[postgis-tickets] [PostGIS] #5150: postgis_extension_AddToSearchPath should take input as text instead of varchar, helpers should use CREATE FUNCTION (was: postgis_extension_AddToSearchPath should take input as text instead of varchar)
    trac at osgeo.org
    Sat May 14 23:16:03 PDT 2022
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  assigned
  Priority:  medium                 |  Milestone:  PostGIS 2.5.7
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Changes (by robe):
 * summary:
     varchar
Old description:
> This is a security change.
> It is possible for a user to create a function
> postgis_extension_AddToSearchPath(text) in the same schema as the
> postgis_extension_AddToSearchPath(varchar) we defined.
> This could allow a rogue user to have their version of function run
> during extension create/updates instead of the one we ship.
New description:
 This could allow a rogue user to have their version of function run during
 Also as general best practice we should use CREATE FUNCTION instead of
 CREATE OR REPLACE FUNCTION.  We can easily change for the helper functions
 since they are created as part of install and then dropped after.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5150#comment:1>
