[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-857-g1324a010d
git at osgeo.org
git at osgeo.org
Mon May 16 08:33:38 PDT 2022
the project "PostGIS".
via 1324a010dabc2ef30a7cb5d472568bb5baeb9152 (commit)
from 6188339d51b2fea912cc0972a28302c806e1c7f4 (commit)
revisions in full, below.
commit 1324a010dabc2ef30a7cb5d472568bb5baeb9152
Author: Sandro Santilli <strk at kbt.io>
Date: Mon May 16 17:32:50 2022 +0200
Print usage of pgtopo_export if called with -h / --help
diff --git a/topology/loader/pgtopo_export b/topology/loader/pgtopo_export
index ac203e3e4..76e8976ba 100755
--- a/topology/loader/pgtopo_export
+++ b/topology/loader/pgtopo_export
@@ -20,7 +20,10 @@ SKIP_LAYERS=no
OUTFILE=-
while test -n "$1"; do
- if test "$1" = '--skip-layers'; then
+ if test "$1" = '--help' || test "$1" = '-h'; then
+ usage
+ exit 0
+ elif test "$1" = '--skip-layers'; then
SKIP_LAYERS=yes
shift
elif test "$1" = '-f'; then
@@ -44,10 +47,6 @@ DUMPNAME="pgtopo_export"
if test "${OUTFILE}" = "-"; then
exec 4>&2
- if [ -t 1 ]; then
- echo "Exporting to terminal is not supported, please redirect stdout or specify a destination with -f" >&4
- exit 1
- fi
else
exec 4>&1
fi
@@ -57,6 +56,13 @@ test -n "${TOPONAME}" || {
exit 1
+if test "${OUTFILE}" = "-"; then
+ if [ -t 1 ]; then
+ echo "Exporting to terminal is not supported, please redirect stdout or specify a destination with -f" >&2
+ exit 1
+ fi
+fi
TMPDIR=${TMPDIR-/tmp}
WORKDIR=${TMPDIR}/pgtopo_export_$$
DUMPDIR=${WORKDIR}/${DUMPNAME}
Summary of changes:
topology/loader/pgtopo_export | 16 +++++++++++-----
1 file changed, 11 insertions(+), 5 deletions(-)
hooks/post-receive
