[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-861-g3389bf538
Tue May 17 07:19:15 PDT 2022
the project "PostGIS".
       via  3389bf538ae1e7b5c8258c9cc1af49752b3bd180 (commit)
       via  b3d52753cd8c9913084e15f27522ab389c0a35aa (commit)
      from  bd04b787f49509ef13801c72a0ebc981669e982c (commit)
revisions in full, below.
commit 3389bf538ae1e7b5c8258c9cc1af49752b3bd180
Author: Regina Obe <lr at pcorp.us>
Date:   Tue May 17 10:19:07 2022 -0400
    More thorough testing of empties. CIs that do garden should crash with this
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index e787daea7..4907d2be7 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -8,7 +8,7 @@
 			using a garden variety of geometries.  Its intent is to flag major crashes.
 	<xsl:output method="text" />
-	<xsl:variable name='testversion'>3.2.0</xsl:variable>
+	<xsl:variable name='testversion'>3.3.0</xsl:variable>
 	<xsl:variable name='fnexclude14'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
 	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
 	<!--This is just a place holder to state functions not supported or tested separately -->
@@ -238,6 +238,17 @@ FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.0821 42.3036 2,-71.
 		</pgis:gset>
+		<pgis:gset ID="Empty Linestring" GeometryType="LINESTRING" createtable="false">
+		(SELECT ST_GeomFromText('LINESTRING EMPTY',4326) As the_geom)
+		</pgis:gset>
+		<pgis:gset ID="Empty Point" GeometryType="POINT" createtable="false">
+		(SELECT ST_GeomFromText('POINT EMPTY',4326) As the_geom)
+		</pgis:gset>
+		<pgis:gset ID="Empty Polygon" GeometryType="POLYGON" createtable="false">
+		(SELECT ST_GeomFromText('POLYGON EMPTY',4326) As the_geom)
+		</pgis:gset>
 		<pgis:gset ID="Empty Geometry Collection" GeometryType="GEOMETRY" createtable="false">
 		 (SELECT ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326) As the_geom )
commit b3d52753cd8c9913084e15f27522ab389c0a35aa
Date:   Tue May 17 10:18:30 2022 -0400
    Exclude visual code file
diff --git a/.gitignore b/.gitignore
index 1caf56734..c8e0cce96 100644
--- a/.gitignore
+++ b/.gitignore
@@ -191,6 +191,7 @@ postgis/uninstall_sfcgal.sql
 .idea/*
 .syntastic_c_config
 .vs/*
+.vscode/*
 # LLVM JIT
 *.bc
Summary of changes:
 .gitignore                         |  1 +
 doc/xsl/postgis_gardentest.sql.xsl | 13 ++++++++++++-
 2 files changed, 13 insertions(+), 1 deletion(-)
hooks/post-receive
