[postgis-tickets] [PostGIS] #5145: segfault with select ST_Node(ST_GeomFromText('LINESTRING EMPTY'))
PostGIS trac at osgeo.org
Sat May 14 22:15:46 PDT 2022
  Reporter:  cactusbone  |      Owner:  pramsey
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:  PostGIS GEOS
 Component:  postgis     |    Version:  3.2.x
Resolution:  fixed       |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Okay I'm going to close this out.  It works after I updated my geos to
 geos main.  The 3.10.2 I have it's still broken, so I guess that's because
 this fix was released only 10 days ago so will be in 3.10.3.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5145#comment:3>
