[postgis-tickets] [PostGIS] #5278: GHA PG16 tests failing on all warnings being treated as errors
PostGIS trac at osgeo.org
Wed Nov 2 15:04:24 PDT 2022
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 So I enabled PG16 on github actions and it's failing because of all sorts
 of warnings.
 https://github.com/postgis/postgis/actions/runs/3380700459/jobs/5613777652
 Most notably in
 gserialized_spgist_2d.c (use of error: passing argument 1 of
 'DatumGetPointer' makes integer from pointer without a cast [-Werror=int-
 conversion] )
 lwgeom_triggers.c:113:25: note: in expansion of macro
 'DirectFunctionCall1'
   113 |   out = PointerGetDatum(DirectFunctionCall1(LWGEOM_addBBOX, in));
 In file included from lwgeom_triggers.c:26:
 /usr/local/pgsql/include/server/postgres.h:670:29: note: expected 'const
 void *' but argument is of type 'Datum' {aka 'long unsigned int'}
   670 | PointerGetDatum(const void *X)
 gserialized_spgist_3d.c:433:9: note: shadowed declaration is here
   433 |  BOX3D *box = DatumGetBox3DP(in->datums[0]);
 In file included from ../libpgcommon/lwgeom_pg.h:22,
                  from gserialized_gist_2d.c:51:
 /usr/local/pgsql/include/server/utils/geo_decls.h:239:25: note: expected
 'const BOX *' but argument is of type 'BOX2DF *'
   239 | BoxPGetDatum(const BOX *X)
 gserialized_spgist_3d.c:484:10: error: declaration of 'box' shadows a
 previous local [-Werror=shadow=compatible-local]
 I didn't think PG16 changed that recently, so these might exist in
 earlier.  Looks like only PG14 GHA is testing in tests mode which treats
 all warnings as errors, and that one is running fine.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5278>
