[postgis-tickets] [PostGIS] #5278: GHA PG16 tests failing on all warnings being treated as errors
PostGIS trac at osgeo.org
Wed Nov 2 15:11:47 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"2405b53478cd52dd6525fd53ce2da0cd30d817da/git" 2405b53/git]:
 {{{#!CommitTicketReference repository="git"
 revision="2405b53478cd52dd6525fd53ce2da0cd30d817da"
 Change PG16 to not treat warnings as errors. References #5278
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5278#comment:1>
