[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-858-g940834bd0
Mon May 16 09:00:38 PDT 2022
the project "PostGIS".
       via  940834bd094e75a504b537234c453a0d1f115d5c (commit)
      from  1324a010dabc2ef30a7cb5d472568bb5baeb9152 (commit)
revisions in full, below.
commit 940834bd094e75a504b537234c453a0d1f115d5c
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon May 16 18:00:14 2022 +0200
    Document pgtopo_export and pgtopo_import
    References #5116
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 3520b1758..de100245a 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -4172,4 +4172,131 @@ two topogeometries intersect.
         </refsection>
       </refentry>
 </sect1>
+<sect1 id="Topology_Import_Export">
+    <title>Importing and exporting Topologies</title>
+    <para>
+Once you have created topologies, and maybe associated topological layers,
+you might want to export them into a file-based format for backup or transfer
+into another database.
+    </para>
+    <para>
+Using the standard dump/restore tools of PostgreSQL is
+problematic because topologies are composed by a set of tables (4 for
+primitives, an arbitrary number for layers) and records in metadata tables
+(topology.topology and topology.layer). Additionally, topology identifiers
+are not univoque across databases so that parameter of your topology
+will need to be changes upon restoring it.
+    </para>
+    <para>
+In order to simplify export/restore of topologies a pair of
+executables are provided: <filename>pgtopo_export</filename>
+and <filename>pgtopo_import</filename>. Example usage:
+    </para>
+<programlisting>
+pgtopo_export dev_db topo1 | pgtopo_import topo1 | psql staging_db
+</programlisting>
+    <sect2 id="pgtopo_export">
+        <title>Using the Topology exporter</title>
+        <para>
+The <filename>pgtopo_export</filename> script takes the name of a
+database and a topology and outputs a dump file which can be used
+to import the topology (and associated layers) into a new database.
+        </para>
+        <para>
+By default <filename>pgtopo_export</filename> writes the
+dump file to the standard output so that it can be piped to
+<filename>pgtopo_import</filename> or redirected to a file
+(refusing to write to terminal). You can optionally specify
+an output filename with the <code>-f</code> commandline switch.
+        </para>
+        <para>
+By default <filename>pgtopo_export</filename> includes a dump
+of all layers defined against the given topology. This may be more
+data than you need, or may be non-working (in case your layer tables
+have complex dependencies) in which case you can request skipping the
+layers with the <code>--skip-layers</code> switch and deal with those
+separately.
+        </para>
+        <para>
+Invoking <filename>pgtopo_export</filename> with the
+<code>--help</code> (or <code>-h</code> for short) switch
+will always print short usage string.
+        </para>
+        <para>
+The dump file format is a compressed tar archive of a
+<filename>pgtopo_export</filename> directory containing
+at least a <filename>pgtopo_dump_version</filename> file with
+format version info. As of version <code>1</code> the directory
+contains tab-delimited CSV files with data of the topology
+primitive tables (node, edge_data, face, relation), of the
+topology and layer records associated with it, and optionall
+(if <code>--skip-layers</code> is not given) a custom-format
+PostgreSQL dump of tables reported as being layers of the given
+topology.
+        </para>
+    </sect2> <!-- pgtopo_export -->
+    <sect2 id="pgtopo_import">
+        <title>Using the Topology importer</title>
+        <para>
+The <filename>pgtopo_import</filename> script takes a
+<code>pgtopo_export</code> format topology dump and a
+name to give to  the topology to be created and outputs
+an SQL script reconstructing the topology and associated
+layers.
+        </para>
+        <para>
+The generated SQL file will contain statements that create
+a topology with the given name, load primitive data in it,
+restores and registers all topology layers by properly
+linking all TopoGeometry values to their correct topology.
+        </para>
+        <para>
+By default <filename>pgtopo_import</filename> reads the dump
+from the standard input so that it can be used in conjuction
+with <filename>pgtopo_export</filename> in a pipeline.
+You can optionally specify an input filename with the
+<code>-f</code> commandline switch.
+        </para>
+        <para>
+By default <filename>pgtopo_import</filename> includes in the output
+SQL file the code to restore all layers found in the dump.
+        </para>
+        <para>
+This may be unwanted or non-working in case your target database already
+have tables with the same name as the ones in the dump. In that case
+you can request skipping the layers with the <code>--skip-layers</code>
+switch and deal with those separately (or later).
+        </para>
+        <para>
+SQL to only load and link layers to a named topology can be generated
+using the <code>--only-layers</code> switch. This can be useful to load
+layers AFTER resolving the naming conflicts or to link layers to a
+different topology (say a spatially-simplified version of the starting
+topology).
+        </para>
+    </sect2> <!-- pgtopo_import -->
+</sect1> <!-- Importing and exporting Topologies -->
 </chapter>
Summary of changes:
 doc/extras_topology.xml | 127 ++++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 127 insertions(+)
hooks/post-receive
