[postgis-tickets] [PostGIS] #5145: segfault with select ST_Node(ST_GeomFromText('LINESTRING EMPTY'))
PostGIS trac at osgeo.org
Sat May 14 08:53:15 PDT 2022
  Reporter:  cactusbone  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS GEOS
 Component:  postgis     |    Version:  3.2.x
Resolution:              |   Keywords:
Comment (by robe):
 @cactusnode,
 Thanks for the update.  I still seem to be getting a crash though
 In both
 POSTGIS="3.2.1 3.2.1" [EXTENSION] PGSQL="140" GEOS="3.10.2-CAPI-1.16.0"
 PROJ="7.2.1" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1"
 WAGYU="0.5.0 (Internal)" PostgreSQL 14.1, compiled by Visual C++ build
 1914, 64-bit
 and
 POSTGIS="3.3.0dev 3.2.0-693-g9870fd492" [EXTENSION] PGSQL="140" GEOS="3.11
 .0dev-CAPI-1.16.0" PROJ="7.2.1" GDAL="GDAL 3.3.3, released 2021/10/25"
 LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)"
 RASTER PostgreSQL 14rc1 on x86_64-w64-mingw32, compiled by gcc.exe (x86_64
 -posix-seh-rev0, Built by MinGW-W64 project) 8.1.0, 64-bit
 Though what puzzles me is this test should be one that is tested in
 gardentests so I got to check why that isn't picking this up.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5145#comment:2>
