[postgis-tickets] [PostGIS] #5150: postgis_extension_AddToSearchPath should take input as text instead of varchar, helpers should use CREATE FUNCTION
PostGIS trac at osgeo.org
Sun May 15 06:28:58 PDT 2022
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  assigned
  Priority:  medium                 |  Milestone:  PostGIS 2.5.7
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"c356da35f061c2f3a1d55cdd2ead9b55efd4a415/git" c356da3/git]:
 {{{#!CommitTicketReference repository="git"
 revision="c356da35f061c2f3a1d55cdd2ead9b55efd4a415"
 Change signature of AddToSearchPath, references #5150
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5150#comment:2>
