
 LANGUAGE 'plpgsql' STABLE STRICT;
 --} TopologySummary
diff --git a/topology/test/regress/topologysummary.sql b/topology/test/regress/topologysummary.sql
index 37df046b3..bce065cde 100644
--- a/topology/test/regress/topologysummary.sql
+++ b/topology/test/regress/topologysummary.sql
@@ -23,7 +23,9 @@ CREATE TABLE test.t(i int);
 SELECT E'--registered_missing_layer_column--\n' || TopologySummary('test');
 ALTER TABLE test.t ADD c TopoGeometry;
 SELECT E'--registered_layer_missing_topogeom--\n' || TopologySummary('test');
-INSERT INTO test.t(c) VALUES ( (1,1,1,1) );
+INSERT INTO test.t(c) VALUES ( (1,2,1,1) );
+SELECT E'--registered_layer_missing_topogeom_in_proper_layer--\n' || TopologySummary('test');
+UPDATE test.t SET c.layer_id = 1 WHERE layer_id(c) = 2;
 SELECT E'--registered_layer--\n' || TopologySummary('test');
 -- TODO: test hierarchical
 DROP TABLE test.t;
diff --git a/topology/test/regress/topologysummary_expected b/topology/test/regress/topologysummary_expected
index 573402f79..e5454d723 100644
--- a/topology/test/regress/topologysummary_expected
+++ b/topology/test/regress/topologysummary_expected
@@ -40,6 +40,11 @@ Layer 1, type Puntal (1), 1 topogeoms
 Topology test (id 1, SRID 10, precision 20)
 0 nodes, 0 edges, 0 faces, 1 topogeoms in 1 layers
+Layer 1, type Puntal (1), 1 topogeoms
+ Deploy: test.t.c (1 missing topogeoms)
+--registered_layer_missing_topogeom_in_proper_layer--
+Topology test (id 1, SRID 10, precision 20)
+0 nodes, 0 edges, 0 faces, 1 topogeoms in 1 layers
Summary of changes:
 topology/sql/manage/TopologySummary.sql.in     | 30 ++++++++++++++++++--------
 topology/test/regress/topologysummary.sql      |  4 +++-
 topology/test/regress/topologysummary_expected |  5 +++++
 3 files changed, 29 insertions(+), 10 deletions(-)
hooks/post-receive
