[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-859-gbd04b787f
Tue May 17 02:58:25 PDT 2022
the project "PostGIS".
       via  bd04b787f49509ef13801c72a0ebc981669e982c (commit)
      from  940834bd094e75a504b537234c453a0d1f115d5c (commit)
revisions in full, below.
commit bd04b787f49509ef13801c72a0ebc981669e982c
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue May 17 11:55:48 2022 +0200
    Fix out-of-build install of topology import/export scripts
    References #5116
diff --git a/topology/Makefile.in b/topology/Makefile.in
index f650586db..03372e862 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -30,7 +30,6 @@ endif
 # Files to be copied to the contrib/ directory
 DATA_built=topology.sql topology_upgrade.sql uninstall_topology.sql
-SCRIPTS = loader/pgtopo_import loader/pgtopo_export
 # SQL preprocessor
 SQLPP = @SQLPP@
@@ -74,7 +73,10 @@ PGXS := @PGXS@
 NO_TEMP_INSTALL=yes
 include $(PGXS)
+top_builddir = @top_builddir@
 VPATH := @srcdir@
+INSTALL = @INSTALL@
+LIBTOOL = @LIBTOOL@
 # Set PERL _after_ the include of PGXS
 PERL=@PERL@
@@ -158,3 +160,14 @@ clean-subdirs:
 distclean: clean
 	rm -f Makefile test/Makefile
+installdir:
+	mkdir -p $(DESTDIR)$(bindir)
+install: install-importer install-exporter
+install-importer: loader/pgtopo_import | installdir
+	$(LIBTOOL) --mode=install $(INSTALL) $^ "$(DESTDIR)$(bindir)/pgtopo_import"
+install-exporter: loader/pgtopo_export | installdir
+	$(LIBTOOL) --mode=install $(INSTALL) $^ "$(DESTDIR)$(bindir)/pgtopo_export"
Summary of changes:
 topology/Makefile.in | 15 ++++++++++++++-
 1 file changed, 14 insertions(+), 1 deletion(-)
hooks/post-receive
