[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-659-gd937e7245
Mon Mar 28 14:08:31 PDT 2022
the project "PostGIS".
       via  d937e7245d3b4314ff9f61d00d03af52f76a5d83 (commit)
      from  b6b188849a2b9e1af37cd560a8fae8455e3db43b (commit)
revisions in full, below.
commit d937e7245d3b4314ff9f61d00d03af52f76a5d83
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Mar 28 23:07:58 2022 +0200
    Fix missing TopoGeometries count with wrong topology_id in deploy tables
    Includes regress test
diff --git a/topology/sql/manage/TopologySummary.sql.in b/topology/sql/manage/TopologySummary.sql.in
index 47c64496f..ebca1f33e 100644
--- a/topology/sql/manage/TopologySummary.sql.in
+++ b/topology/sql/manage/TopologySummary.sql.in
@@ -152,13 +152,15 @@ SELECT count(*) FROM (
   SELECT DISTINCT id(%3$I)
   FROM %4$I.%5$I
   WHERE layer_id(%3$I) = %2$L
+    AND topology_id(%3$I) = %6$L
 ) as foo
             atopology,
             rec.layer_id,
             rec.feature_column,
             rec.schema_name,
-            rec.table_name
+            rec.table_name,
+            var_topology_id
           BEGIN
             RAISE DEBUG 'Executing %', sql;
diff --git a/topology/test/regress/topologysummary.sql b/topology/test/regress/topologysummary.sql
index bce065cde..0f57ff7c0 100644
--- a/topology/test/regress/topologysummary.sql
+++ b/topology/test/regress/topologysummary.sql
@@ -25,7 +25,9 @@ ALTER TABLE test.t ADD c TopoGeometry;
 SELECT E'--registered_layer_missing_topogeom--\n' || TopologySummary('test');
 INSERT INTO test.t(c) VALUES ( (1,2,1,1) );
 SELECT E'--registered_layer_missing_topogeom_in_proper_layer--\n' || TopologySummary('test');
-UPDATE test.t SET c.layer_id = 1 WHERE layer_id(c) = 2;
+UPDATE test.t SET c.layer_id = 1, c.topology_id = topology_id(c)+1 WHERE layer_id(c) = 2;
+SELECT E'--registered_layer_missing_topogeom_in_proper_topo--\n' || TopologySummary('test');
+UPDATE test.t SET c.topology_id = topology_id(c)-1 WHERE layer_id(c) = 1;
 SELECT E'--registered_layer--\n' || TopologySummary('test');
 -- TODO: test hierarchical
 DROP TABLE test.t;
diff --git a/topology/test/regress/topologysummary_expected b/topology/test/regress/topologysummary_expected
index e5454d723..4cd90d36e 100644
--- a/topology/test/regress/topologysummary_expected
+++ b/topology/test/regress/topologysummary_expected
@@ -45,6 +45,11 @@ Layer 1, type Puntal (1), 1 topogeoms
 Topology test (id 1, SRID 10, precision 20)
 0 nodes, 0 edges, 0 faces, 1 topogeoms in 1 layers
+Layer 1, type Puntal (1), 1 topogeoms
+ Deploy: test.t.c (1 missing topogeoms)
+--registered_layer_missing_topogeom_in_proper_topo--
+Topology test (id 1, SRID 10, precision 20)
+0 nodes, 0 edges, 0 faces, 1 topogeoms in 1 layers
Summary of changes:
 topology/sql/manage/TopologySummary.sql.in     | 4 +++-
 topology/test/regress/topologysummary.sql      | 4 +++-
 topology/test/regress/topologysummary_expected | 5 +++++
 3 files changed, 11 insertions(+), 2 deletions(-)
hooks/post-receive
